Question about Lexmark P6350 All-In-One InkJet Printer
Cant seem to get the printer to print documents
Hi can anyone help I have got a lexmark p6350 printer and can't seem to get to print any documents and keeps saying in the box place document in scanner to copy wondering how I set it up to print documents. thanks
    Scholar:
  • 35 Answers
The issue you are referring could be due to number of reasons, it could be due to the printer was not set as default in the operating system or it could be due to the printer driver corrupt, missing or not installed. It sounds funny is it, cause you said that it says to place a document in the scanner to copy, you must be wondering at this point of time that if the scanner is installed how come the printer is not installed as it is a multifunction printer, however let me tell you that it does happen sometimes, the printer driver gets corrupt or missing however the scanner works just fine, This is just because when you install the printer driver the printer driver and the scanner driver are installed separately even if it is a multifunction printer, So lets first try few steps to check and isolate the issue, here is what you need to perform
  1. Click start, point to printers and Faxes then click on it.
  2. Once the printer and fax page is displayed try and locate the printer icon.
Note: If you find the printer P 6350 icon on the screen it means the driver for the printer is installed, however you need to check if the icon has a check mark on it. If you observe that the printer icon is available but it does not have a check mark, it means that the printer is not set as default printing device, so all you need to do is to right click on the printer and then click on the option “ set this printer as default” to fix the issue. In case if you do not find the printer icon on the page then you need to reinstall the printer driver using the driver disk.
After you are done appropriate steps mentioned above accordingly, you can try to print a test page just to confirm that the issue is fixed, to print a test page right click on the printer icon and then click on properties, select the option “ print a test page at the bottom of the window.
If you need any further assistance please keep me posted.
Regards
Malik Khan
Posted on Jan 27, 2008
How do i get my lexmark 6350 connected to my laptop wireless
Although the Lexmark P6350 printer is not wireless capable, you can connect your device to a wireless print server so you can wirelessly connect your laptop and other computers that belong to the same network.
I hope this helps.
Mar 19, 2012 | Lexmark P6350 Printer
How do I make my lexmark p6350 compatible with my toshiba windows 7
Use the Vista driver in Windows 7. Before downloading the printer driver, check if your Windows 7 is running on 32-bit or 64-bit operating system. On your computer, go to Start menu > right-click on Computer > click on Properties. Take note of the System Type.
Use the link below to download the corresponding driver for your operating system:- Lexmark P6350 Driver for Microsoft Vista 32 bit and Windows 7 32-bit- Lexmark P6350 Driver for Microsoft Vista 32 bit and Windows 7 64-bit
Simply follow the steps on your computer screen to complete the installation.
Feb 27, 2012 | Lexmark P6350 All-In-One InkJet Printer
Error Code 1102 on Lexmark P6350 Printer
Hi, it seems that it's a cartridge problem. That's the most probable reason why you're getting that error code. Try this out.
1. Remove cartridges.
2. Unplug printer from power outlet.
3. Then, plug printer back in power outlet after 10-15 seconds.
4. Reinsert cartridges.
If error still appears, redo steps 1, 2 and 3. Then, insert black cartridge first. If error appears, replace black cartridge. If not, insert color cartridge, if error appears, replace color cartridge. Hope this helps.
Mar 08, 2010 | Lexmark P6350 All-In-One InkJet Printer
Install printer cartridge for Lexmark P6350
hi..
You may download the English version of the Lexmark P6350 user guide at the following link:
http://www.lexmark.com/publications/eng/6300/index.html
Apr 25, 2009 | Lexmark P6350 All-In-One InkJet Printer
LexMark P6350
go to---- lexmark solution center option ---- by clicking the ---printing preferances option ---- in that select the ---new cartridge installation option or change cartridge option---- in that option you select the proper number of your cartridge and it will ask whether it is new or old let the cartridge refilled or used or any you should always select the option new cartridges.then it will detect the cartridge and u will be able to print the colour from the cartridge.
Sep 24, 2008 | Lexmark P6350 All-In-One InkJet Printer
Fading cartridge problems
That printer is pretty old. Are you selecting "Best" quality when you print or is it possible that some documents are being printed in Quick Print mode (which puts less ink on the page)? If you're doing the same thing on each print job but the print quality changes, there's definitely a problem. If you're printing from web pages, the print quality may be a factor of the design of the pages. If you print two pages of a multi-page document and quality declines, you should be able to get help through Lexmark's technical support.
Apr 09, 2008 | Lexmark P6350 All-In-One InkJet Printer
LEXMARK P6350 All-In-One
Did you ensure you connected the usb cable and printer in order of the disc requesting you to do so.
Have you been to Lexmark site?
Have you enabled the printer in Printer settings as a default printer? It should normally do so when installed, but worth checking if you have other printing software on your comp
Regards Faggly
Mar 25, 2008 | Lexmark P6350 All-In-One InkJet Printer
INSTALL
You can download the software from Lexmark.
http://downloads.lexmark.com/cgi-perl/downloads.cgi?lxkprod=Lexmark+P6350
Just pick your operating system.
Feb 17, 2008 | Lexmark P6350 All-In-One InkJet Printer
Lexmark P6350 All-In-One InkJet Printer Logo
54 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
