Question about Kyocera Finecam SL400R Digital Camera
Battery life My SL400R Kyocera camera depletes the charge of a fully charged new battery in about 60 seconds and shuts off. It seems to have a direct short. Help!
I bought a few SL400R.. yes I think this is the best camera ever. The battery that came with the cameras always would last very short time, especially in cold weather. But when I ordered new ones online, these would last very long. The specs of the new batteries are the same as the original ones. Go figure. After that I ordered external charger too, so I dont need to use the camera's built-in charger. Works very well.
Posted on Mar 20, 2009
Battery depletes after 60 seconds
I'm afraid that the battery you bought as new, in fact is a battery that was in the shop for years, and can't hold enough power.
If you camera works normal for one minute and does not run hot or even gets warm, I think the battery is not as good as you think.
Can't find since when the camera is around, but my guess is the camera is not that new anymore.
Please recharge the battery and use it, and than recharge it again It could take a few charge cycles, before the battery gets its full capacity, but don't expect wonders.
Nov 17, 2013 | Kyocera Finecam S5R Digital Camera
Power schemes battery
Chances are that your battery doesn't / wouldn't hold a charge anymore. The laptop runs off battery power. When it is plugged in, the AC power "goes right through the battery", to support the laptop's operations. When the power cord is unplugged, and the battery doesn't hold a charge, the laptop will shut down, as your battery is (too) low to continue supporting the laptop's operations.
The easiest way around this problem is to get a new battery for the laptop.
If your battery is (quite) new (and a Lithium battery), you may wish to see if you can "revive" the battery's "life" ... first by depleting the battery (completely), then charging it (until it shows it is full, plus a couple more hours), and repeating this process a few times. If you're lucky, the battery will slowly/gradually start to hold some charge, but, don't expect it to be very long.
The (preferred) way to use re-chargeable batteries is to charge it fully, unplug it from the external power source, use it until it is depleted, then plug in the external power source to charge it up (fully) again .... and NOT to keep it on a power source all the time.
Oct 26, 2013 | Lenovo G500 59373039 Intel Core i5-3230M...
Battery will not charge
li-Ion batteries have a bad habit: whenever fully depleted, they lose a few cells, to the extent that they might not be able to hold a full charge if enough cells are damaged. In other words, repeatedly using a laptop (or any other Li-Ion powered device) to battery depletion can shorten the battery's life significantly. You might want to keep the batteries fully charged whenever possible and avoid fully depleting them too often.
There is also the habit of "re-setting" the batteries by using the "fully deplete-fully charge" procedure. It only applies to niMH or NiCD batteries ( and is used to erase the "memory effect" ) but is damaging to Li-Ion batteries for the reason mentioned above.
so if your battery can not full charge,this mean you need change a new battery for your laptop
Oct 05, 2012 | Computers & Internet
My camera halts after 20 to 60 second while on shooting mode. I have changed its SD card but problem not resolved
This is not to do with the memory but can be errors inthe servo of the camera. Make sure the battery is fully charged and try each functions one by one to make sure which particular function is out of sync for example like the auto focus, the zoom drive, the shutter speed. or the switch on.
If any of them seems irrregular then you might need more help within.
Sep 21, 2010 | Kyocera Finecam M410R Digital Camera
How should i store my poetable dvd player battery?
Store it full charge. If you store it low charge, then battery life will be compromised. Research and tests have proven that storing batteries full charged will extend its life. Also make sure that you charge stored batteries every 3 months to further extend its life.
Nov 08, 2009 | Sony Televison & Video
Loosing power randomly
how old are the batteries and how many times they were charged without being fully drained can cause a short life for the battery. Try a new battery-fully charging it properly, but dont charge it again till it goes off by itself completely. If you have a wall charger, plug your phone in. If it stays on that way, check your 'power save' settings. That can also make your camera shut off. Try these steps first and see if it changes the 'battery' from being empty to full and stays on. hope this helps
Aug 24, 2009 | Sony Cyber-shot DSC-W170 Digital Camera
I was given a nice sony handycam camcorder. i was told the battery is probley dead
Batteries have a limited life even if they are constantly charged.
Leaving batteries in constant charge will limit their life by causing gas leakage. Once depleted, they must be replaced. There is also a small button battery that keeps unit memory up, if you do not use camera for months at a time, replace this battery also.
Ni-Cad batteries need to be refreshed ony once a month by discharging them fully, then recharging them fully for best performance to erase memory effect
May 01, 2008 | Sony Handycam CCD-TRV37 Camcorder
My camera won't charge
I've got same problem - cant charge the battery. Plug into charger, kyocera red light comes on momentarily, then goes out.
Jan 06, 2008 | Kyocera Finecam SL400R Digital Camera
Hi, This might be a case of the defective batteries (though brand new). Most if not all rechargeable batteries including Li-Ion batteries have only so much shelf life. The unit might be new but have been with the dealer for sometime. Probably your best bet would be to bring it back to the dealer and ask for a replacement camera or at least the batteries. Show him the fully charged indicator and how quick it will be gone when you try to take a pic. Of course, you would need your warranty card, proof of purchase and any other documents normally asked for complaints like this, Hope this give you an idea. Good luck and kind regards.
Aug 20, 2007 | Polaroid I739M Digital Camera
Kyocera Finecam SL400R Digital Camera Logo
166 people viewed this question
Top Kyocera Cameras Experts
Iqbal Husain
Iqbal Husain
Are you a Kyocera Camera Expert? Answer questions, earn points and help others
