Question about Dell W4201C 42 in. Plasma HDTV
Dell 42" 1080i plasma issues after TV warms up
I have a 42" plasma purchased in early 2005. The TV powers up and works fine until it warms up, at which point the screen gets staticy and zig zag lines on it. Any ideas on what could be causing this and how I can fix it?
  • hemi517 May 14, 2008
    Mine does something similar. After 30 min. it starts flickering, esp. with bright/white backgrounds. Any ideas?
    New Friend:
  • 90 Answers
The power board needs to be inspected. you need a t20 torx bit, and phillips screwdriver. do not work on unit around carpet. stay away from need a digital multimeter as well. remove back cover, and set meter to VDC. take black probe, and stick in one of the upper holes. look at the top right of the panel for a white sticker. this gives the proper voltage readings. on the power board, located middle top (big bd) look for the vs, vset, va, vsc settings on pow bd with red probe, test each one for proper voltage if 2 or more mismatches, the power bd needs replaced. do a ebay search for bd id number located on bd or simply type dell 4201 power bd.
Posted on Apr 13, 2009
Color splotches
I had same problem, or should I say I still have it, slowly getting worse, and I had replaced the Y board which would be logical based on description of what board controls, but it didn't help. I found out it is the plasma screen, and not worth replacing, so I put up with it until picture is all full of shadows, then will part it out. Last time I had issues with capacitors a few years ago, I spent $400. on several boards, including Y board trying to isolate problem, that is how I learned it didn't help the shadows creeping in after warming up. Live with it or buy a new TV is what I am doing.
Sep 08, 2014 | Dell W4200 42 in. HD-Ready Plasma...
Tv blinks until it warms up
Gateway does not offer much in the way of parts or service information--I would suspect the power supply which could of course be checked to see if voltages remain stable or change after warmup.
Other than that the main board is next in line.
Jun 11, 2012 | Gateway PLSM50TV 50 in. Plasma Television
I have a 52 inch Magnavox Plasma TV that was purchased 4 and a half years ago. It is mounted on our wall in our family room. Recently we had issues with the tv warming up and not turning on right away. The...
The problems with ur tv is the power supply board,it dead.That the board,where the power a/c plug in to it.Try website like to buy a refurbish power supply board for the replacement.
Dec 11, 2010 | Akai PDP4294 42 in. EDTV-Ready Plasma...
Can't turn on TV
Since when does 2 years equate from purchase date of 2008 and the date at present 2017.
Probably a power supply issue caused by leaky capacitors.
Apr 04, 2017 | Samsung HPT5054 50 in. HD-Ready Plasma...
Dell plasma 42 inch
fot the most part, you have solved your problem (pow bd), The main bd may also need to be replaced as well. The is a signal upon powering up the system. the pow bd communicates with the signal board. The signal bd, also is responsible for ALL of your additional I/O lines. Between the two of these, + a firmware update, i think the tv will be just fine.
Feb 03, 2009 | Dell W4201C 42 in. Plasma HDTV
Dell W2600 Power Issue
may be dlm board is the culprit
Mar 06, 2008 | Dell W2600 26 in. LCD Television
5071HD switch, power supply problem??
Pioneer recommended a firmware upgrade for the repeating twelve blue led blinking and remote issue you specifed.
Feb 29, 2008 | Pioneer PDP-5071HD 50 in. Plasma HDTV
"No Signal" floating notice on Blue Screen - No other picture
If all connections and the tuner have the same issue, you either have a power supply issue or a bad digital board.
Mar 29, 2007 | Sampo PME-42S6 42 in. HD-Ready Plasma...
Dell W4201C 42 in. Plasma HDTV Logo
160 people viewed this question
Top Dell Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Dell Televison and Video Expert? Answer questions, earn points and help others
