Question about Avaya 700340193 Corded Phone
Need programing manual
Can anyone help me with a programing manula for an Avaya ASC Rev 5.0
  • ronbonan Mar 17, 2009
    programming 'do not disturb' for a phone.
Because you have indicated that you have an, "ASC" rev. 5. WHen you actually have a Partner ACS, R5.
Here is the link to the manual site on AVAYA.COM.
http://support.avaya.com/japple/css/japple?PAGE=ProductArea&temp.productID=107628&temp.releaseID=143469
Posted on May 12, 2008
Why does everything have to be so difficult with this Avaya phones. I need help and I can't get it anywhere!
Posted on Apr 04, 2008
    Scholar:
  • 157 Answers
I have not been able to locate this exact product on Avaya's support website based on the information you have given....however, here is a link to their support site for telephony, I,m sure you will find it useful :
http://esearch.avaya.com/r/results.asp?queryText=corded+phones&SITE=red&Go.x=6&Go.y=4
Posted on Jan 23, 2008
6ya staff
SOURCE:
I am a new customer service rep and cannot login to the company communication server using Avaya IP Agent R7. I have downloaded and tried to install/uninstall/reinstall the program several times. When I...
Try to login manually from the avaya not from the computer. it will log you in. but you might also need to check with your CCO (call center operation desk) and which software you are using to log in and check if you have an outside access, if its still not working submit a trouble ticket at your company's website. reinstalltion the application will not work if the access is not there. avaya are very safe phones and i am also using the avaya 4620sw ip phone. it happens sometimes when you login using the softphone but try to login using the hard phone. it should log you in, but will it solve the purpose. you need to check. All the best.
Sep 25, 2009 | Avaya 4610SW IP Phone
Remotely program my avaya 8
You will need a remote access/backup restore card (silver card) Then you will need the remote admin software available for free at Avaya.com
Aug 16, 2009 | Avaya Corded Phone avaparp18d
ASC & ABS light on cluster
Check to see if your brake pads and rotors are in good condition. Or if you have replaced the pads yourself and have not reset the wheel sensors this would cause the ABS Antilock Brake System light and the ASC Automatic Stability Control light to stay on as the ASC uses the ABS brakes with computer assistance to control the traction of the car if not fixed it can effect your rev limiter slowing performance
Jul 09, 2009 | 1999 BMW 318 ti
I have 1998 bmw 528i, the problem is when the ASC light come on, the automatic transmission won't go into gear. and this only happen in low gears
Check to see if your brake pads and rotors are in good condition. Or if you have replaced the pads yourself and have not reset the wheel sensors this would cause the ABS Antilock Brake System light and the ASC Automatic Stability Control light to stay on as the ASC uses the ABS brakes with computer assistance to control the traction of the car if not fixed it can affect your rev limiter and slow performance
Jul 09, 2009 | 1998 BMW 5 Series
My ASC+T Indicator Lamp lights and car can't move...
When your ASC light is on this is to let you know your Automatic Stability Control system is switched off press the ASC button Till light is off /ASC is on this works with your rev limiter and should stabilized your idle. If the problem persists have your throttle control unit checked as this can trigger the ASC light as well and may also activate the ABS light if not fixed
Jun 06, 2009 | 1996 BMW 3 Series
My car is bmw 525i 2000 model asc sensor alwayes on after i change abs box
if you changed the asc module, the module has to be programmed/coded after replacement. If it was a new part there should be no problem programming the new control unit. I would recommend taking the vehicle to the dealership to allow them to program the control unit.If you have access to the programming don't forget to take the asc module out of "end of belt line mode" and most likely the steering angle sensor will have to be aligned
Apr 22, 2009 | 2001 BMW 5 Series
Programming Page Button
You could look in the station user's guide and program paging. This may work, or not, if you're paging internal and outside do this:
From your phone press Feature 00 the button and then Intercom *70.
If you don't want all the idle phones in group 1, but just the outside speaker, press 70 alone.
I'm not positive, but you may have to delete the button in centralized programming if it is already assigned a "CO" line.
Centralized programming is done from extension 10 or 11 and involves the system manual and knowing where the overlay buttons are.
Post back if you need a basic Partner ACS manual or try www.avaya.com for system manuals.
Carl
Feb 20, 2009 | Avaya Corded Phone avaparp18d
Asc light comes on and engine cuts out
When your ASC light is on this is to let you know your Automatic Stability Control system is switched off press the ASC button Till light is off /ASC is on this works with your rev limiter and should stabilized your idle. If the problem persists have your throttle control unit checked as thi can trigger the ASC light as well and may also activate the ABS light if not fixed
Nov 11, 2008 | 1997 BMW 318
Euro style 18d how to program memory keys
The Avaya website (www.avaya.com) is loaded with manuals, you just have to know where to look.. Here's one http://support.avaya.com/elmodocs2/partner_acs/r7/518457701_2.pdf
Page 13 tells you how to program a button (ie FEAT 00 button dial the number and press FEAT 00 again to exit). Page 16 tells you how to program personal speed dial number from the 20 bins 80-99 allotted to your phone.
Carl
Nov 11, 2008 | Lucent PARTNER18 Corded Phone
Avaya 700340193 Corded Phone Logo
495 people viewed this question
Top Avaya Lands Phones Experts
martin hogg
Ekse
Are you an Avaya Lands Phone Expert? Answer questions, earn points and help others
