Question about Rockford Fosgate Punch P5002 Car Audio Amplifier
Rockford p5002 amp is smoking...
Im not sure what is wrong here, my car sat for a couple days, i came back and drove it, the system wasnt working. I just checked yesterday and sure enough, the fuse was blown on the amp. So i put in a new fuse but stupid me, i didnt think to unhook the amp from the battery before putting in a new fuse....i saw some sparks and heard a "pop", i pulled the fuse out real quick...i though i fried my amp. I unhooked it from the battery and put the fuse in, turned everything on and it works, it pushes the 12" sub that im running right now, the other one is blown so its not hooked up. What its doing now is smoking and smelling like burnt something. I have it all turned off untill i figure out what to do, im pretty good with electronics so if this is a simple fix, i can most likely do it. thanks for any help. -Devon
    Problem Solver:
  • 37 Answers
If you know how to use a multimeter check your output ic's and see if you have blown one of them you will have to see if they are PNP or NPN which is positive negitive positive or neg pos neg
Posted on Oct 22, 2011
  • 631 Answers
Completely disconnect the amp and remove the cover. Look for anything that is discolored or burned.
Did you have one sub on each channel before the sub blew?
Posted on Jan 25, 2008
I have a old 2001 rockford fosgate 2 channel p5002 model in great condition just need to know how many watts is it and which subwoofers are compatible to this amp? thanks
Your amp is rated at 500 watts. Here is the break down of your wattage.
125x2 at 4 ohms
250x2 at 2 ohms
500x1 at bridged 4 ohms
When hooking up the amp make sure to use 4 gauge power and ground wire.
Jan 07, 2011 | Rockford Fosgate Punch P5002 Car Audio...
Rockford fosgate p5002 amp keeps blowing fuses as soon as i turn it on.
make sure your power hasnt found its way in the the ground and vice versa
Apr 02, 2010 | Rockford Fosgate Punch P5002 Car Audio...
Rockford P5002 amp problem with thermal light and low voltage
Hello rbenwalker,
The voltage drop may not be in the actual power wire itself. The same reading on both the B+ and remote terminal probably points to a bad or high resistance ground. Try a different ground point or make sure there isn't any corrosion, paint or anything else preventing metal to metal contact.
Hope this helps.
Sep 12, 2009 | Rockford Fosgate Punch P5002 Car Audio...
I need to find output transistors for a Rockford amp
Call rockfor fosgate and ask if they sell component parts to public, if not, ask who the their component manufacturer is, maybe you can get it directly from them.
Sep 03, 2009 | Rockford Fosgate Punch P5002 Car Audio...
Amp fuses blowing and amp overheat
Does the amp heat up if you power it up with no speaker wires connected to the amplifier's speaker terminals?
Jul 17, 2009 | Rockford Fosgate Punch P5002 Car Audio...
I think my ex blew my amp
model number? im thinking 401s? if so that should be the only light on
Aug 07, 2008 | Rockford Fosgate Punch P5002 Car Audio...
Not working
maybe you should use 4 awg wire
Jun 24, 2008 | Rockford Fosgate Punch P5002 Car Audio...
Where to take my amp for repair
Contact Rockford for factory service.
If you don't want to send it to Rockford, ask the local audio shops who they use for amp repairs. If several use the same repair shop, it's probably a good place to send your amp.
May 25, 2008 | Rockford Fosgate Punch 500a2 Car Audio...
Amp problem on a bmw 3 serie
you have a ground loop problem that whining is called radiated engine noise.
Sep 30, 2007 | Rockford Fosgate Punch 800a2 Car Audio...
Rockford Fosgate Punch P5002 Car Audio Amplifier Logo
170 people viewed this question
Top Rockford Fosgate Car Audio & Video Experts
seankane89
Level 1 Expert
hoyzee1
Tygh Duval
Tygh Duval
Are you a Rockford Fosgate Car Audio and Video Expert? Answer questions, earn points and help others
