Question about Roper RS22AQXKQ Side by Side Refrigerator
Ice maker not making ice
My roper refridge ice maker will not make Ice unless I pour water into the spout. I getting water from my water source to the refridge, just not to the ice maker.
  • 283 Answers
The fill tube could be frozen. Gently use a hairdryer. If not you have to check the fill valve coil in the back to see if it's getting power. If it is replace the valve. if not check wiring connections etc. If there's no power out of the Im to the valve, replace the IM
Problems with water are most common tho. Please rate this
Posted on Jan 23, 2008
Ice maker is not getting water,
Hello
Either the ice maker makeup water tube is frozen or the solinoid timer for water is broken.
Try running a hair dryer near where the water comes through the refridge wall to the ice maker,this will remove any ice blocking the water from coming in.
Sep 10, 2011 | Refrigerators
Not making ice
There are several possibilities for this and the dual water control valve is one of the possible problems. Try pouring tap water into ice maker tray if no cubes are present. Allow it to freeze and if the cubes drop then the water control valve part Click Here=> 2188542-1 Then you have a possibility that the ice maker thermostat is at fault item number 27 in photo here=> 627985 Ice Maker Thermostat Sometimes the problem is located inside ice maker and buying new makes it more worth the cost than the cost of replacement parts. This is the Replacement and parts here=> 4317943 Complete Ice Maker
If you need additional help I can be found here or here=> Appliance 911, Thanks Sea Breeze
Oct 09, 2010 | Roper RS22AQXKQ Side by Side Refrigerator
Ice maker quits working
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
poptypty
May 23, 2010 | Roper RS22AQXKQ Side by Side Refrigerator
Looks like water dripping from frezzer, but there isn't an ice maker hooked up in the freezer. top refridge shelf covered with water and ice
you have a blocked drain.i use a steamer to clear the drain,they cost around 50 bucks,take off the back wall.melt out ice with hair dryer,crack out as much ice that you can with plyers or hammer,gently hit it and it will crack out if the floor is a sheet of ice and a putty knife comes in handy,when you melt out and remove ice stick the tip of steamer in drain and clean the drain out,hit it for 10 seconds then stop wait a minute and hit it again,you don't want to damage the drain line it's plastic so take your time,pour hot water down drain to make sure it's clear you might have to use hair dryer and heat up the inside of ceiling in the fridge section in the middle of back wall and ceiling where the drain is, the air ducts are there also,whenwater stops dripping you'll know you melted all the ice,good luck
Jan 23, 2010 | Roper RT18DKXKQ / RT18DKXKT Top Freezer...
GE refridge icemaker won't work
The ice maker unit give the command to the water valve to relese water for a short time.
you cna check with volt meter on the water volve that got the pip go to the ice maker unit if it getting 120V for short time when the fingers of the ice maker making full round.
if you get 120v the problem is the valve (the ice maker and the water have difrent water path so its difrent valve used) if you dont get 120v or the fingers of the ice maker not turning then its your ice maker unit need to be replace.
I hope you find this Very Helpful and best regards!
Jan 03, 2010 | GE Refrigerators
My roper side by side ice maker does not work. I replaced the part on back which directs water to the ice maker and water through the door. I get water through the door, but ice maker still does not work....
Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
See if the ice maker starts working when it dumps the ice.
Sep 28, 2009 | Roper RS22AQXKQ Side by Side Refrigerator
Ice maker is not making ice...no water to tray, but.ice maker motor works
there may be a sensor in the bin where the ice cubes drop into. It tells the ice maker when the bin is full so it stops making ice. Check to see if that sensor got bumped or moved or needs to be reset
Jul 07, 2009 | Roper RS22AQXKQ Side by Side Refrigerator
Ice maker isn't getting water. Water works on door, and line from ice maker has water in it, just not all the way to the ice maker
Icemaker is probably bad. If ice is in mold it is bad. If not, pour some water in it and see if it drops cubes after a few hours. If it does then fill spout to i/m must be frozen up- thaw it out. Common for i/m to go bad. Please contact me if you need further help or leave feedback if appropriate as that is how I get paid. Thanks for letting me help you!
Nov 30, 2008 | Maytag MSD2756G Side by Side Refrigerator
Water Doesn't get in
Once you get the ice maker solid block cleaned out, you need to re-prime it by pouring in fresh water using a cup to just below the blades. It will not kick out ice and refill until the temperature sensor senses the frozen ice. With no water in the tray, it can't sense. It must dump to trigger the refill.
May 29, 2008 | Roper RS25AEXLQ Side by Side Refrigerator
Roper RS22AQXKQ Side by Side Refrigerator Logo
141 people viewed this question
Top Roper Refrigerators Experts
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a Roper Refrigerator Expert? Answer questions, earn points and help others
