Question about Kenmore 88752 Top Load Stacked Washer / Dryer
Dryer Problem Just this past weekend I noticed that it is taking several cycles for my clothes to dry. The dryer is turning and there is heat however, the lint trap is not collecting anything. I have vacuumed the lint trap. Help
  • 2 more comments
  • Anelly Feb 05, 2008
    Thanks so much!
  • 1tiabates Apr 06, 2008
    i can't find the lint trap, now it takes a long time for my clothes to dry
  • labcfitz Jul 30, 2008
    vacuumed lint trap and dryer. blown out vent. cleaned all lint from dryer. lint trap still not collecting lint and it takes several cycles to dry. condensation builds up on the lint trap top
  • Anonymous Mar 13, 2014
    Dryer turns on and will heat up but will not dry anything. It takes several cycles to get it even half dry. we have cleaned the lint screen but still won't dry.
  • 770 Answers
SHUT OFF THE BREAKER to the unit then open the panel (3 Screws) that is in between the washer and Dryer you will see your venting hose ther remove the flex vent pipe from the exh duct closes Turn back on the pwr and run a load in the dryer see if it drys ok if you wil need your vent to the outside cleaned out
Posted on Jan 23, 2008
  • Gary Davd
    Gary Davd Feb 05, 2008
    Your welcome glad to Help
Kenmore elete model 110.67032600 timer changes to higher # and takes a long time to dry on auto dry.
I had this and it was lint trapped in door below lint filter screen.( several handfulls) Took door apart/ reassembled and he worked fine.
Oct 07, 2015 | Kenmore Dryers
Whirlpool duet dryer
Run the dryer for 2-5 minutes. Check to see if it has heat inside. If not, you have an internal problem.
If heat is generated, check your dryer lint trap. It must be clean before every dry cycle to dry properly and efficently. If the trap is clean and heat is generated, check the tubes behind the dryer for disposing of the lint.
Oct 15, 2013 | Dryers
Our Crosley CDE6000 electric dryer would shut off midway through a timed cycle w/ clothes not dried. I removed the door and front , then cleaned out a fairly good amount of lint from trap in door. Rep
sounds like your stat (Tod) for short has gone a Tod is what tell the dryer to heat and when to turn off you will have to replace them OK they are right on top of the heater OK hope this have helped
Oct 22, 2012 | Crosley CDE6000 Electric Dryer
Why isn't My Kenmore Heavy Duty 70 Series Soft Heat Extra Capacity Electric Dryer drying clothes on any one cycle?
One possibility: Air flow! Make sure that the lint trap is cleaned before each cycle. You likely need to thoroughly clean out the vent piping out the back of the machine- a buildup of lint in here can also restrict airflow.
Sep 04, 2012 | Kenmore 659 Electric Dryer
Dryer taking to long to dry
1. One of the simplest problems to remedy could simply be that you are putting too many items inside the machine during the drying cycle. Avoid overloading your dryer, as this might cause your dryer to work extra hard to dry your clothing, extending the length of the dry cycle.
Wrong Heat Setting
2. A common issue with clothes dryers could be the wrong heat setting. Most home dryers feature several settings, from low heat settings to high heat and permanent press. Be sure the setting you choose is right for your needs. Another setting to check is the load size of your dryer. If you are drying a large amount of clothes, be sure the setting for large loads on high heat is selected. Choosing the wrong heat setting or load size can cause your clothes and linens to take longer to dry.
Lint Trap
3. One of the simplest fixes for drying issues might just be that your lint trap is clogged. Each time you use your dryer, lint will form in the trap. If the lint trap and vents are full, this could block air going into your dryer and slow down if not completely stop the drying process. After you use your dryer, remove this lint trap and empty it fully. Even if the lint trap is full, your other dryer vents might be clogged as well.
Clogged Vents
4. If your clothes are in the dryer for a long amount of time, but still not drying, the reason for this could be a clogged vent. A sign that your vent is clogged is if your clothes are warm or hot to the touch after sitting in the dryer, but still damp. To unclog your dryer vent, you may need professional assistance. This is especially necessary if your dryer vent leading out of the house is particularly long.
Heat Source
5. If the dryer is not getting enough heat to dry your clothes,something could be wrong with the heating system. After the drying cycle, touch your clothes to see if they are warm. If not, this means that the heating mechanism is malfunctioning. It will need to be repaired or replaced by a professional.
Feb 28, 2011 | GE Profile Harmony DPGT750GC Gas Dryer
Clothes not dryin
clean out the exhaust vent tubes thoroughly. the moister sensor will shut down the high heat if clogged full of lint
Jun 06, 2010 | Estate EED4100SQ Electric Dryer
I have a GE dryer that is approx. 5 years old (not sure what model). This weekend it stopped blowing hot air (just runs cold for the alotted time on timed dry cycle). It ran all night the other night when...
without knowing the model... your first safe bet is to trace the lint trap all the way to the vent and check for blockages. this will cause the effect you are talking about. also i would consider the heating element has gone bad.
Oct 19, 2009 | Dryers
Will not dry clothes fully. the machine heats fine but it takes two or more cycles to fully dry a little load. someone told me about a part that may need repaced around the lint trap.. Any ideas?
Your lint exhaust is blocking the heat flow.
Remove the vent from the rear of the dryer and run a timed cycle load for 40 minutes.
If laundry is dry, repair the outside vent.
If not dry,open the dryer cabinet and clean the inside lint and heat vent.
Mar 05, 2009 | Kenmore Dryers
Dryer is heating but not get clothes dry...
make sure you have a strong air flow from the dryer it self take hose off and run the unit it should force your hand away if not your dryer is stopped up you will have to take fan casing off and clean (the metal going to hole for vent hose) if you do go outside and make sure you vent outside is opening and free of lint also wash your lint filter with warm soapy water fabric sheets stop them up and cause longer drying time
Nov 12, 2007 | Roper REX4634KQ Electric Dryer
Dryer produces low heat but not high heat
check the vent outside it seems to be getting too hot and cycling the element off and on your safety therm.
Oct 22, 2007 | Kenmore 62802 Electric Dryer
Kenmore 88752 Top Load Stacked Washer / Dryer Logo
171 people viewed this question
Sal De
 Brian Main
Brian Main
