Question about Canon S200X Ink-Jet InkJet Printer
Blurred printing result..
Hye..i've done all the printing maintenance 4 my printer i255..but printing results still have a problem..1st line ok..2nd line blurred..its alternate till end of printing..please help me..
  • cherter May 07, 2008
    put in new ink cartridges but print s still very small and blurred
Ddd
Posted on Jan 30, 2008
Copy result is blurred
Does the printer scan OK?
Is the platen glass clean?
Dec 10, 2013 | Epson ME OFFICE 620F MULTIFUNCTION INKJET...
The black ink in my mp258 canon printer is blured how can i fix it
Try a few print head deep cleanings if that does not help then you could try soaking the print head in a shallow plate of hot distilled water. Soak the tip of the print head only in no more than 1/8th to 1/4 inch of water.
Jan 16, 2013 | Canon MP250
My hp 6500 won't print black. I've changed the cartridge twice. No result. Can the ink not be getting to the printer head?
Unplug the printer for at least overnight. I have 3 of these printers and all 3 have done this. All 3 came back after being unplugged for a long period.
Personally, I think a class action suit might be in order.
Nov 19, 2011 | HP Officejet 6500 Wireless All-in-One...
My canon Pixma MP620 wont print in black. All the other colors are fine. I've tried deep cleaning with no results..
Try this;
- Open the document you want to print - Go to file > Print - click properties in the print window - in the menu select 'Maintenance' - in the 'Maintenance' click 'Ink Cartridge Settings' - select Black Only - click OK - click OK - now you can print only using the black ink in the printer.
Hope this helps.
Please rate if this solution was helpful. thanks!
Jul 14, 2011 | Office Equipment & Supplies
I HAVE LOST CANON I255 PRINTER SOFTWARE. CAN I PRINT FROM THE COMPUTER WITHOUT USING THE PRINTER SOFTWARE? IF THIS CAN BE DONE, PLS TELL ME STEP BY STEP PROCEDURES. THANK YOU
You must install driver software for your printer.Here is the adress to download your driver http://www.nodevice.com/driver/i255/get32889.html
Feb 09, 2011 | Canon i255
How to do a print test on canon mp460 printer after replacing cartridge?
Print the nozzle check pattern to determine whether the ink is being ejected properly from the FINE Cartridge Nozzles. Use this function when the printed results are blurred or the color is incorrect. sikaku.gif Performing Maintenance 1 Press [ON/OFF] to turn ON the machine.
2 Press [Menu].
3 Display the Maintenance screen.
(1) Use [l_mark_s17.jpg] or [r_mark_s18.jpg] to select <Maintenance/settings>, then press [OK].
The Maintenance/settings screen is displayed.
(2) Use [l_mark_s20.jpg] or [r_mark_s21.jpg] to select <Maintenance>, then press [OK].
The Maintenance screen is displayed.
(3) Use [t_mark_s23.jpg] or [d_mark_s24.jpg] to select the setting item, then press [OK].
The setting screen for the selected item is displayed.
sikaku.gif Printing The Nozzle Check Pattern 1 With the machine ON, load a sheet of A4- or Letter-sized plain paper in the Auto Sheet Feeder.
2 Print the Nozzle Check Pattern.
(1) Display the Maintenance screen.
(2) Use [t_mark_sas25.jpg] or [d_mark_s26.jpg] to select <Nozzle check>, then press [OK].
The pattern print confirmation screen is displayed.
(3) Use [t_mark_s28.jpg] or [d_mark_s29.jpg] to select <Yes>, then press [OK].
The nozzle check pattern is printed.
Mar 31, 2010 | Canon PIXMA MP460 All-In-One InkJet...
All colours and black print faded. Black is a
ANSER #1
Assuming that you are using original Canon cartridges or a brand of Compatibles that you have used before.
If print results are blurred, colors are faded or not printed correctly, the pint head nozzles are probably clogged.
Follow the procedure below to print the nozzle check pattern, check the print head nozzle condition, then clean the Print Head. You may have to do this 2 or 3 times.
If printed ruled lines are misaligned or print results are otherwise unsatisfactory, aligning the Print Head may improve print quality.
Caution Do not rinse or wipe the Print Head and ink tanks. This can cause trouble with the Print Head and ink
tanks.
Note Before performing maintenance
Open the Top Cover and make sure that all lamps on the ink tanks are lit red.
If not, see Checking the Ink Status and take an appropriate action.
Increasing the print quality in the printer driver settings may improve the print result.
Sep 30, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
Blurred printing printer i255
Hi, check the nozzle and test , if the result not in solid color there are spaces within the color means need head cleaning after head cleaning twice test print .
Jan 23, 2008 | Canon PIXMA iP1500 InkJet Photo Printer
Print result at 1st line ok..2nd line become blur..its alternate till end of printing
Replace the ink cartridge.
The cartridge is so wide that it can print 2 lines at a time, and the upper part of it is probably partially clogged. That's why every 2'nd line is blurred, and the rest is ok.
Jan 17, 2008 | Office Equipment & Supplies
Canon S200X Ink-Jet InkJet Printer Logo
237 people viewed this question
old marine
old marine
