Question about Konica Minolta magicolor 2400 Laser Printer
Faded left hand copies
Someone gave me a Minolta Color Pageworks Plus printer. I have been changing cartridges whenever it indicates low ink on any one particular color. However, having recently changed my black ink cartridge, it is still printing paper with the left side of the copy faded out.
How do I go about cleaning up the printer to get clean copies again?
You may email me at [email protected]
Thanks,
Ken
  • Anonymous Mar 25, 2014
    Copies are light; what is suppose to be on the top of the page is on the bottom of the page.
    Champion:
  • 214 Answers
Pleas check that you inserted the K toner correctly, check, that transfer belt and/or drum cartridge is installed correctli. also check that 2transfer roller, its one big black roller.
Posted on Jan 24, 2008
6ya staff
SOURCE:
Hp officejet pro L7580 printer alignment failed and ink faded
Try the steps below.
Remove the Cartridges ( bottom left side of printer ) and clean the electrical ( golden contacts ) and put them back in.
Remove the Printhead ( Open the Printer cover and you will find the Carriage that moves. Lift the latch and clean the electrical contacts ( golden contacts ) with lint free cloth
Reinstall the Printhead and wait for printer to respond. IT should fix the issue.
Regards,
Sean
Apr 10, 2013 | HP Officejet Pro L7580 All-In-One InkJet...
Epson cx3200 printer has printing problem
Hello cockie ,
You can diagnose most problems by checking the control panel LED's for ink out, paper-out or copier problem.
If a problem occurs while you're printing, you'll see an error message in the progress window on your computer.
It may also be helpful to try running a printer nozzle check.
See the following message problems and solutions:
Error Message Probable Cause No color or black ink cartridge - - >
Press the Color Copy button to install a new ink cartridge.
The indicated cartridge is not installed or it is installed incorrectly. Color or black ink out - - >
Press the Color Copy button to begin replacing the ink cartridge.
The indicated cartridge is out of ink Ink cartridge error - - >
There is something wrong with the ink cartridge. Paper jam or misfeed - - >
Press the Color Copy button and clear the paper jam by hand if necessary.
Paper is jammed. Press the Color Copy button to clear the jam.
See the User's Guide for more troubleshooting tips.
Paper out - - >
Load paper in the sheet feeder and press the Color Copy button.
Paper is out. Load paper in the sheet feeder, then press the Color Copy button to continue printing. Scanner unit open - - >
Close the scanner unit.
Scanner cover open. Carefully lower the scanner cover and press it down until it clicks securely into place. Scanner error - - >
See your documentation and call Service if necessary.
Press the On button to turn off the EPSON CX3200. Check the transportation lock and unlock it, if necessary. Turn on your EPSON CX3200 again. If the error message still appears, contact your dealer or EPSON. Printer error - - >
Press the On button to turn off the EPSON CX3200, then press it again to turn it back on. If the message still appears, contact your dealer or EPSON.
Mar 23, 2008 | Epson Stylus CX3200 All-In-One InkJet...
Black print is faded on my HP deskjet 6980 printer. Whenever I print a word document it will have sporadic fading. It will be fine in one place then all faded in another. I've cleaned the cartridges and...
Here are some steps you can check to resolve your issue.
Check if the ink cartridges are low, specially the color black since if the black is empty, you are using the colored cartridges to print black. If the cartridges are newly replaced check the cartridges by reseating it. Try to consider changing the print quality high but doing so will use more ink. If still the same try to clean your printer heads.
Here are the instruction for cleaning your printer.
Open the printer tool box. (open a word, then click on file then print, choose properties, then services)
click on clean the print cartridges, then clean. Do test printing as well to check if the color is correct. If still the same calibrate the color which can be found in the same menu.
For more information here is the link for step by step instruction with visuals.
Hope this will help you resolve the problem.
Thank you for choosing fixya
Mar 03, 2011 | HP Deskjet 6980 InkJet Photo Printer
How to check the ink level onC4480 printer
To check the ink levels from the HP Photosmart Software
1. In the HP Solution Center, click Settings, point to Print Settings, and then click Printer Toolbox.
NOTE: You can also open the Printer Toolbox from the Print Properties dialog box. In the Print Properties dialog box, click the Features tab, and then click the Printer Services button.
The Printer Toolbox appears.
2. Click the Estimated Ink Level tab.
The estimated ink levels for the print cartridges appear.
Or
Print a self-test report
1. Load A4 unused plain white paper into the input tray.
2. Press and hold the Cancel button and then press the Start Copy Color button.
The product prints a self-test report, which might indicate the source of the printing problem.
3. Make sure the test patterns show a complete grid and the thick color lines are complete.
• If more than a few lines in a pattern are broken, this might indicate a problem with the nozzles. You might need to clean the print cartridges.
• If the black line is missing, faded, streaked, or shows lines, this might indicate a problem with the black or photo print cartridge in the right slot.
• If any of the color lines are missing, faded, streaked, or show lines, this might indicate a problem with the tri-color print cartridge in the left slot.
