Question about Epson ACULASER CX11NF All-In-One Printer
Epson AccuLaser CX11NF
Prints fine
Fax works fine
Won't copy
Have unplugged, restarted, re-installed drivers.
"Data" light flashes and simply keeps on flashing
  • Anonymous Mar 06, 2008
    My problem is basically the same, the data light flashes and flashes but that's all it does. It won't even cancel, I have to turn it off, then back on.
  • fujimo208 Mar 09, 2008
    i cant get mine to even install i run windows xp it tell me to check connection there all fine any help
I had this problem. Try unplugging any usb connection to the computer, turn off, then turn on and then try a stand alone copy. It was my USB connection to the computer which had locked up the copier.
After this it was fine.
Posted on Nov 07, 2008
  • Epson Master
  • 1,879 Answers
DO you mean that it will not even do a STANDALONE (no computer or network attached to it) FUNCTION such as COPY ?
more nfo please -
Standalone (nothing connected) status : (status lights, does it feed paper manually, can it perform a SELF-TEST)
OS :
Connectivity :
Status Lights on the unit :
Error message if any on the unit :
Posted on Jun 16, 2008
I have got an Epson cx11n and have tried to install this. I have no instructions and cant seem to get it to work. I have tried to install a new driver but this has not helped either. I have connected a...
Try unplugging the printer, uninsta the drivers for the printer (from device manager), restarting the PC then installing the drivers (obtained from Epson web site). At some stage, the software will tell you to plug in your printer and turn it on. If it doesn't, plug in the printer after the driver install has completed. Good luck.
Regards
Zahc
May 07, 2010 | Epson ACULASER CX11NF All-In-One Printer
Epson Acculaser CX11NF Error 'Service Req E527'
Hi.. To fix the E527 error, close the front panel (cover A) and open the top cover (cover B). With the photoconductor unit removed, the toner carousel will rotate. It only rotates if cover A is closed all the way. You can easily rotate the carousel to a position where you can remove/reinstall the toner cartridge if stuck.
Thanks
jim report_dis_text_13954 = 'We\'re sorry but you must be signed in to report inappropriate material. Click the button below to sign in or register.
  • Sign In / Register »
  • Cancel »
Feb 18, 2009 | Epson ACULASER CX11NF All-In-One Printer
ACULASER CX11NF Photoconductor reset - chip?
The reset chip will not provide you with a long term solution to your problem. The photoconductor unit is now full of waste toner and the photoconductive drum, prime charge roller and wiper blade are all worn, this is the cause of the message. Your only real and the correct solution is to replace the Photoconductor unit with a new one. Remember that this is part of the consumable set for this printer and is therefor costed in as part of the cost per page.
Should you proceed with the replacement chip, you will be opening yourself to deminishing quality print and eventual failure of the unit.
Gremlin11
Jul 24, 2008 | Epson ACULASER CX11NF All-In-One Printer
Communication error
Marky12, if the printer works fine on the vista system then you can eliminate a hardware fault. sounds like a driver or install issue. remove the printer completely from the mac (uninstall software, drivers and unplug) then go to epson.com, choose your countrey and head to the support and downloads section. Get the latest drivers for mac/tiger and reinstall the printer (make sure you have restarted the mac in between uninstall and reinstall) and most important !!! dont plug in the usb cord until the driver install tells you to
Good luck
Feb 28, 2008 | Office Equipment & Supplies
Epson ACULASER CX11NF incoming fax problem
Try this:
Unplug line from back of printer
Set the Incoming mode to autoswitching
set DRPD to Off so that it will recognize all incoming calls
** if possible call your telephone company and set a distinctive ring pattern for phone calls
replug cable on line port at the back of printer
then ask someone to send you a fax...
Feb 05, 2008 | Epson ACULASER CX11NF All-In-One Printer
Scanner Not Recognized
You need to remove the yellow question mark on the device manager. Click on the plus sign of the Question mark icon. Right click on the item that will be displayed under the question mark and then uninstall. You need to uninstall the drivers as well. you can doo it on add/remove programs(winxp) or program features (vista). Unplug the USb cable/ Download drivers from support.epson.com and you just need to choose the right driver for your windows version. After Installing the TWAIN driver and Epson scan utility, you need to restart computer. When computer is ready you can plug in the usb cable and open up Epson Scan on your desktop
Jan 28, 2008 | Epson Stylus CX5000 InkJet Photo Printer
Epson ACULASER CX11NF All-In-One Printer Logo
149 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
