Question about DISH Network DVR-625 DTV Receiver / 100-Hours Video Recorder
Dish Network 625 Receiver Problem
I bought a new 625 Receiver a few months ago on EBay. Yesterday a technician tried to install it and window appeared saying "hard disc internal memory corrupted" or something to that effect and he couldn't pull up menu, etc. Can this be easily,(cheaply) repaired? Thanks glrb@hotmail.com
  • LarryRB Aug 07, 2008
    I sent it back to the seller. Thanks
  • 51 Answers
Sounds like a bad hard drive, is there a number in the top left corner of the attention box??
Posted on Aug 07, 2008
We have dish network with a dvr. A few weeks ago it started recording things we did not program it to and deleting timers that we had programmed. We called dish and they sent us a new unit. Immediately...
Hello, my name is Becki Barned with Dish Network customer service. I understand the frustration with this issue. There are a few things that could be causing this problem. There could be interference with a remote at a location near yours, such as a neighbor's remote. It could be a grounding issue, in which case a technician would be needed. Since it is happening on the second unit, a technician may be the best resolution, because as I said, it may be a grounding issue causing this. If this has not yet been resolved, or you have any other questions/comments, blog back, or you can also find us on Twitter!
Nov 23, 2010 | DISH Network DVR-625 DTV Receiver /...
Installed a new 625 today replacing any old 510 receiver. On the new 625 I cannot get TV2 to record--can only get TV1 to record. Have called Dish and was told to put in a DP separator. My husband did...
Hello! Dan Busa with Dish Network here. I know you've probably gotten this up and running by now but just for reference to anyone on this site. Any cabling or connectors used to carry signal to the receiver should be rated for 2,150 mhz if this is not the case you will typically get signal loss messages.
Oct 04, 2010 | DISH Network DVR-625 DTV Receiver /...
We recently moved our dish ( we are in an rv) and now we get a signal on one tv only. we have dish network and a 625 DVR. we have moved many times and have never had a problem before. in order to switch...
5shades690,
Are you still having problems with your TV 2 off the 625 receiver? You have a cable off the back of the receiver, TV 2 Home Distribution. That's feeding to your TV 2 location. You might check to make sure it is secure. You can also see if that cable screws into a diplexer if it is being back feed through the satellite cables. These are all potential problem spots, especially since you said it was working before. I hope this helps.
Ray Calo
DISH Network
Jul 28, 2010 | DISH Network DVR-625 DTV Receiver /...
DISH Model 625 skips to the end
Hi claramarie20there are a couple of things to look at when this happens. The first thing youwill want to do is replace the batteries in the remote, after you replace thebatteries you will need to press the MENU button and the numbers of 6-1-1. Itwill take you to the Point Dish screen and from there please select the CheckSwitch tab and then the Test button. After the test completes exit out of allmenus and the receiver will reboot and acquire the signal and it will stop the receiverfrom powering on and off.
Jul 04, 2009 | DISH Network DVR-625 DTV Receiver /...
Dish 625 shuts off without warning and fan runs high
Unfotunately this is an event known as power cycling and the only resolution is another receiver. This issue is due to faulty internal components and has nothing to do with anything other than that fact. If you have further questions feel free to contact me. Thanks for using Fix Ya.
Jan 12, 2009 | DISH Network DVR-625 DTV Receiver /...
Dvr receiver 625 will not record
hit master reset .. if that doesn't work rma the dvr needs update
Hunter
Jan 08, 2009 | DISH Network DVR-625 DTV Receiver /...
Installing a DVR
You are not able to use the DVR unless you have Dish Network services. Cable operates at a different frequency than Dish Networks Dish Pro Plus Receivers.
Sep 07, 2008 | DISH Network DVR-625 DTV Receiver /...
DISH Network DVR-625 DTV - AUDIO PROBLEM ON LOCAL CHANNELS ONLY
I am probably stating the obvious here but here it goes:
If the 625 is connected to the tv using coax directly try using the RCA jacks to connect directly to the tv. If the 625 goes through a peripheral first, eliminate that peripheral and conect directly to the tv.If the problem exists with different media connections still at the same tv you can remove the coax off of the TV1(3-4) output on the back of the 625 and attach it to the TV2(CH60-73) output.You would then change your tv channel from 3 or 4 to ch 60air or 73 cable(which will be the same channel that TV2 is normally on in the remote room without the 625) Once you are on the right channel you will be able to tune TV1 to your local channel using the TV2 remote. If the audio is good here it eliminates the TV coax input on the TV1 and the coax cable connecting it as the source of the problem. You will have already eliminated any other inputs on the same tv as being faulty by using the other connecting media leaving you with the internal components of the receiver as being faulty. In this situation I know of no recourse except the obvious.
Aug 08, 2008 | DISH Network DVR-625 DTV Receiver /...
Lines on TV with DVR-625
try using a better cable from the receiver to the tv. sometimes less expensive cables dont "ground " as well as they should after a few years. the more shielding the better. the cable here will sell you the cable much cheaper then going to any store and its better quality, even if your not a customer of cable.
hope this helps
Mar 12, 2008 | DISH Network DVR-625 DTV Receiver /...
DISH Network DVR-625 DTV Receiver / 100-Hours Video Recorder Logo
281 people viewed this question
Top DISH Network Televison & Video Experts
S. Gontko
john milligan
Jaime Hernandez
Are you a DISH Network Televison and Video Expert? Answer questions, earn points and help others