Nov 30, 2010 | HP PhotoSmart C4480 All-in-One Printer ...
Having trouble fitting new ink cartridge
Hi, when an ink cartridge runs low in your HP Officejet 5610 All-in-One printer, you will see a message on the printer's display screen. Faded-looking text or pictures also indicate low ink. Ensure print quality by replacing ink cartridges when they run low.
Instructions
Things You'll Need:
* HP #27 or #56 black, #22 color or #58 color photo print cartridge, or compatible equivalent
Turn printer on if it is off. Never attempt to change the ink cartridge if the printer is off. If it is off, it will not properly position or release ink cartridges, and attempting to change the ink cartridges may damage the printer.
Open the print-carriage door, located on the right side of the printer. The print carriage will automatically move into the access area.
Push down on the top edge of the cartridge you are replacing to pop it out of its slot. Remove the print cartridge and discard or recycle.
Pull off the protective tape on the new print cartridge using the pink tab. Do not touch any part of the cartridge except the black plastic. Touching the contacts or ink nozzles under the protective tape can damage the cartridge and result in poor print quality.
Hold the cartridge upright and push gently forward into the empty ink cartridge slot until it clicks.
Close the print-carriage door.
You can also use this video clip to learn more:
youtube.com/watch?v=wVXUndG-o_Q.
Please don't forget to rate me thanks.
Thanks for using fixya...
Oct 26, 2010 | HP Officejet 5610 All-In-One InkJet...
Getting
Hi there
Your error message is coming from the Dell Series 5 ink Cartridge. To reset the error message, unplug the printer from the wall. Now remove the power brick from the back of the printer. Wait 60 seconds and then plug everything back in. This usually resets any error messages on the printer. Make sure the Dell Series 5 ink cartridges are intalled correctly by removing them and re-seating them .
Black in left or black side, color in right side or color side
If using a photo cartridge...
Photo cartridge in the black side(left) and color in the color side(right)
Dell Series 5 ink cartridges have a sensor in them that cannot be reset
It is also possible to get a new ink cartridge with a bad sensor. Please take it to the place of purchase for a refund or a replacement one.
Please all I ask is call back and just gave a vote, it will gave me some satisfaction to know am helping some one, so I will keep on helping.
All The Best: Pineworks
Jan 14, 2010 | Dell 962 Photo All-In-One InkJet Printer
Polling the ink cartridges for available ink level.
http://files.support.epson.com/pdf/r220__/r220__pg.pdf
then click on replacing ink supply, and the first box down tells you about ink cartridge levels.
There you go Utah
Please leave rating...thank you kindly
May 10, 2009 | Epson Stylus Photo R220 InkJet Printer
Faded coloring
Clean off the bottom of your color cartridge with a slighty damp tissue to make sure the whole doesn't have ink stuck in it. If that doesn't work then its possible the ink has dried up in the cartridge and youll have to replace it. How old is the color cartridge and do you print often with it? If so if could be running low.
Feb 05, 2009 | Lexmark X1270 All-In-One InkJet Printer
Error inkcartridge
Error message: No color or black ink cartridge-->Press the Color Copy button to install a new ink cartridge.
Solution: The indicated ink cartridge is not installed. Please install the necessary cartridge(s).
Error message: Color or black ink out -- >Press the Color Copy button to begin replacing the ink cartridge.
Solution: The indicated ink cartridge is out of ink. You will need to replace the necessary ink cartridge(s).
Error Message: Ink cartridge error -- > Press the Color Copy button to begin replacing the ink cartridge.
Solution: There is something wrong with the ink cartridge. Make sure the cartridge is genuine Epson ink. Also, try reseating the cartridge (remove it, and then reinstall it).
Error Message: Paper jam or misfeed -- > Press the Color Copy button and clear the paper jam by hand if necessary.
Solution: Paper is jammed. Check for any obstructions under the unit's cover, and in the paper tray.
Error Message: Paper out -- > Load paper in the sheet feeder and press the Color Copy button.
Solution: Load paper in the sheet feeder, and then press the Color Copy button to continue printing.
Error Message: Scanner unit open -- > close the scanner unit
Solution: Carefully close the scanner and press it down until it clicks securely into place.
Error Message: Scanner error -- > See your documentation and call service if necessary.
Solution: Press the ON button to turn off the Epson Stylus CX3200. Unlock the transportation lock, if necessary. If it is already unlocked, toggle the lock back and forth, 5-10 times. Turn on your Stylus CX3200 again.
Error Message: Printer error -- > See your documentation and call service if necessary.
Solution: Press the ON button to turn off the Epson Stylus CX3200. Disconnect it from power, and then reconnect it to power. Press the ON button to turn on the Stylus CX3200
Nov 28, 2008 | Epson Stylus CX3200 All-In-One InkJet...
Print problem
Have you tried replacing the ink cartridge?
May 01, 2007 | Minolta magicolor 2200 DeskLaser Printer
Konica Minolta magicolor 2400 Laser Printer Logo
173 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Clive
Clive
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
