SYMPHONIC 19" LCD MODEL # WF15L5. SERIAL # J12692150
PURCHASED THIS TV FROM REX IN 7/24/07. WHEN TURNED ON IT IMMEDIATELY GOES OFF WITHIN SECONDS!
  • 1 more comment
  • Anonymous Mar 02, 2008
    i have the same problem...within minutes after turning the tv on it will just turn off.
  • Anonymous May 27, 2008
    Same problem turn tv on and shuts down within seconds. symphonics WF15L5
  • tmtripp Nov 21, 2008
    same problem. Is it worth fixing?
SOURCE: Tevion 19 LCD TV Model Number 1961HDT
eh, that should be 0871 663 1540
Posted on Jun 25, 2008
SOURCE: 8 month old Symphonic 20 inch lcd tv turns off itself every 3-5 seconds
I have the same problem with mine and its 5 years old I took it apart cause i blew a fuse. I fixed the fuse and got this problem. So my fix was take the tv out back and put 43 7.61mm round in it. The tv is really messed up now but I feel a lot better and know not to buy symphonic any more.
Posted on Sep 13, 2008
SOURCE: ssl2006 sylvania TV goes dim and turns off within 5 seconds when turned on
There is no audio out, to hook up surround sound. Does anyone know how to deal with this problem?
Posted on Oct 24, 2008
SOURCE: My TV is going into standby mode whenever it is turned on
My screen turns black and the TV goes into standby mode (I get an Amber Light) within 3 seconds after turning the TV on.
Posted on Jan 08, 2009
  • 1632 Answers
SOURCE: New Samsung LCD TV won't turn on or off
This is the best solution for your problem as a 40 year experience with wires etc. Go to the source of your cable signal connector . Open it and clean the terminals with emery paper , sand the end of the cable shiny clean from corrosion , get a new barrel connectors with gold terminals if possible lengthen the ends of the cable , insert and tighten good, use thick rg-16 or rg 40 cable with good insulation ends crimped professionally with a crimpier or buy ready made , not from dollar store. Get a gold plated professional splitter if you need one or two , it will cost about 15 or more each . Make the cable runs as short as possible, using the thick good cables. If needed get a signal magnifier. From radio shack or the source etc. Connect them good and tight . Ground the splitters . Problem solved , you will get crystal clear channel 2 to 7 including 3 and 4 . Isolate the TV cable from other cables and power wires. Vitally
Posted on Apr 15, 2010
Symphonic wf15l5
No. It is not digital.
Aug 18, 2013 | Televison & Video
I just purchased a brand new M420nv 42 HDTV LCD LED and turned it on for the first time & the screen was white with blue vertical lines (very similar to a UPC bar code) on the left side of the screen. ...
For sure a defect. You are looking at a T-con board that is faulty. Return immediately and get a different one. If it's within 30 days just swap out and avoid having to wait for a warranty repair!
Please rate if this helped :)
Mar 09, 2011 | Vizio m420nv 42 in. LCD HDTV
I also have a 19" Symphonic tv vcr combo which
The problem is with the vcr section, it is stuck in eject mode thinking there is a tape. This a mechanical problem that might be repairable. The tv and vcr share some of the same circuits, you can try resetting the tray in the out position as if it fully ejected the tape. Now if this does not work it means you have a gear timing problem or bad sensor.
Dec 23, 2010 | Symphonic SC319C 19 in. TV/VCR Combo
Can I buy a remote for Symphonic TV, model SC3819?
sure you can check out partstore.com they have original remote for your tv.good luck.
Feb 27, 2010 | Symphonic SC319C 19 in. TV/VCR Combo
Stand
You would need an actual wall mount bracket for your TV. Here is a link that you should be able to find what your looking for.
http://www.mountsandmore.com/TV-Mounts-C135.html?refid=OV81.tv+wall+mount
Mar 12, 2008 | Televison & Video
Blank screen during game play
Is there another input you can try?
Mar 21, 2007 | Symphonic ST427FF TV
Televison & Video Logo
224 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
