Question about Philips Magnavox 51MP392H Rear Projection Television
Streaks between the two screens .help
Can I remove the screens on my tv and clean between without hurting anything
    President:
  • 4,402 Answers
TV: Viewing Screen RPTV - damage and maintenance
http://www.hdtvmagazine.com/forum/viewtopic.php?t=6547
Posted on Jan 23, 2008
Cleaning
If water have entered inside the panel, you have to disassemble the set's panel to wipe it out. Normally, there is no possibility to enter water into the panel. Anyway, it will be best to contact any service technician. Disasembling panel is a skilled work.
May 23, 2013 | LG 42 42LK450 42 LCD TV
Appropriate Cleaning
This problem has been answered a few ahile ago.
May 23, 2013 | LG Televison & Video
What is the best way to clean a 46" LCD Toshiba TV
You do not want to use any harsh chemical or anything in excess. What I use and recommend is simply water and dish soap such as ivory. Use clean lint free paper towels or cotton or soft fabrics. You put a drop or two of detergent on a damp towel.You gently wash the screen then wipe it dry. The towel needs to be damp but not enough so that you get any running water.You may need to do it in small sections. If you use too much soap you get streaks. If that happens just get another damp piece without soap and go over and then use the dry to wipe the screen dry. The soap takes off anything without harming the anti-glare coatings on the screens. The wrong type of alcohol or a harsh cleaner can strip these coatings off or damage the plastics. Dish soap and water is very safe dirt cheap and found in the kitchen usually. ;-]
Sep 02, 2011 | Toshiba 46SL417U LCD TV
I accidentally cleaned my samsung led monitor with windex. there are streaks all over the monitor. i used a soft cloth to try and clean off the streaks and it did not work. Is there anything I can do to...
Hello mrm552,
The best possible case is to use to a proper tv screen cleaner, ex. monster screen cleaner. The solution comes with a cloth. Spray the cloth with the solution first with one or two sprays. Then in a circular motion wipe the screen. You can get this solution at most electronic stores where they sell TV's. Hope this helps, good luck.
- Joe
Aug 28, 2011 | Samsung Televison & Video
I used a soap/water solution to clean my plasma screen but used a regular cloth instead of microfiber and now there are horrible streaks on the tv that won't go away. Help! Is there anything I can do?
You can try to use a harsher cleaner like lysol but sometimes the streaks are permanent. The screen is glass but some tvs have a glare reduction layer that can be destroyed with harsh cleaners (like lysol). Your soap cleaning shouldn't have damaged it.. I would try just water and see if the streaks change. If they keep changing as you clean, its probably some scummy residue, but if they apprear to be permanent, then it could be damage. I always recommend the store bought plasma cleaner with the microfiber cloth, but if you smoke or have a really dirty tv, sometimes you have to cut it with lysol or something. Clean at your own risk, as anything not made to clean the tv can sometimes cause damage. I've seen paper towels scratch the glossy frames sometimes even.. good luck
Jun 11, 2010 | Panasonic Viera TH-50PX80U Plasma TV
Clean behind screen
I have a 42 inch screen and have cleaned it myself. It takes quite a bit of contortionist positions but can be done. Remove the back panel and have a microfiber cloth handy. get some invisible glass glass cleaner.....It has no soap so it cleans well. Spray the cloth lightly and the rest is reach and wipe...It does take a long time. You can also clean the lenses.GENTLY.... If you have streaks after turning it on you have to keep working on it. I couldnt come out of the process without some streaks. Its just too hard to reach the whole darn screen..I hope this helps ya out
Nov 25, 2007 | Sony KP-53HS30 53" Rear Projection...
Streaking inside of screen
Philips screens tend to be very tough to remove as if you are not careful on removal of the screen frame bolts then the whole screen will come falling off.
Mar 19, 2007 | Philips 44PL9523 44 in. Rear Projection...
Philips Magnavox 51MP392H Rear Projection Television Logo
77 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
