Question about Kenmore Elite 22.4 cu. ft. Bottom Freezer Refrigerator with Adjusta Cube Ice Maker
Interior Water dispenser not working
I have the Stainless Steel Trio which I purchased in 2/07. I love it!
The water dispenser which was not used often stopped working. I can hear it trying to dispense by the hum when I push the button. I just changed the filter hoping it would be that easy. No luck.
The ice maker is working fine.
Same as described. Water filter blue bypass cap has been tried although filter replacement not indicated on advanced temperature control. Supply plumbing and water pressure specs have been checked. No saddle valve used. It appears that (sounds like) no water is getting past the filter head. Temp is set @ 39* .
  • 1 more comment
  • Ron Nagy Jan 24, 2008
    Depressed button for 2 plus mins.There is no audible indication of air being bled from the tank.There is an audible hum in the area of the filter while the button is depressed but no water.Have raised temp to 43* in case tank or line is frozen.
  • Ron Nagy Jan 25, 2008
    Follow up - I raised the temp earlier today. Double-checked interior temperature with a thermometer (actual temp was 3 degrees colder than showing on panel). It took almost 9 hours but obvious that the unit was frozen somewhere inside as now water is coming out.
    Thanks for the tip Master_Tech, but I'm glad that was not the problem.
  • 770 Answers
If you have not yet used it you will need to bleed the air out of the tank in the refrigerator hold the button in for a few mins to flush this out
Posted on Jan 24, 2008
  • Gary Davd
    Gary Davd Jan 24, 2008
    your water inlet valve is most likely bad
  • Gary Davd
    Gary Davd Jan 25, 2008
    Just an FYI there is a tank in refrigerator section on the back wall usally behind the drwers this hold about 1.5 gal of wter to make it cold coming out of the dispenser this is the most likely place it was freezing up
From the water filter, where does the water tubing connect to?
Some have a connection behind kickplate at bottom front.
Oct 08, 2017 | Whirlpool Refrigerators
Whirlpool refridgerator side by side is leaking water on the side. We do not know where it is leaking from
Often water leaks result in stains on the Stainless Steel, use DeBruce Polish for removal. Using DeBruce Polish on all your stainless steel will allow you to now perform JUST TOUCH UPS of finger printing and remove the need for "OILS" that manufacturers provide for cosmetic care of blending. Stainless IS A GREAT FINISH TO CARE FOR one just needs the right product. Once cleaned with DeBruce Polish there exists no oil or other "films" to BLEND. DeBruce Polish will now perform touch ups instantly. LOVE YOUR STAINLESS STEEL AGAIN! Get DeBruce Polish at debrucepolish.com NON-TOXIC AN ODORLESS ...PERFECT
Jan 06, 2014 | Whirlpool 25.6 cu. ft. Side-by-Side...
Water dispenser not working on kenmore trio refrigerator
The tubing inside the door is most likely frozen. Mine did that a year ago. I had to remove gasket and loosen screws around edge and allow to defrost inside door. There was a lot of ice around dispenser and tubing.
Sep 16, 2012 | Kenmore TRIO® 77553 Stainless Steel Bottom...
White film on dishes and interior
White streaking is caused by too much rinse agent. (jet dry) Most all dishwashers now have adjustable rinse agent dispensers, so you can set them to a lower setting when you have soft water, and a higher setting if you have harder water. The adjustment is generally right where you add the jet dry. Other possiblilities would be a leaking jet dry cap, or a defective jet dry dispenser.
Apr 16, 2010 | Jenn-Air 24 in. JDB1090AWS Stainless Steel...
1 year old Kenmore Elite Trio Refridgerator not cooling
There are a lot of things that could be the source of the problem... is there no cooling at all going on in the freezer? Is the back wall of the freezer cold? It could be anything from a fan, to the compressor, to the control board... you need a technician.
I would get on the phone with Sears, and explain the continuing problems you have been having, and they may agree to cover service.
Jul 26, 2009 | Kenmore 73503 Stainless Steel Bottom...
Internal water dispenser stopped working
I lowered the temp on the freezer to 4 overnight, by morning water dispenser is working fine. I think that when we changed the temp to 7 (in order to make more ice ) it froze the water pipe going to the dispenser. I am going to keep both fridge and freezer at 5 ,and hope this will not happen again.
Dec 31, 2008 | Amana AFD2535FES Stainless Steel Bottom...
Spots on freezer door
Use a product like lime-away may help. These water spots are caused from calcium buildup. Lime-away or similar product will dissolve the calcium. Then use the stainless cleaner on it.
May 28, 2008 | GE Profile PSW26P Stainless Steel Side by...
I just had the same problem and symptoms. And it was reading your thread that put me on the right track. I put a thermometer inside and found that the temp was about 3 degrees colder than shown on the panel. I figured the line may be frozen in some area and turned the temp up 5 degrees. After about 10 hours I tried the dispenser and now am getting water out again. Maybe this will work for you - it was at least free!
Jan 12, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Kenmore Elite 22.4 cu. ft. Bottom Freezer Refrigerator with Adjusta Cube Ice Maker Logo
232 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
