Question about Microwave Ovens
Output of control transformer
Electronic control card main transformer has burned
  • Microwave Ovens Master
  • 9,176 Answers
We see this a lot. The problem is on the control panel, which we regularly repair nationwide for $39.95 postpaid.
If the transformer is indeed bad, it would probably run an additional $15-25.
Details of our service and critical safety information and disassembly information is at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
Posted on Jan 27, 2008
6ya staff
SOURCE:
My microwave has no power,I have checked all fuses, switches and thermostats, i've replace the main control pcb. still no lights or display
pwr comes in, goes thru fuse to transformer which powers pcb and mag. pcb is not getting pwr. chk ur installation and the output from the transformer
Jan 25, 2016 | Microwave Ovens
I have panasonic nn-gs597m microwave its working normal but not heating, I opened the cover magnetron is hot the fan is working. Any help?
follow the next steps , use the VOM and fix it. God bless you
Diode
The high voltage diode converts the A/C power output of the transformer to D/C, doubling the voltage to nearly 5,000 volts. This high voltage powers the magnetron which emits the energy that cooks the food. If the diode burns out, a lower A/C voltage reaches the magnetron, which is not sufficient to power the magnetron. When the diode fails it is often visibly burned out. If it appears to be good, it can be tested with a volt-Ohm meter capable of testing diodes. High voltage diodes frequently fail and are one of the most common points of failure in a microwave oven. A regular meter with a diode checker will not work to check these diodes. You have to use a meter with a 9 volt battery or put a 9 volt battery in series with the diode to check it.
Door Switch
If the microwave does not heat, one of the door switches might be defective. Microwave ovens normally have three door switches, if any of them fail the microwave does not turn on and does not heat. Check the switches for continuity with an Ohm meter.
Magnetron
If the microwave oven doesn't heat the magnetron tube might have burned out. The magnetron uses high voltage, high current DC power to generate the microwave frequency that cooks the food. If the microwave oven is turned on when it is empty this can cause the magnetron to burn out. Once it is burned out it has to be replaced, it's not repairable.
High Voltage Capacitor
If the microwave doesn't heat the high voltage capacitor might be defective. The high voltage capacitor works with the high voltage diode to convert the output of the transformer to DC voltage and to double the output voltage. If the capacitor is burned out the entire high voltage circuit stops working properly. The high voltage capacitor can be checked with a special VOM meter which has a capacitance testing capability. Be aware that the high voltage capacitor can retain a charge of more than 3,000 volts and can injure or kill a person if not handled properly. Only trained technicians should perform this type of testing.
High Voltage Transformer
If the microwave does not heat, the high voltage transformer might be burned out. Microwave ovens produce a very high voltage in order to power the magnetron antenna, which emits the energy that cooks the food. When a high voltage transformer fails it will usually arch and have a burning smell.
Thermal Fuse
If the microwave doesn't heat the thermal fuse may have blown. It can be tested for continuity. Watch our fuse testing video for more information.
Thermoprotector
If the microwave doesn't heat the thermoprotector may have tripped. This is a safety device to prevent the microwave from overheating. It can be tested for continuity to see if it's blown.
Main Control Board
If the microwave doesn't heat the main control board may be defective. This is not common. When a microwave doesn't heat the problem is usually a faulty door switch or within the high voltage circuit; either the high voltage capacitor, diode, transformer or magnetron.
Jun 16, 2013 | Microwave Ovens
Cook temp not working
follow this steps and test with VOM. God bless you
Diode
Enter your model number to see parts for your microwave.
Help me find my model number
Door Switch
Magnetron
Thermal Fuse
Thermoprotector
Main Control Board
Apr 02, 2013 | Maytag MMV4184A 1000 Watts Microwave Oven
Morphy richards oven is not heating and not cooking anything
please proceed according and fix it. God bless you
Diode
Door Switch
Magnetron
Thermal Fuse
Thermoprotector
Main Control Board
Mar 01, 2013 | Morphy Richards Microwave Ovens
Sharp convection microwave oven model R1875F. It's cooking on the left side faster then the rest of the oven. It seems to burn on the left side and not cook in the middle.
see the next causes. God bless you
Diode The high voltage diode converts the A/C power output of the transformer to D/C, doubling the voltage to nearly 5,000 volts. This high voltage powers the magnetron which emits the energy that cooks the food. If the diode burns out, a lower A/C voltage reaches the magnetron, which is not sufficient to power the magnetron. When the diode fails it is often visibly burned out. If it appears to be good, it can be tested with a volt-Ohm meter capable of testing diodes. High voltage diodes frequently fail and are one of the most common points of failure in a microwave oven.
