Blinking red power light - set will not turn on
HI, this morning I turned on the tv to watch the weather and in a few minutes, noticed that the screen had gone black. I still had audio at that point but turned everything off to restart - I have Directv so restarted that receiver as well.
Once I did this, the tv tried to turn on (you could hear it click) but the screen stayed dark and the power button began to flash red. I cannot turn off the power button by pushing on it. It continues to flash red and the screen stays black with no audio now.
Have tried replugging it in and out and even changed power strips in case that had gone bad but other things plugged into it seem to work.
What has happened? Thanks.
  • 1 more comment
  • Mc Robb Jan 23, 2008
    OK - I put the make and model number in the place where you asked for it but here it is. It is a Toshiba 57HC85 - rear projection monitor. We have had it just over 2 yrs now with no problems.
    I called Toshiba and they had me unplug for a few minutes and then plug back. When I did that, I got a blue screen very briefly with pale blue lines across it but after about 3 seconds, the screen went black again. But I did have audio until the screen went black. Thanks for your help.
  • Mc Robb Jan 27, 2008
    Thanks for you comments. I am in a wheelchair so cannot do the actual work. My husband was reluctant to do anything ourselves so I have called the repair guy. Hope it doesn't cost me an arm and a leg!
  • Cary Farah
    Cary Farah May 11, 2010
    need make and model number
  • 3 Answers
I know it has been awhile since this was posted. In simple explination, one of the tubes has shorted. It is more than likely the blue tube if the screen is turning blue before it shuts off. I have the 46h84 Toshiba widescreen and it has recently done the same problem. To troubleshoot, remove the control board for the tube, make sure it does not touch anything, plug the TV in and see if it stays on for at least 5 minutes. If so, the tube is the ptoblem. If it shuts back off, reconnect the tube and try it with the other boards. if the problem exisit with the tv the same each time, it is a controller board that is no good. Isolating that is a bit more difficult and I have not had the experience troubleshooting those. Good luck
Posted on Dec 05, 2008
    President:
  • 4,402 Answers
Heres your fix
http://www.riddledtv.com/repair/journal/Toshiba51H84/index.html
Posted on Jan 24, 2008
  • Cary Farah
    Cary Farah Jan 28, 2008
    please mark the post as fixya!
  • 8,617 Answers
Were the pale blue lines real thin in a slight diagonal from bottom to top of your screen? If so you either have a bad component in the blue drive, Blue CRT socket or your Blue CRT is shorted.Try removing the blue CRT socket and trying to power up your set for a moment without the blue socket attached to the tube. Be sure the CRT socket doesn't touch any components when you try this. Let me know if the set starts up without the blue.
Posted on Jan 23, 2008
Yesterday i changed the lamp. After this I turned the TV on and it worked fine. This morning, upon turning it on,it showed for a few minutes and then the screen went blank, the green power light started to...
how many times is the red led blinking? if you just changed the lamp make sure and check that the lamp door is secure if the door is ajar it will flash 3 times.
Dec 22, 2010 | Sony Grand WEGA KDF-50WE655 50" Rear...
Hi, I have a Sony KDL-46XBR9 LCD Digital Color TV. This morning my son was watching cartoons and it clicked itself off. It has sometimes done this in the past, so we did something else for a couple of...
This tv have a power supply board is the causes and the problems.Ur tv power supply board finally gave out and not supply the right voltages to the tv system anymore.That the board,where the tv power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Dec 06, 2010 | Televison & Video
When i go to turn on the tv the red power light turns on and then starts flashing, with an all blank tv screen. I cant get anything but a black screen. The light will flash for a lil while, then the tv...
BLINKING RED LIGHT IS ERROR CODE.
1. Unplug set for a few minutes.
2. Plug back in and turn on.
3. When red power light starts blinking--COUNT THE BLINKS.
4. THREE BLINKS, pause, THREE BLINKS (ETC) IS SHORT PROTECTION AND A DO IT YOURSELF repair for some people. I have complete instructions for this repair.
5. 5 blinks, pause and 5 blinks etc is short on 140 volt line and while not as easy as 3 blink error code it points to places to look at.
If this told you something you did not know, rate this solution as very helpful as I do this here for free.
Post a comment here when you know what error code is and I will help.
REGARDS, SD TECH
Aug 16, 2010 | Panasonic PT-47WX53 47" Rear Projection...
TV will not come on, red power light clicking off and on.
This problem is caused by a couple of faulty electrolytic capacitors located on the power supply pcb. Think they are both 1000mfd 35v
Aug 29, 2009 | LG 42LC2D 42 in. LCD HDTV
Sony KDF-46E2000 - Screen Goes Blank
You definitely have a bad lamp. Sony rates the lamp life at between 4000 and 8000 hours. There are 3 things that effect the lamp life, listed in order of importance:
1) number of times the lamp is turned on and off. Every time the lamp is first fired, it takes life off the lamp. Customers I see that turn the TV on in the morning, leave it on all day and then turn it off on the evening can get up to 12000 lamp hours
2) ventilation. Be sure you have at least 6 inches of open space all the way around the set and that the vents are clear of dust and debris.
3) power. If the power is interrupted when the set is on, there cannot be a proper cool down cycle. The fans will run after you turn the set off to properly cool it down, if the power is lost this cannot happen. If your power is unreliable, buy a small UPS to let the set finish a cool down cycle
Occasionally a lamp will faill before the average lamp time due to being defective. from your purchase date it sounds like you got about average lamp time. Be sure to purchase AN ORIGINAL SONY LAMP as a replacement, becuase the aftermarket lamps are bad news, Be sure to rate this solution. Thanks!
Oct 13, 2008 | Sony KDF46E2000 46" Projection HDTV
Sony 57" rear prijection TV has a fast flashing light and will not turn on
turn on tv, after a few minutes picture goes black, but still have sound. red light blinks 5 times,turn set off same thing happens when you turn set back on. some times it want do it for 10 min.
Apr 25, 2008 | Sony KP-57WS500 57" Rear Projection...
Hitachi 55VG825 rear proj television blinking light and screen doesn't light up
Refer to owners manual ! Blinking indicates the type of fault that is occuring on all your tv sets. example : power light on red - indicator light beside it green but blinks rapidly for half a second rapidly then shuts off. This refers to a faulty lamp or a lamp that is near its expiration. Read your manuals if indicators refer to easy repair sweet, but if it says call tech then bummer...
Dec 06, 2007 | Hitachi UltraVision CineForm 55VG825 55"...
Televison & Video Logo
468 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
