Question about Canon PIXMA iP6700D InkJet Photo Printer
Error msg 6A00
My Canon Pixma iP6700D stopped printing this morning and gave me the above error msg. I can not find this error msg listed in my user guide that came with the printer, I have canceled the print jobs, turned it off and left it off, but when I turn it back on it stills shows this error and will not print? What am to do?
  • roseval Feb 27, 2008
    SAME PROBLEM ERROR MSG 6A00
Just fixed mine. :-) I highlighted in yellow a small absorbtion pad that sits under the "home" position for the ink heads. This pad was tilted on its side and prevented mechanisms from moving. Once I put it back in its place, everything appears to be working. You might be able to reach this without taking the cover off, but it is tricky. See http://www.fixyourownprinter.com/forums/inkjet/37440 for some info on care with cover removal.
Posted on Mar 24, 2008
Was anything figured out about error 6A00???
Code 6A00 is comming up whenever I try to print. kindly advise me how to solve
Hello and Welcome to FixYa!
The 6A00 is a Canon generic code for paper path jam.Some where in the paper path a sensor is activated indicating paper jam so the printer will give off a 6A00 code.As a Canon technology,I usually find the code almost 90% of the time it is related to the purge unit being jammed with something and not being able to move.Moving the print head assembly will not clear a purge unit if its jammed with paper,paper clips,push pins,screws,cookie crisp,flower bud pods etc.
I have found all those things in a purge unit.The offending item needs to be removed or the purge unit needs replacement.A
Canon PIXMA iP6700D InkJet Photo Printer would still be under Canon warranty, get it into a shop and save yourself the hassel.
Incidentally, the 6A00 error pertains to all Canon printers made in the last several years, its not just used in one model & its always a paper path error or purge unit
I forget myself so here goes, the purge unit,called a spittoon assembly in an HP,lexmark & other ink jet printers,is where the print head assembly parks when not in use, also its other job is to clean and make sure the print head is clean and open for printing.That is why you 'll find the print head assembly parked on top of it. It also has a an electrical pump to milk the print heads and test for ink flow
If you want to get support on Call then Call Canon Support by phone, at 1-800-OK-CANON (1-800-652-2666)
I hope this solution helps you
Don't hesitate to let me know if you want any further assistance.
Thank you for using FixYa!
May 10, 2011 | Canon PIXMA iP6700D InkJet Photo Printer
Error 6A00 on/off and alarm are flashing
Solution 1:
Move the printhead carriage back and forth a few times.
Solution 2:
Check the purge unit: Moving the print head assembly will not clear a purge unit if its jammed with paper, paper clips, push pins, screws, cookie crisp, flower bud pods or the like.
Solution 3:
Press the ink pads down in the purge unit.
All I ask is please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Apr 11, 2010 | Canon PIXMA iP6700D InkJet Photo Printer
Error code 6A00 comes up printer not working
The carriage did not move up or down
properly.
PR lift shaft ***'y (QL2-
0936)
- Sheet feed unit (QM2-
2312)
- Logic board ***'y (QM2-
2745)*1
- Carriage lift sensor unit
(QM2-2678)
Jan 25, 2010 | Canon PIXMA iP6700D InkJet Photo Printer
6A00
Hi
Error 6A00
Solution 1:
Solution 2:
Solution 3:
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
Oct 15, 2009 | Canon Pixma MP500 All-In-One InkJet...
Canon iP6700D error 6A00
6A00 is a purge assembly error, thats the cleaning unit on the right where the printhead parks. Look on the right with a flashlight and see if there's paper, or anything that doesn't belong. If the wipers are jammed into the pad assembly, you will need a new purge unit, best changed by a shop.
May 25, 2009 | Canon PIXMA iP6700D InkJet Photo Printer
Printer malfunction
Hi
Error 6A00
Solution 1:
Solution 2:
Solution 3:
Dec 03, 2008 | Canon PIXMA iP6700D InkJet Photo Printer
Printer problem
Hi
All the best
Solution 1:
Solution 2:
Solution 3:
Oct 08, 2008 | Canon PIXMA iP6700D InkJet Photo Printer
Canon Pixma IP6700D
Hi there
Error A600
Your A600 is a paper path error, usually related to the purge unit. Try checking the purge unit for paper stuck in it.
Almost 90% of the time is related to the purge unit being jammed with something and not being able to move.
Look for paper, paper clips, push pins, screws flower bud pods or the like.
The purge unit, called a spittoon assembly in an HP, Lexmark, and other inkjet printers, is where the print head assembly parks when not in use, also its other job is to clean and make sure the print head is clean and open for printing. That is why you'll find the print head assembly parked on top of it. It also has an electrical pump to milk the print heads and test for ink flow.
The purge unit is a white plastic assembly (on the right side of the printer where the print head homes) that is spring loaded on rides on a rail.
You can try moving it back and forth about 5 times or so and clean the rail with a cleanex and putting a little bit of some light oil on it and then close everything up and try it.
If you found this useful all I ask is call back and just gave a vote, it will gave me some satisfaction to know am helping some one, so I will keep on helping.
Jul 07, 2008 | Canon PIXMA iP6700D InkJet Photo Printer
Canon PIXMA  iP6700D InkJet Photo Printer Logo
189 people viewed this question
old marine
old marine
