Question about Epson Stylus CX3200 All-In-One InkJet Printer
Epson stylus CX3200
I have the same problem as the others....Scanner Error...see manual. Tried resetting the lock function, but did not work. Have also flicked trasportation lock back and forth, no resultm have also tried locking transportaion swith and shaking printer.
  • 98hd Jan 24, 2008
  • sylviacr Jan 27, 2008
    Thank you for your message. I know I am not very IT litrerate, not totally useless, but I have not been able to see what you suggestion is to fix it. I have checked all the links and keep coming back to see that use 98hd has the same problem.
    Apologies. Sylviacr
I have just changed the print cartridges on my Epson CX3200 and when I closed the lid I got the 'Error' message on my scanner telling me to contact service engineer. I thought it has to be something stupid as all I'd done was opened and closed the lid. so I switched the printer off, played about with the transportation locking mechanism, opened the lid, pressed the soft area 'under' the kid below the locking mechanism (just out of curiosity) wondering how the locking mechanism worked, closed the lid, switched the printer on and lo and behold, the error message was gone, So I don't know what part of my actions it was that did the trick, but there's something sensitive in that mechanism, so all I can say is fiddle like I did and I'm sure you'll eventually get a result.
TC
Posted on Feb 02, 2008
  • Epson Master
  • 1,879 Answers
We know that having a printer serviced/fixed costs more than buying a new one, check out this link http://www.epson.com/loyalty .
Posted on Jan 26, 2008
Error Message - Scanner
Go to manufacturer's website, and download the latest device drivers for your model printer, and any other software updates they provide.
Sep 01, 2009 | Epson Stylus CX3200 All-In-One InkJet...
Epson Stylus CX3200 Error
Possible scanner failure.
Turn off your printer. Disconnect it from your computer. Toggle the transportation lock on the scanner unit if there is any. It has to be in the unlock position. Turn the printer back on.
If your unit is not yet a year old, please contact epson for your warranty options.
To help you find an epson certified servicer near to your area, please log on to epson.com.
Apr 28, 2009 | Epson Stylus CX3200 All-In-One InkJet...
Error inkcartridge
Error message: No color or black ink cartridge-->Press the Color Copy button to install a new ink cartridge.
Solution: The indicated ink cartridge is not installed. Please install the necessary cartridge(s).
Error message: Color or black ink out -- >Press the Color Copy button to begin replacing the ink cartridge.
Solution: The indicated ink cartridge is out of ink. You will need to replace the necessary ink cartridge(s).
Error Message: Ink cartridge error -- > Press the Color Copy button to begin replacing the ink cartridge.
Solution: There is something wrong with the ink cartridge. Make sure the cartridge is genuine Epson ink. Also, try reseating the cartridge (remove it, and then reinstall it).
Error Message: Paper jam or misfeed -- > Press the Color Copy button and clear the paper jam by hand if necessary.
Solution: Paper is jammed. Check for any obstructions under the unit's cover, and in the paper tray.
Error Message: Paper out -- > Load paper in the sheet feeder and press the Color Copy button.
Solution: Load paper in the sheet feeder, and then press the Color Copy button to continue printing.
Error Message: Scanner unit open -- > close the scanner unit
Solution: Carefully close the scanner and press it down until it clicks securely into place.
Error Message: Scanner error -- > See your documentation and call service if necessary.
Solution: Press the ON button to turn off the Epson Stylus CX3200. Unlock the transportation lock, if necessary. If it is already unlocked, toggle the lock back and forth, 5-10 times. Turn on your Stylus CX3200 again.
Error Message: Printer error -- > See your documentation and call service if necessary.
Solution: Press the ON button to turn off the Epson Stylus CX3200. Disconnect it from power, and then reconnect it to power. Press the ON button to turn on the Stylus CX3200
Nov 28, 2008 | Epson Stylus CX3200 All-In-One InkJet...
My scanner
Open the scanner lid and slide the transportation lock back to the hw_translock_1.gif unlock position.
I will appreciate a Fixya rating if I were able to resolve your concern.
Oct 22, 2008 | Epson Stylus CX3200 All-In-One InkJet...
CX3200 SANNER
Can you make a copy? If not then:
1) Turn off the printer.
2) Lift the scanner cover.
3) Toggle the transportation lock five times, ensuring that it is in the unlocked position, towards the back of the scanner.
4) Turn on the printer, and the error should be cleared.
If you can make a copy, you need to go to your all programs, and select Epson Scan
Aug 18, 2008 | Epson Stylus CX3200 All-In-One InkJet...
Scanner error see your docmentation and call service if necessary
Please follow the steps below to resolve your issue.
Jul 28, 2008 | Epson Stylus CX3200 All-In-One InkJet...
Help Epson CX3200
I just like to ask to where specifically you can see the red light. It will help us determine what cause the red light. To give you heads up as well, the Printer's LCD screen can help us determine what exactly the offline condition of the CX3200 is:
Solution: Press the ON button to turn off the Epson Stylus CX3200. Disconnect it from power, and then reconnect it to power. Press the ON button to turn on the Stylus CX3200.
May 23, 2008 | Epson Stylus CX3200 All-In-One InkJet...
Nazir
There is an error with the scanner section.
Feb 08, 2008 | Epson Stylus CX3200 All-In-One InkJet...
The red light is on and the message scanner error. tried turning it off and then on again after a few seconds the red light comes on again. Also check to see if the system was locked released that. Tried...
Try flicking the transportation lock (on the left side under the scan lid) on and off. It has a picture of a pad lock shown locked and unlocked. Flip it back and forth and leave it in the unlocked position.
This worked for me. Good luck!
Oct 15, 2007 | Epson Stylus CX3200 All-In-One InkJet...
Scanner error
Oct 07, 2007 | Epson Stylus CX3200 All-In-One InkJet...
Epson Stylus CX3200 All-In-One InkJet Printer Logo
334 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
