Question about Compaq Presario 1200,1600, Series CD ROM(297657-001) (EP8RDA3G) Motherboard
Picture too large for screen
I have a Toshiba 50H13 HDTV manufactured Jan 04 with the following issues...1)picture is too for the screen i.e., tops of heads are cut off, bottom of picture is cut off 2)font size is too large 3)volume is still too low at it's max output Please help. Thanks! my picture is too large for my compaq laptop and how do you tighten the top to a laptop. I have to hold the top with my left hand while I type with my right
  • coyotebill1 Jan 26, 2008
    thescreen I was talking about was my laptop screen. How do I downsize the picture on my screen?
    Genius:
  • 1,067 Answers
Take zoom offf on dish and the tv it sel use normal 16 .9 ,mode when u push screen in to it use 1024x768 60 hertz ok
Posted on Jan 23, 2008
  • nick helpap
    nick helpap Jan 26, 2008
    got ya sorry ya right clik on desktop properties ok then go to settings in the disply settings set reslotuion 1024x768 or highter in 32 bit mode ok do this change your rating to fix ya
  • nick helpap
    tighten it by popeing off top panel under hindge cheak it out
I have a Toshiba 50hp66 that the power light cycles from red to green with a simultaneous clicking of a relay on the power board. I check for power at a few points per the Toshiba service manual and iy is...
Check the fuses on the ysus & zsus boards. Are any fuses on boards open . Disconect power cabels to ysus board first {board on left} . put tv on . if the light is green the ysus board must be replaced.
Mar 28, 2010 | Toshiba TheaterWide 50HP16 50 in. Plasma...
My picture shacks vary fast from side to side toshiba 42H83
You could have a bad color wheel or there is a Factory Service Bulletin from Toshiba that says: Remove the MVUP14 Hyper Module from the TV chassis, remove
the top shield and replace the 10uf, 16v capacitors using Part Number
24619040 as shown in Figure 1. It’s recommended that all of the
capacitors identified in Figure 1 be replaced. (Note: These capacitors are
low impedance surface mounted aluminum electrolytic capacitors. Care
should be taken to avoid damaging the PCB while replacing these
capacitors.) You should call a good TV Tech to do this repair.
Aug 02, 2009 | Toshiba 50H13 50" Rear Projection...
Our Toshiba HDTV
Greetings MDMSG,
I really do not have any further advice other than to possibly contact Toshiba and see if they have any information on this problem.
I wish I could be of more help!
Thank you,
Dorothy
Go Ahead. Use Us.
May 04, 2008 | Toshiba 42HL167 42 in. LCD Television
1/2 the screen is blurry
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Jan 15, 2008 | Toshiba 53HX71 53" Rear Projection...
Video has squigly lines in it at the top of screen ..
Small board called a hyper module bad .....can be rebuilt be
skilled tech or sent for rebuild..........................T.
Jan 10, 2008 | Toshiba 50H13 50" Rear Projection...
Toshiba - 50H13 Projection TV
There is a large metal case behind the input board in the back of the set called the hyper board that needs to be replaced.Good Luck
Oct 07, 2007 | Toshiba 42H83 42" Rear Projection...
Deteriorating picture quality at power up
It sounds like you need a hyper board for this. This part may not be available form Toshiba but I think I still have some in stock. You will likely have to have a technician insatll this for you.
I’m happy to help further over the phone at https://www.6ya.com/expert/dewayne_4a10eab6caecdb92
Aug 27, 2007 | Toshiba 50H13 50" Rear Projection...
If the television is connected to a cable box such as Time Warner's HD box, the picture mode can be changed by pressing the '#' on the cable box's remote keypad (where the channel numbers are). This cycles the picture between zoom, normal, and stretch which could be cause of your problem.
Aug 18, 2007 | Toshiba 50H13 50" Rear Projection...
Compaq Presario 1200,1600, Series CD ROM(297657-001) (EP8RDA3G) Motherboard Logo
195 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
