Question about ViewSonic Televison & Video
Diplay setting changes made but the color or resolution is still bad.
We are having resolution problems with a 22' widescreen ViewSonic VX2255 wmb. We have tried the normal what else can we do. We have made changes to the display setting but the color or resolution is still bad. help
sdwilliams@ddi.org
I have a similar problem with this monitor, i always after connecting having to go to the "screen Position and Size" setting in my ATI FireGL. and shift the screen 1 pixel, and the color and resolution turn ok, it is manual step, but better than no fix
Posted on Jun 17, 2009
Dell 2208wfpt settings for portrait rotation?
Andrew Scharlach,
Are you changing the rotation using the ctrl+alt+right arrow. left arrow or down arrow? That is how i change the rotation on the screen. If needed lower the resolution in the display settings in control panel.
Thank You,
Dell-Jesse L
Dell Social Media and Communities
Jul 24, 2015 | Dell UltraSharp 2208WFP 22" Widescreen LCD...
My monitor shows nothing but a white screen
This is typically a sign of a video card that is not working right. The other possibility with ViewSonic is that the monitor went bad. MNy best advice is find someone with a known working computer and hook the monitor up and see if it works or not. That way, you can determine if it is the monitor or the computer. Also, the VX2255 may be under warranty. A visit to viewsonic.com will help you determine if they can repair/replace (if your test finds the screen to be bad.) Be sure to un plug the monitor from the wall; wait a moment, and plug back in to determine if a power blip may have caused an issue too.
Best of luck.
Oct 18, 2010 | ViewSonic VX2255 Monitor
Mouse movement is not clearly visible & get more H'lin brightness
Have somebody take a look at the capacitors in the power supply first, look for caps that are leaking/bulging top, very common failure in LCD monitor.
Please see some failed bad caps album and failed VIEWSONIC monitors due to bad caps here:
http://s807.photobucket.com/home/budm/allalbums
Learn about bad caps:
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Jun 01, 2010 | ViewSonic VA2226w 22" Widescreen LCD...
After waking from sleep mode, monitor resolution is a mess!
Try reinstalling the graphics drivers. and possibly a different graphics card.
Apr 14, 2010 | ViewSonic VA2226w 22" Widescreen LCD...
I had to reinstall my Viewsonic monitor after getting a new hard drive. Now the screen shows everything is a horizontal stretched mode. How do I get it to normal aspect ratio?
It seems like the display resolution was not set to the optimal resolution for your monitor.
To correct this, follow this guide. I am assuming you have Windows XP.
1) Navigate to the Control Panel in Microsoft Windows by left-clicking on Start, followed by Settings and then choosing Control Panel.
2) In the Control Panel window, open Display.
Note:
In Microsoft Windows XP, depending on how your operating system is setup, you may not see the Display icon. To correct this, click on the link on the left-hand side of the Control Panel window that says Switch to Classic View.
3) In the Display Properties window, click on the Settings tab.
4) Slide the Screen resolution slider all the way to the right for your optimal resolution.
5) Click the OK or Apply button to confirm the changes. If prompted, follow any additional on screen directions.
NOTE: If the text appears too small, go back to step 4 and try a different position on the slider until you get it how you like it.
Good luck on solving your computer problem.
Aug 27, 2009 | ViewSonic VA2226w 22" Widescreen LCD...
My viewsonic VA1701wb monitor having streching problem for images
The native resolution for that LCD is 1440x900. If you do not see that resolution in your display properties you can try to update the video driver. If it is still not displayed as an option you may need a newer graphics card. Many newer low end card support this widescreen resolution, so if you need to replace the card you will not need to spend a lot of money.
Mar 18, 2009 | ViewSonic VA1703wb Monitor
Bad resolution Westinghouse 22" LCD
You might have to apply one or more of the following troubleshooting steps to solve this problem:
Fuzzy Image
• Set desktop resolution on your PC to 1680 x 1050 at 60 Hz.
• Adjust Phase/Sharpness setting on the monitor
Cannot find 1680 x 1050 under screen resolution on my Display Properties
• You may need to download and install the latest video card driver for your PC.
Listed below are websites for major video card manufacturers:
Nvidia: http://www.nvidia.com/content/drivers/drivers.asp
Intel: http://downloadfinder.intel.com/scripts-df/support_intel.asp
ATI: https://support.ati.com/ics/support/default.asp?deptID=894
If you need any further clarification, you can view a user's guide online at: http://www.westinghousedigital.com/pdf/60_User_Manual.pdf
If I've managed to solve your problem or answer a question, please take a moment to rate this post,..thanks!
Feb 28, 2009 | Westinghouse 22" Widescreen LCD Flat Panel...
Viewsonic vx2245wm
You need to chk graphics settings in NVidia control center and change resolution until it looks right
Mar 06, 2017 | ViewSonic VX2235wm LCD Monitor
Televison & Video Logo
110 people viewed this question
Top ViewSonic Televison & Video Experts
Are you a ViewSonic Televison and Video Expert? Answer questions, earn points and help others
