Question about Mitsubishi WD-52525 52" Rear Projection HDTV
Mitsubishi wd-52525 no picture or sound
First had flickering bluish screen with message check power connections and component inputs. did that, all appear normal, unplugged for one hour now no picture at all and sometimes get solid red led. checked bulb which was replaced in july 07 appears ok.
  • 1 more comment
  • Jimhollywood Jan 23, 2008
    I am experiencing the exact same issue. All of a sudden on power up, blue screen with words at bottom stating to check power and connections. Did system reset, nothing. Removed bulb and reinstalled, picture started to flicker then solid red LED. Replaced with new bulb, no joy. It still states the same input issues as before. What next, a $220 house call just to diagnose? HELP!!!!
  • btajr Feb 04, 2008
    took tv to authorized mitsubishi shop for them to check and repairon 1/25/08. they had it repaired by 1/30/08. report said they replaced two capacitors on power supply. charge was just over $200. picked up 2/1/08, tv operates great. got to watch super bowl on the big screen. life is good again!
  • holziee Mar 06, 2008
    I also have a WD-52525 that I have had for 2 years now. Turned it on today and it said check connections or power. It also said RGBHV or PBrPb may be invaild- hopefully that is the same as you and all it will need is a $200 fix.
    President:
  • 4,402 Answers
Http://www.chrisandnat.com/Projects/BlinkingTV/blink.htm
http://www.jeremyburns.com/Mitsubishi-Green-Blinking-Light-Fix.pdf
http://www.fixya.com/howto/h159332-mitsubishi_dm_board_repair
http://hdtvoice.com/voice/showthread.php?t=32186
replace DM
Posted on Jan 23, 2008
  • Cary Farah
    Cary Farah Feb 04, 2008
    please mark post as soulution fixya!
Can you help with this error message: "Check connections or power. The connections for RGBHV or YPrPb may be invalid." Getting no picture for any devices connected to the screen.
There is a problem with the Component video cables and/or connection. These are the 5 RCA cables. Red, Blue, Green and two additonal cables for audio in red and white. Be sure they are connected to the proper ports on each end. Not sure what you have connected to the TV with these cables, but HDMI would be best. You also should have selected "Video" from the Input button on the tv's remote. Check these and follow up if possible.
Jun 30, 2010 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD 52525 blue screen on all inputs
Hi and welcome to fixya, it is the colour wheel problem,,,,,,,,,this is common problem please check it ...it may be also cathode ray tube... thank u.........
Jun 03, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Error message: check connections or power-the connections for RGBHV or YPrPb may be invalid. The screen is a two tone blue and is flashing.
DO NOT do anything to your Mitsubishi WD-52525 until you read this forum overseen by a Mitsubishi certified repair technician: http://www.hometheatershack.com/forums/mitsubishi/11703-problem-mitsubishi-wd-52525-scrambled-picture-no-picture-2.html . There has been a worldwide problem in computers and TVs over the past several years with faulty electrolytic capacitors (from Taiwan) that decay, dry out, swell and die. The power supply is often the first component to go bad, but other systems also degrade over time. As the forum explains , this problem is widespread in these sets causing multiple types of display problems after several years of use. Mitsubishi is aware of the problem and will cover most of the cost of repairing the chassis, even years out of warranty, but apparently ONLY if you get an estimate from a Mitsubishi certified repair station and contact their customer support BEFORE doing any work on the set. I just followed the recommended procedure on that forum and Mitsubishi is covering half the cost of my $700+ repair when my 3+ year-old set recently died and showed only a blue screen. I'm not sure if this is your problem, but it might be.
Apr 21, 2009 | Mitsubishi WD-52525 52" Rear Projection...
4yr old Mitsubishi DL 52525, HDMI input vide problem
Are you sure its the TV and not the source? Are you sure its only the HDMI port on the TV? The only reason why you must HDMI is to get 1080p and your TV doesn't support 1080p. Its supports up to 1080i. Your TV has a native resolution of 720p which means it can accept a 720p image and not need to scale it, so the picture will look the best at 720p but will support 1080i. I would use component cables to connect your sources and set them to output 720p.
Mar 20, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Black Screen with White Randomized Pixels
Bad FMT (Formatter) circuit board. No longer available for purchase from Mitsubishi.
The electrical chassis will need to be sent to Mitsubishi for rebuild.
Wait time: 4-8 weeks
Cost (including labor to uninstall it and reinstall it: $800 +)
Nov 09, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Unable to receive input device signal
Can you post a picture of the screen so I can properly diagnose it. It sounds like the caps on the FMT PWB but a picture would help me be certain.
Aug 04, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Flickering screen with semi-circular middle whitish flicker and static sound
Use your warranty, as most warranties are vioded if you open the set up.
Jun 12, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Display problems
Sounds like bad 1000uf capacitors on the FMT board there are 3 100ufs on that board that can cause that symptom
May 09, 2008 | Mitsubishi WD-52525 52" Rear Projection...
WD-52525 flickering blue screen
it sounds like the light engine has failed..since it is expensive it would be a good idea to have a factory trained tech take a look
Nov 25, 2007 | Mitsubishi WD-52525 52" Rear Projection...
Sound but no Picture on all inputs but the RF
No its difficult to change any boards in this model (they're all package together in one module).
Oct 01, 2007 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
387 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
