Minolta cxpro duplexing
How do you duplex print on these copiers
  • thsthsths May 16, 2008
    I could not find any option or setting neither in the DIALTA printer driver or the copier itself to make it work as a duplex printer (when printing from my PC).
  • 87 Answers
Is this a CSpro?
Posted on Jan 24, 2008
6ya staff
SOURCE:
How i print paper in duplex
get a duplexer from a dealership
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Jun 18, 2014 | Konica Minolta bizhub 350 All-In-One Laser...
How i print duplex paper
cant print thick three paper in duplex unless you go manual print one side stick in draw then print other side thick three is like a pizza box duplexer for a 350 is less 6" of room.
Konica Minolta C451 is ghosting only black color and ONLY when duplexing (first side is OK, just second side is ghosted). Black parts of print looks like smeared in direction how paper moves through p
what media are you using and what is the weight of the media you are using and does the copier know this and is correctly set
Mar 23, 2014 | Konica Minolta Bizhub C451 Copy-print-scan
When i turn the photocopier minolta di 470 on the table displays normally after a moment the photocopier turns off and displays the code c1334 i would like to now the meaning of the code.
C - 1334 Duplex take up print command error.
A duplex take up print command is not received for the paper to be taken up from the duplex after the papers has moved past the horizontal transport but before it reaches the transport roller.
The number of duplex take up print commands falls short of the number of sheets of paper to be taken up from the duplex or the leading edge of the sheet of paper,for wich a duplex take up print command is yet to be received activates the transport roller sensor.
Clean the transport feed rollers and the sensors.Reset the error code using the trouble reset switch and open/close the front door.
Apr 09, 2013 | Konica Minolta Office Equipment & Supplies
It has a code 1334
C1334 Duplex take-up print
command error
• A Duplex take-up print command is not received for
the paper to be taken up from the Duplex after the
paper has moved past the horizontal transport, but
before it reaches the Transport Roller.
• The number of Duplex take-up print commands falls
up from the Duplex, or the leading edge of a sheet
of paper, for which a Duplex take-up print command
is yet to be received, activates the Transport Roller
Sensor.
Apr 09, 2013 | Minolta Office Equipment & Supplies
We can duplex copy but not duplex print on the KM Bizhub 250. When printing from the computer, in the Konica Document Properties Window on the Layout tab, when the Print Type pull down screen is activated...
Hello
See if you have selected weight paper from the tray in the duplex mode.
Weight paper is selected in duplex mode only from the bypass.
So you check that the paper in the tray 1 or tray 2 must be plain paper and in duplex mode it can print normally.
Jan 29, 2010 | Konica Minolta bizhub 250 All-In-One Laser...
Bixhub c351- I can copy in duplex but i can not print in duplex
Have you told the print driver that you have a duplex fitted, also is the paper set as plain as any thick setting will cancel out the duplex function.
Jun 16, 2009 | Konica Minolta bizhub 250 All-In-One Laser...
Cannot print in duplex
Go to Option, in driver and be sure that the Duplex Option is installed.
Reset your Toners and Imaging units for Minolta Bizhub and CF series.
http://www.chipreset.eu
Jun 01, 2009 | Konica Minolta bizhub 250 All-In-One Laser...
Kinoca Minolta Di2510 Double-sided printing
Yes it can be done, if the m/c is having duplex unit.
Mar 02, 2009 | Konica Minolta Office Equipment & Supplies
Duplex Printing
do you have duplex installed ? if you trying to copy duplex originals, you need duplex feeder.. in main displey the left tab is dupleks printing, if you have there options 1 -1; 2-1; 1-2; 2-2 then you have a duplex installed and you can copy/print duplex. also in driver menu there is a option duplex, wath you have to choose if you printing.
Apr 25, 2008 | Konica Minolta bizhub C250 All-In-One...
41 people viewed this question
jasbo
jasbo
Ekse
Marvin
Marvin
