Question about Toshiba Satellite A105-S4004 Notebook
Toshiba Satellite L25-S119 White Display Screen
I was in the process of upgrading the RAM and realized I had the wrong size. I receeded the existing RAM and went to power the system and now have a white display screen. The hard drive is spinning and I can tell it is going through the normal boot process but I continue to have the white screen. The memory is in correctly and the only thing else I did was blow the fan out with compressed air. I even went as far as to disassemble the laptop and check to make sure the video connection had not come loose from the motherboard. PLEASE HELP!
Thank you in adavance.
  • 1 more comment
  • Acwade84 Jan 23, 2008
    It did work hooked up to a monitor... I took the screen apart and found the LCD cable has a broken wire. Now, the problem is where to find a replacement.... the model number is : DDOEW3LC106.
  • Acwade84 Jan 26, 2008
    I got a replacement LCD cable, but still have a white screen. Everything is seated properly and nothing is bent. Since the laptop works hooked to an external monitor, is it just a bad LCD screen?
  • jannjer Oct 18, 2008
    I have a L25-S119 toshiba sattelite laptop. The screen would just stay off, Black on startup. An external monitor would work. So I replaced the screen and now it just boots up white, or if I try and reboot is stays black. I'm trying to isolate what is the real problem.
    Thanks,
    Jerry
    Scholar:
  • 181 Answers
First, hook up the laptop to an external monitor. Turn it on and try to get into the bios.
How compressed was the air you used to blow out the heatsink, and when you blew it out, did you have it unplugged and the battery removed? When you spin the heat sink fan, it creates current, like a little generator.
I gotta tell you, just removing memory won't cause the problem you're describing.
I've had several Toshibas with lcd issues, mostly caused by the onboard video modules on the motherboard getting hot.
Good luck.
If you can get video to an external monitor, let me know.
Thanks
Posted on Jan 23, 2008
Free download audio driver toshiba satellite L25 - S119 for window xp
are you haven issues installing the audio drivers or you can't find drivers for it?
Aug 11, 2012 | Toshiba Satellite L25-S119 Notebook
My toshiba satellite l25-s119 turns on but the screen is blank?
If your laptop appears to boot up and the hard disk LEDflashes, then the problem is probably a back light fault. This can be a faultyinverter or a faulty CCFL lamp. Please click on this link and follow myinstructions to identify the fault and possible fix :- http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
May 27, 2011 | Toshiba Satellite L25-S119 Notebook
I Want The Drivers of my Laptop. Details are as follows... (Toshiba Satellite L25-S119)
The Toshiba web site has all you need.
Just enter your model number and follow the prompts. The web site can even get all the information from your Satellite for you if you are not sure.
Click here.
Oct 23, 2010 | Toshiba Satellite L25-S119 Notebook
Toshiba Satellite L25-S119 laptop-No image on screen but the fan powers up when the power is turned on. The Power button illuminates then turns off but the fan continues to run.
well your leaving a lot to the imagination..is the hard drive light working..plug it into a external monitor then boot it..then we can go from there..
Feb 18, 2010 | Toshiba Satellite L25-S119 Notebook
Toshiba Satellite L5-S119 PC , my screen turned red how to recover the original screen
the video card might have been damaged. If that's the case, a replacement should be done.
Nov 21, 2009 | Toshiba Satellite L25-S119 Notebook
Wifi drivers for L25 - s119
Please use this link:
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=DL&os=&category=&moid=1124512&rpn=PSL2XU&modelFilter=L25-S119&selCategory=3&selFamily=1073768663
Jul 12, 2009 | Toshiba Satellite L25-S119 Notebook
Who knows which driver(sound and PCI Modem)needs toshiba L25 S119?
Toshiba Support, Toshiba Satellite L25-S119, driver download page,
Date: 09-20-2005 Driver Modem
To the right of this is in blue, is -> Conexant Software Modem Driver for Windows XP (v725.00.00r2; 09-20-2005; 1M)
Click on this for the PCI Modem driver.
Date: 09-20-2005 Driver Sound
To the right of this in blue, is -> Conexant Audio Driver for Windows XP (v6.14.10.6553 r2; 09-23-2005; 711K)
Click on this for the Sound driver.
Apr 20, 2009 | Toshiba Satellite L25-S119 Notebook
Satlite l25-s119 i need all drivers for the above model laptop
Hi!
Here you can find all the windows drivers:
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=SB&os=&category=&moid=1124512&rpn=PSL2XU&modelFilter=L25-S119&selCategory=3&selFamily=1073768663&selModel=1124512|PSL2XU
Jan 19, 2009 | Toshiba Satellite L25-S119 Notebook
Restore factory settings
You need the disk to do so. Else you format hard drive install New Os download drivers from Website. ( Before this see the modem type display card drivers lan card drivers Etc.)
Regards rafique
Mar 04, 2008 | Toshiba Satellite L25-S119 Notebook
Open Questions:
See all Toshiba Satellite A105-S4004 Notebook Questions
Toshiba Satellite A105-S4004 Notebook Logo
446 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
