Canon PowerShot A75 Digital Camera Logo
Posted on Dec 19, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The screen is very blurred and I can hardly see the subject when I'm about to photograph it, I've never had this problem before.
Anonymous
Level 3:
  • Master 10,594 Answers
  • Posted on Dec 19, 2009
Anonymous
Master
Level 3:
Answers
10594
Questions
9
Helped
2957173
Points
33084
If you see some what similar image in your Canon A75 then its problem of ccd imager chip failure and that will be replaced.
Canon offers free of cost ccd imager replacement in A75 camera.
Click Canon CCD Imager Advisory for details.
Thanks.
2helpful
Aperture function
The primary function of the aperture is to control the amount of light passing through the lens. The more light passes through the lens, the less time is required for the proper exposure. A faster exposure can freeze motion and alleviate camera motion, while a longer exposure can allow the subject to blur, conveying a sense of motion.
The aperture also affects the depth of field. A wider aperture narrows the depth of field, causing the foreground and background to blur, while a smaller aperture widens the depth of field, putting more of the scene into focus.
It's up to the photographer to decide which effects to show. Usually for a portrait you'd want the subject's face to be sharp and the background to be blurry. For a landscape, you'd generally want everything from the foreground to the background to be sharp.
tip
Depth of field is the characteristic of how much of, or how deeply, the...
Depth of field is the characteristic of how much of, or how deeply, the photograph is in focus. If the main subject is in focus but the foreground and background are blurred, the photo is said to have a shallow depth of field. if most of the photo is in focus, including the foreground and background, the photo is said to have a wide depth of field.
Depth of field is controlled by the aperture setting:
- A wide aperture setting (indicated by a low f-stop number) will provide shallow depth of field, resulting in the main subject being in focus and the foreground and background being blurry. This setting is particularly useful when taking portraits or when using a macro lens.
- A narrow aperture setting (indicated by a higher f-stop number) will provide wider depth of field, resulting in the entire photo being in focus. This setting is particularly useful when taking landscape or wide-angle photographs.
The photographs below are examples of how the same subject will photograph using different aperture settings. Note that as the aperture closes, which will allow less light to reach the image sensor, the shutter speed gets faster to produce the appropriate exposure.
I think you have got a general idea about depth filed. If you have further questions, you can ask me directly. http://www.fixya.com/users/shajanrs
depth of field - what is depth field - how depth field affects picture - how to adjust depth field - DEPTH FIELD - depthfield - DEPTHFIELD
Black screen no image showing
black screen blur image showing cannot see subject to be photographed when camera power on,if press to take photo nothing shows, just black screen. it was fine one minute then nothing the next. battery is fully charged, memory card ok.
What does the ND with a down arrow mean on the LCD
In photography and optics, a neutral density filter or ND filter can be colorless (clear) or grey filter. An ideal neutral density filter reduces and/or modifies intensity of all wavelengths or colours of light equally, giving no changes in hue of colour rendition.
The purpose of standard photographic neutral density filters is to allow the photographer greater flexibility to change the aperture, exposure time and/or blur of subject in different situations and atmospheric conditions.
This is used to set the best filter for your camera. If you would like to learn more on how to use the ND Filter consult your camera's manual.
Regards.
1helpful
Blur problems.
With blur, the problem could be the camera, but is usually due to the photographer. You can try using flash, decrease the distance to your subject, before you take the picture, hold the camera very, very still until after the picture is taken. If these things fail, the camera might be defective.
Apr 22, 2010 • Cameras
Well i was wondering how i could get a bokeh effect behind a subject? does anyone know? is it possible to do this without a filter?
hello! Yes, you can since the Coolpix L100 has a 15X telephoto lens, you can use the second method described below.
Bokeh is a photographic term used to describe a lens effect wherein the background of the photo is out of focus. This effect is used to blur out distracting backgrounds and give emphasis to the the primary subject of the photo.There are two ways to get bokeh when taking pictures. The first is by using a very large aperture to get a shallow depth of field. You can set your camera’s aperture to f/5 or below. This will effectively throw everything behind your subject out of focus. You can also blur out the background of your photo by using a long telephoto lens. There is no hard rule on how long your lens should be but the longer its reach, the more pronounced the bokeh is going to be.
How can i change the exposure time on my pentax istD digital slr to get motion blur etc.?
OK that was a lame answer up there! If you want to add motion blur to your photographs there are several ways. There are two main motion blurs that can be achieved. One is the background blur to give your subject a fast motion feel while being able to identify your subject, like a race car. The other is subject blur to give a motion effect to your subject. NOW THE FUN PART - Doing it. The first one is the panning technique, set your camera for the proper exposure for your subject, frame your subject, as it passes by shoot and pivot at your waist while following the subject in the viewfinder, avoid up and down movement, with practice you will figure the right exposure and movement to achieve this blur effect. The second is the subject blur, this is simply adjusting your shutter speed and exposure to allow your subject to pass by with the shutter open long enough for it to leave a blurred image.
1helpful
My canon powershot SX100 IS has image stabilizer, but apparently I'm not using it properly. All my pics, even stand still pics, turn out blurred. What am I doing wrong? My sons graduation pics were ruined,...
Image stabilizer (IS) will help you stabilize your shaky hand when photographing static object in dim light environment. When photographing moving things such as humans, camera IS will not and cannot not freeze them unless you use high shutter speed. If your camera allows high ISO and manual shutter speed setting, experiment indoors with it. Just remember, high shutter speed freezes motion and IS can only steady your shaky hand for so long. Tripod can only steady your camera not the subject if the subject is a human being.
Blurry pictures in Sports Mode
Well, Sports Mode is a fully automated mode, which I believe tries to balance the exposure toward faster shutter speeds. An over all dark photo indicates an underexposure. You can adjust for underexposure by dialing in a 1/2 stop or so on your exposure compensation dial.
However, dark AND blurry indicates that you just didn't have enough light. The first thing you want, for that same shooting situation, is some faster film. Go up at least an f-stop or two (eg, if you're shooting with ISO 100 film, try ISO 400).
Pay attention to the shutter speed the camera is setting. If you're stilling still, photographing action, you'll want a pretty fast shutter speed, or you WILL get blurring. I'd recommend at least 1/250th second, faster still if you're trying to freeze motion.
A more advanced technique is to pan with your subject. Follow the subject with the camera, and use a medium to medium fast shutter speed (1/60th-1/250th). You will get some blurring, but if you learn this well, your subject will be pretty clear, and the background will blur... thus including the suggestion of speed in the final photo, rather than something that looks frozen. That can deliver a much more satisfying shot.
I have used Canons for years, but I avoid all of the those special modes, like sports modes. They're really trying to deliver some help, but these are techniques you should learn in any basic photography course.
If you set the camera to Av mode, you can choose the widest aperture available for that lens, which will always get you the fastest possible shutter speed -- thus, the least chance of blurring. If you still blur, you need more light, a lower f-stop number, or faster film.. those are the only cures.
Top Canon Cameras Experts
old marine
old marine
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Canon Camera Expert? Answer questions, earn points and help others
