Question about Maytag Neptune MAH5500B Front Load Washer
My door lock is in lock mode and the door is open. If i push the door closed and hold it closed, the machine operates. I also noticed that the spin light does not light up - it goes from rinse to off after the time expires. What is odd is that it seems like it is spinning. Any suggestions? I am hoping that I only need to replace the lock.
  • 1 more comment
  • Frank Mooch Jan 23, 2008
    yes, I tried both.
    Is there another way to lift the plastic lock that latches onto the door
  • Gary Davd
    Gary Davd May 11, 2010
    have you tried to use the manual release to open the lock??
  • 1,294 Answers
Try some WD40 on the lock.
Posted on Jan 23, 2008
Door won't open
Dec 31, 2012 | Maytag Neptune MAH5500B Front Load Washer
It says the door is not locked
There are two switches in the door latch and they both need to engage. Check it with voltmeter. Most likely bad door latch assy.
Maytag Neptune repair in orange county, ca
appliance repair orange county, ca
Feb 06, 2010 | Maytag Neptune MAH5500B Front Load Washer
My Maytag Neptune Washer has an error code "do" What does this mean?
The washer detects that the door is open when
starting a cycle or the door is not locking.
Close the door tightly and restart the cycle.
Nov 14, 2009 | Maytag Neptune MAH5500B Front Load Washer
The comment posted 14 may 2009 it what helped me. DO NOT PRY OPEN the door. Find the release cord inside the soap dispenser,,,you may have to remove the 4 screws and lift it from the washer like i did. I had to lean into the door and pull the cord to release the lock. It was not a system error. The washer was over loaded and although the door was closed and locked...the load pushed the door enough to indicate that it was open and would not wash. After opening the door, rearranging the load and removing some, the door closed and latched locked and was able to continue with the wash. DO NOT PRY OPEN,,,use the cord release first,,,this worked for me.
May 13, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag front loader washer--door won't open but lock light off
Open the soap dispenser. Look down in front of the fabric softener dish.
You should see a yellowy-green plastic cord (like weed-whacker line). Pull it.
The door should open.
If you don't see the cord, remove the four screws that hold the dispenser lid in place to find it. Just don't lose it when you put the cover back on.
Mar 01, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune - door locked, clothes inside, lights are on, no reaction to unplugging and replugging. Help! My work clothes are in there! Thanks a lot.
The manual says that you should push the on/off button to turn off the machin. Wait for 2 minutes for the door to unlock. Then open the washer door.
Sep 29, 2008 | Maytag Neptune MAH5500B Front Load Washer
Maytag neptune won;t rinse
Check latch mechanism for alignment. Often operation of machine loosens latch mechanism causing internal switch for "door open (or ajar)" preventing rinse or spin cycle. Opening and closing door presses latch mechanism closing internal switch allowing for continue processing to rinse or spin cycles.
Mar 24, 2008 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune MAH5500B Front Load Washer Logo
356 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