Door Switch If the microwave does not heat, one of the door switches might be defective. Microwave ovens normally have three door switches, if any of them fail the microwave does not turn on and does not heat. Check the switches for continuity with an Ohm meter.
Magnetron If the microwave oven doesn't heat the magnetron tube might have burned out. The magnetron uses high voltage, high current DC power to generate the microwave frequency that cooks the food. If the microwave oven is turned on when it is empty this can cause the magnetron to burn out. Once it is burned out it has to be replaced, it's not repairable.
High Voltage Capacitor If the microwave doesn't heat the high voltage capacitor might be defective. The high voltage capacitor works with the high voltage diode to convert the output of the transformer to DC voltage and to double the output voltage. If the capacitor is burned out the entire high voltage circuit stops working properly. The high voltage capacitor can be checked with a special VOM meter which has a capacitance testing capability. Be aware that the high voltage capacitor can retain a charge of more than 3,000 volts and can injure or kill a person if not handled properly. Only trained technicians should perform this type of testing.
High Voltage Transformer If the microwave does not heat, the high voltage transformer might be burned out. Microwave ovens produce a very high voltage in order to power the magnetron antenna, which emits the energy that cooks the food.
Thermal Fuse If the microwave doesn't heat the thermal fuse may have blown. It can be tested for continuity. Watch our fuse testing video for more information.
Thermoprotector If the microwave doesn't heat the thermoprotector may have tripped. This is a safety device to prevent the microwave from overheating. It can be tested for continuity to see if it's blown.
Main Control Board If the microwave doesn't heat the main control board may be defective. This is not common. When a microwave doesn't heat the problem is usually within the high voltage circuit; either the high voltage capacitor, diode, transformer or magnetron.
Oct 03, 2012 | Sharp R-1870 Convection/Microwave Oven
Sharp micro doesn't heat
see this causes and fix it. God bless you
Oct 02, 2012 | Sharp Microwave Ovens
Maytag microwave problem everything seemingly works but does not heat. Help
Oct 01, 2012 | Maytag MMV4205 Microwave Oven
Limited heat power
It sounds like the transformer is shorting out on you but is not completely shorted.It will be shorting out on the output side of the transformer.this will give you a lower output level,and will cause the microwaves to be weaker.(less turns of wire in the secondary of the transformer).The short will probably get worse.Simply replacing the transformer should cure the microwave.
Jun 23, 2009 | Kenmore 63682 / 63684 / 63689 Microwave...
Seems like Power supply burned up
If the high voltage transformer is fried, the high voltage capacitor or clamp diode may be at least partially shorted (causes transformer overload). Usually this blows a fuse immediately to prevent a transformer burnout. Arcing in the oven waveguide or cavity, or a magnetron fault could also have been the cause. It would probably be a good idea to replace the magnetron controller relay also; it probably was overloaded.
Given the price of the replacement parts, your best bet would be to find a similar unit at an electronics recycling place and combine good parts to get a working oven. The keypad on your oven is worth something since keypad failure is common in that particular line.
Jul 03, 2017 | GE Spacemaker JVM1640SJ Microwave Oven
Brother put a foil wraped burger in micro now everything is dead
Hi, You may want to try to check/troubleshoot the PCB underneath the display/control panel. The mains do supply two circuitries: the heavy load and the electronics. In some units, they have a standard transformer while in others an SMPS that supplies the +5 (and sometimes +12 or higher) voltage. This powers the electronics which includes a microcontroller, timer, relay drivers and display panel. Trace the transformer/SMPS and look for any fusible link, secondary fuse or surface mounted fuse. More often than not, there are also standard components along the way like bride diode, diode, filter capacitor and regulator IC. Check for VDC input and output of power components. Hope this gives you an idea, Pls post again how things turn up or if you need further information. Good luck and kind regards.
Aug 11, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave Ovens Logo
Top Microwave Ovens Experts
William Miller
William Miller
Marvin
Marvin
Are you a Microwave Oven Expert? Answer questions, earn points and help others
