Question about Maytag MAH8700A Front Load Washer
Error code PF
I get this error code "PF" on my Maytag neptun washer, washer will not work. Any idea what the code means?
  • Anonymous Oct 27, 2008
    I have a full load of work clothes in the washer and every few minutes it stops and displays the flashing PF code. I press the pause/start button and it starts again temporarily.
  • Anonymous Mar 27, 2014
    what does pf mean
  • 770 Answers
THIS is a "Power Failure " Clease the code (press Cancel button) and see if it starts up
Posted on Jan 23, 2008
Maytag dryer has PF error code, but when use a extension cord it works fine?
Must be something wrong with the cord itself PF means power failure:
Codes and manual
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Sep 21, 2012 | Maytag Neptune MDG9700A Gas Dryer
Code pf
Here is a tips that I wrote that will help to explain why you get the PF Error Code
PF Error Codefor Appliances
heatman101
Apr 25, 2011 | Maytag Neptune MAH5500B Front Load Washer
Maytag MD5500 displayed a code PF. what does that mean?
Power Failure maytag whirlpool same same:
http://www.advantagesupplyfl.com/WhirlpoolDryerFaultCodes.html
Apr 17, 2011 | Maytag Neptune MDG5500AW Gas Dryer
How do you fix the maytag neptune pf code for the dryer??
heatman101
Apr 13, 2011 | Maytag Neptune MAH5500B Front Load Washer
My maytage neptune washer is flashing PF what does that mean?
Hi
Error code PF means power failure. This happens when there is a power surge or the washer is unplugged manually. To reset this error you'll need to turn off the washer and unplug it for 10 minutes. Restart the washer and check, If the error still appears then pressing the Spin Speed key will begin the Board Output Test. This test turns ‘ON’ a specified output after a key press. Pressing the Spin Speed key again cancels the test. Please post back for further assistance if required.
Daniel
Aug 27, 2010 | Maytag Neptune MAH5500B Front Load Washer
My maytag neptune washer stopped working and flashed an FL error code. Any idea what that means?
It could mean flood error.if it has stopped full of water & it wont drain out.The pump might be blocked or jammed with hair pin or other debris.
May 30, 2010 | Maytag Neptune MAH5500B Front Load Washer
Error code PF
PF means Power Failure!
Unplug both units for 10 minutes, then plug them back in and try operating them. You may need an electrician to investigate why you are losing power to both units
Jun 04, 2008 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Neptune Dryer PF Error Code
PF is a 'Power Failure' code meaning the dryer power may be interrupted. The plug receptacle may be bad. Check the plug for proper tension. If feels loose, have the receptacle replaced. Inspect the plug for discoloration. (a sign of a bad receptacle). If all looks OK, Check the power connections at the dryer. If looks OK the electronic control may be defective.
May 31, 2008 | Maytag Neptune MDG5500AW Gas Dryer
Maytag MAH8700A Front Load Washer Logo
379 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
