Question about Xerox WorkCentre Pro 555 Plain Paper Laser Fax
Bad copies I put in new toner, faxes are ineligible to read, they have missing lines coming all the way down the paper.
    Genius:
  • 1,003 Answers
Take out toner cartridge shake from left to right and reinstall cartridge
Posted on Jan 24, 2008
Change toner
Step 1 Check the top of your Canon fax/copy machine to see if your specific model has a protruding extension piece from the plastic delivery tray. Push the extension piece down if one is present on your model.
Step 2
Grip the bottom edge of the paper delivery tray at the front of the machine. Lift the tray upward to reveal the rectangular, plastic toner cartridge inside the machine.
Related Reading: How to Add Toner to a Canon X25
Step 3
Grab the handle at the top of the current toner cartridge and lift the cartridge upward. Pull the toner out of the machine and set it aside.
Step 4
Set your replacement toner cartridge over the empty space in the fax/copy machine. Ensure that the arrow near the bottom of the cartridge is facing down, and line up the protruding guide piece on the left side of the cartridge with the groove inside the machine. Push the toner downward until it snaps into position.
Step 5
Push the paper delivery tray back down, and lift up the extension piece if your model uses one.
May 06, 2015 | Office Equipment & Supplies
Fax machine print light
When you see light print it can be from a few things. This is basically a laser printer with a fax machine so the same problems exist in both. The most common cause by far is simply low toner. If you take out the toner cartidge and gentl shake it side to side then put it back in. Now try printing again. This should be much darker. This may only last a few dozen pages (but can go a quite a bit more if you are lucky) but it shows you that you need to get a new toner cartridge. The other causes can be a image setting in the fax. In the control panel it will show you a setting for how dark it will print. Normally it is in the middle of the range. The last common thing is a fusor wire. This normally shows up as a error first but it can slowly fail. The fusor is the heater that bonds the toner to the paper. If it doesn't get hot enough then not all the toner sticks and you get light printing.
Normally the problem is low toner.
Jan 10, 2012 | Panasonic KX-FL511 Plain Paper Laser Fax
Receiving fax has vertical lines on paper.
Are the fax from the different fax numbers or the same if the same may be there fax machine have them clean there scanner, if from varioue fax numbers then check your toner/drum unit and print out some internal reports such toner/drom order repkacement orders or one touch numers or meter read forms or make a copy if able to copy with this machine is line gone? Also check your fuser unit the hot part. also check your scan glass
Apr 24, 2010 | Office Equipment & Supplies
Can send faxes they can read fine but when i get faxes cant read them about a week ago paper jamed in the roller do i need to clean with what product
I assume you talking about a panasonic DP-190? Do not clean the drum you may gently wipe it down, realize the drum puts the image on the paper, nick it, grease from hands, ,etc will effect copy qualilty. Remove the toner cart. clean any toner spilled. Drum may need replacement, print a toner/drum resupply form to see if the machine prints them cleanly
May 08, 2009 | Office Equipment & Supplies
Brother copy machine 9160
There should be a blue slider on top of the cartridge, but it probably is a bad drum cleaning blade inside of the cartridge.
Dec 16, 2008 | Brother MFC-8220 Fax
Gray line down middle of faxes/copies on panafax uf880
yes change a toner and clean the glass area under nearth the toner.
Oct 24, 2008 | Panasonic Panafax UF-880 Plain Paper Laser...
Fax
You probably need new ink / drum / toner.
Oct 13, 2008 | Sharp UX B700 Plain Paper Inkjet Fax
Clear vertical lines when printing that do not clear up by shaking toner
does it do it on copies and internal test as well???
1- check the thin strip of glass inside the machine and make sure it is clean, look at the toner are there any line on there that corresponds?? yes then replace.it could be coming from the drum or toner. I beleive the drum is a seperate piece from the toner
Aug 27, 2008 | Panasonic KX-FL511 Plain Paper Laser Fax
Copy Quality
The CIS scanner has one of the LCD bits bad. If it is new, claim a warranty repair. Otherwise, strip the scanner out and go over all the solder joints
Feb 27, 2008 | Panasonic Panafax UF-490 Plain Paper Laser...
BLACK INK LINES ON INCOMING FAXES KX-FL511
It's time to change NEW DRUM UNIT..and that's why your Toner will Not Last Longer because unnecessary toner (the black lines) will be on the copy every time the fax comes or you make a copy.
Oct 01, 2007 | Panasonic KX-FL511 Plain Paper Laser Fax
Xerox WorkCentre Pro 555 Plain Paper Laser Fax Logo
55 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
