Question about Ensoniq (6000708) Sound Card
Audio device not found
My audio device is not found, thats what is says under sound and audio device under control panel. I have an MSI motherboard.
    Genius:
  • 1,226 Answers
Is the sound device is built in to mainboard? if yes the you can download the driver of your audio here:
http://global.msi.com.tw/index.php?func=downloadindex
just input necessary data for the download.
Posted on Jan 24, 2008
I have no sound , i am useing onboard sound on the msi p4m900m3 mainboard
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
if his does not fix the problem
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar for any further volume control settings you will need to right click on the volume icon system select adjust volume
click start control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speaker plug/outlets is usually at the back of the computer or if it
Sep 30, 2011 | MSI P4M900M3-L Motherboard
Hi im using ms-7312 ver.1.0 motherboard newly formatted by sound is not coming pls help me
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers or uninstall
also
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
make sure you have an earth ******** before touching any parts inside your computer
hope this helps
May 29, 2011 | MSI K9MM-V Motherboard
Sound device not found in my system
also
hope this helps
don
Mar 02, 2011 | MSI 945GZM3-L (7267-020(945GZM3-L))...
No audio output device is installed
you might have to get a portable usb sound card if you mean dont have a sound card installed or
control panel sounds and audio,volume,advanced,speakers select appropriate speakers or audio you will find 3 drop down lists make sure you have selected the right speakers or
control panel,administrive tools,computer management,device manager,sound,could be a yellow question mark? right click to re-install drivers
hope this helps
Nov 02, 2010 | MSI 845GVM-L (MS-6714-040) Motherboard
Audio
if you mean no sound
control panel sounds and audio,volume,advanced,speakers select appropriate speakers or audio you will find 3 drop down lists make sure you have selected the right speakers or control panel,administrive tools,computer management,device manager,sound,could be a yellow question mark? right click to re-install drivers
hope this helps
Oct 25, 2010 | MSI PM8M3-V (7211010VPM8M3V) Motherboard
No sound
control panel sounds and audio,volume,advanced,speakers select appropriate speakers or audio you will find 3 drop down lists make the necessary adjustments there or control panel,administrive tools,computer management,device manager,sound,could be a yellow question mark? right click to re-install drivers
hope this helps
Oct 01, 2010 | MSI K9N6SGM-V (7309-020(K9N6SGM-V))...
My sound drive is gone, so now i want to install sound drive again. what should i do? its a v-class series
control panel sounds and audio,audio make necessary adjustments there or control panel,administrive tools,computer management,device manager,sound,could be a yellow question mark? right click to re-install drivers
good luck
Sep 07, 2010 | MSI K8MM-V Motherboard
HELLOO SIR I HAVE INSTALLED THE SOUND DRIVER OF MY MSI MS-6380E EVERYTHING SEEMS TO BE OK BUT NO SOUND. thanks <a href=http://www.ddl.name/ >backup...
click my computer then control panel click performance and maintenance click system then click hardware click device manager then click sound video and game controller if there no question mark your software is installed so go back to control panel click sound,speech and audio device then click where you want to adjust
Aug 19, 2010 | MSI MS-6380E (MS-6380E-010) Motherboard
Sound driver installed but no sound
start->control panel->sound speech & audio devices->sound and audio. Now make sure your audio device is present under the Audio tab in the Audio Playback. Also make sure you are not muted.
Jun 04, 2009 | MSI P4MAM-V (MS6787060) Motherboard
Ensoniq (6000708) Sound Card Logo
157 people viewed this question
Top Ensoniq Computers & Internet Experts
David Payne
David Payne
Are you an Ensoniq Computer and Internet Expert? Answer questions, earn points and help others
