Question about Creative Labs Zen MicroPhoto MP3 Player
Wont turn on
When i hook it to the computer it lights up and goes back to off but it wont turn on at all
    President:
  • 4,402 Answers
Sounds like the battery is dead do you have a ac charger to charge it?
Posted on Jan 23, 2008
The check light is parmenently on ,if the battry head is removed and replace it goes off and after some time it come's back
you have a bad sensor take to a local shop they can fix the sensor and turn of the light i hope this helps you when you un hook battery it resets the computer but with out fixing the problem the computer again realizes there is a problem and turns it back on so it will always come back untill you fix the problem please give good ratings
Jul 10, 2011 | 1999 Toyota Corolla
Ok 1994 vw passat... battery wont hold its charge.. new battery new alternator.. battery cables look old and worn.. when I turn the key sometimes there is nothing just the fourways trun on.. I then unhook...
the wires on the positive post are the large cable goes to the starter, one of the smaller wires goes to the charging circuit and the other goes to the fuse/relay power center, now how to check for a draw on your battery, first you need to remove the battery and have it charged you can take it to auto zone and they will charge it for free. after you have the battery charged hook up the negative battery cable but do not hook up the positive cable, make sure every thing is turned off and all doors and trunk are closed, then take a 12volt test light and hook it between the positive battery post and the positive battery cable if the test light lights up you have a draw, if it lights start pulling fuses one at a time till the light goes out. when you find the fuse that turns the light out you found the circuit that is drawing on the battery. now i cant tell you what in that circuit is drawing you will have to come back on and tell us what fuse it is and we can look up what all is on that circuit, if the light stays on after all fuses have been tested unhook the alternator if the light goes out you got a bad alternator......GOOD LUCK
Jan 15, 2011 | Volkswagen Passat Cars & Trucks
My mp3 player won't turn on until i hook it up to the computer and then it comes on but when i turn it back off it doesnt turn back on
i have a mini touch mp4 when i dropped it it wont turn on but when i plug it in a red light pops out but wont turn on!!!!HELP ME!!!!
Mar 13, 2010 | Philips SA3125\02 MP3 Player
The red light on my ps3 is blinking and wont stay on
Turn off the ps3. Try reseating the hard drive. Take the cables off and then hook them back up. After this turn the ps3 back on and see if the blinking red light goes away. If it doesn't then try another hard drive in the system. If the blinking light goes away then you know you have a bad hard drive. If the blinking light does not go away then you know either the power supply or main board is bad.
Jun 29, 2009 | Sony Playstation 3 (PS3) Console
Psp wont turn on green light goes on then turns off
http://forums.afterdawn.com/thread_view.cfm/688507 go to the fifith comment or so and do as told
First of all try hold the right trigger if a recovery mode pops up go to usb mode and hit X. hook it up to ur computer and then run psp deluxe and tell it what drive ur psp is and then do what they tell you to do and set dcmenu as left trigger and start it and then trun off turn back while u hold left trigger! if a menu comes up with 4.01 m33 do that!\\
HEY MAKE SURE ITS PLUG TO A CHARGE AT ALL TIMEs
Jun 15, 2009 | Sony PlayStation Portable (PSP) Console
Computer boots up when plugged in,monitor powers down
hi there.......
it is the memory it has to be matched with the actual fsb of the cpu if its slower then it wont switch on.....
and some dell pc's wont work with 1gb sticks so accertain which ram is compatible with the motherboard
Feb 24, 2009 | Dell OptiPlex GX260 PC Desktop
Dashboard lights will not turn off
Pull it back out, (Radio) and recheck your steps. Something is not hooked up right. When you pull it back out, See if it goes back working normal. Retrack the wires. You cut are hook up something wrong????
Feb 08, 2009 | 1991 Plymouth Acclaim
1999 ford explorer sport wont start
It sounds like you either have a bad battery or a loose connection at the battery
Jan 08, 2009 | 1999 Ford Explorer
Monitor remains in standby
turn the monitor off and the computer off. unplug it from the wall. let set for 10 sec. make sure you have it in the right place and in all the way. turn computer back on, then the monitor.
Dec 18, 2007 | X2Gen MG15VT 15" LCD Monitor
Creative Labs Zen MicroPhoto MP3 Player Logo
Top Creative Labs Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Mohamed Ismail
Mohamed Ismail
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
