Question about iLO DVD Recorder DVDR05
Hooking up i can not get the recorder to hook up right for recording how am i supposed to hook it up
Depends what you're trying to hookup. TV? take coax from tv out to INPUT on back of ilo, setup tuner(selected in source). From VHS? hook up a vcr to another one of the inputs, A/V one the unit. Even the ones on the front will do. Then after going into the record menu and setting up the length/quality settings, then select source to select which input you want to record from and hit record. Try to end it before your alotted time expires and forget about programming it to record something automatically via the time, It never works well, if at all for me. Best bet is +RW's depending on unit. Mine is MU unit and Sony +R's work good for me.
Posted on May 28, 2008
Unable to read dvd/cd
I have put dvd from best buy and the one i made but unable to make it work last day it worked was when i recorded micheal jackson i no it work i dont now what i did to it to stop it the cable are they supposed to be hooked to the front of the tv and on the back and do the cable from the wall go into the
dvdr are the tv i think i dont have it hooked up right so how do i do that also
thanks
Oct 18, 2009 | Cyberhome DVR 1600 DVD Recorder
How do I hook up my vcr to my dvd recorder so I
You will need one RCA video cable it will have a yellow, red and white plugs. On the back of your VCR locate where the color inputs are find where it says VIDEO OUT hook it up there. On the back of the DVD Recorder look for the same color input jacks NOW find where it says VIDEO IN hook it up there. You may have to turn on your TV,DVD recorder and VCR to get the right channel. your Recorder may have one or more video inputs if it does turn on all three. Use the channel on your TV you use to watch DVDs make sure you see your DVD screen. Now to record to a DVD. Change the channel on the DVD Recorder. Look for the input channels It may be Video 1 Video 2 etc... depends on the inputs you have. ( A great way to tune your DVD Recorder is to play a prerorded VCR tape. Turn the channel on your DVD Recorder unil you see the prereorded tape playing. )
Jul 21, 2009 | Toshiba Audio Players & Recorders
Need help DP-01 basic hook up to synthesizer
Midi on the DP-01 is only for time synching with another device, synth, etc. To hear your synth through the DP-01 run a 1/4" patch cord from the audio outs (R and L) on your synth into the A and B inputs of your DP-01. Then assign the inputs to tracks and arm them for recording. You should then be able to hear your synth playing out of whatever you are using to monitor you DP-01 (headphones, stereo or powered monitors). To record the synth output simply press play and record together on the tascam.
bd.
Feb 21, 2009 | Tascam DP01 All-In-One Recording Package...
I'm simply looking for the most efficient way to hook up my HD-TV with HDMI inputs to both my cable box (with HDMI inputs) and my DVD player/recorder so that I can record from the TV I watch.  ...
The way you have it hooked up right now will not work unless you have a coaxial out on your cable box going to the dvd recorder. Even then, picture quality will be severely degraded. The best way to do it is to leave your cable box hooked up to your TV via HDMI and connect your dvd recorder to your cable box via component video if your dvd recorder has a component video input. If it doesn't, then just use the composite video input. That way your picture quality will be better and you will still be able to record with the TV off.
Jan 02, 2009 | Insignia 37" LCD Flat-Panel HDTV
JVC DCD Recorder hookup to digital TV
Yep, this recorder is NTSC analog. Sad, too - it was only manufactured in 2006 - they knew about the digital transition then. There is a possible workaround, but it depends on your TV - if your TV has a red, white AND (most importantly) yellow OUT/OUTPUT, then you can hook it to the AV IN on the back of the JVC and record from TV that way. Note: most TV's (even new ones) do not have the yellow video/monitor OUT, even if they have red and white audio OUT's.
-Tha Mp3 Doctor
Sep 03, 2008 | JVC DR-MV7 DVD Recorder/VCR
Hook ups
use a video splitter for the audio and video, or go out of the DVD player in to the DVR, out of the DVR into the TV (WARNING!!!! Trying to hook a DVD player to any recording device may trigger the copyright protection, causing blue flashes, and distorted pictures)
Aug 22, 2008 | Memorex MVD2042 DVD Player
Burning cd with windows media player
Hi, can you check in Windows Media Player what devices you have installed. Tools/Option/Devices. Highlight your CD R and click on Properties.Click on Recording Tab. Make sure there is a check in Enable CD Recording on this drive. Hope this works for you. Pls post again how things turns up. Cheers.
May 08, 2007 | E-Machines W3400 PC Desktop
iLO DVD Recorder DVDR05 Logo
50 people viewed this question
Top iLO Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Saylor
Level 1 Expert
Are you an iLO Televison and Video Expert? Answer questions, earn points and help others
