Remove the two screws that hold on the front panel. Unplug the wire that connects to the ignition light. Now look about low center for a small plastic cover held on by two screws. Remove the cover, all three wires noting which wire went where, and remove both ceramic probes. There is a paper thin gasket that tears easy so be very careful. Take a small green scrub pad and polish the ends of the probes. Take a pair of pliers and adjust the bull-horn probes a little closer. Reinstall and test fire. If it continues, you will need to have the gas pressure tested.
