Question about Philips VR550 VHS VCR
Cassette should my cassette eject at the end of the tape or do i have to do it from the video manually
  • 1 more comment
  • aloa Jan 23, 2008
    cassette is ejected when end of tape is reached
  • aloa Jan 23, 2008
    manual states cassette is ejected at end of tape
  • aloa Jan 23, 2008
    manual states that cassette will eject at the end of the tape
    automaticly it does not has do be done manualy
    New Friend:
    Problem Solver:
  • 8 Answers
If your eject button is busted, simply set the recording timer, ffwd to the end of the tape and press "timer" (or "function") - then it will eject - easy !
Posted on Nov 26, 2013
  • 2,130 Answers
Most VCR's will auto-rewind the tape when it gets to the end of a tape. Most will leave the tape in the unit assuming you may wish to view it again once rewound. Does the tape eject properly when you press the eject button? What does the manula say about the eject function?
- Jim
Posted on Jan 23, 2008
  • SHARCNET-USA
    SHARCNET-USA Jan 23, 2008
    Ok, if it doesn't auto-eject after the end of a tape, does the tape eject properly when you "manually" press the eject button? I am trying to find a common mode of failure. If it doesn't eject manually as well, then there is a problem with the eject mechanism.
2 Suggested Answers
SOURCE: tape ejects when inserting into video player
check the tab on the back side of the tape- make sure its intact- if tab is missing it will not let you record - i've sometimes added tape to replace the tab ,,
Posted on Feb 05, 2009
How do I get a VHS tape out of a Go Video DVD/DCR combo?
you will have to open it up to get it out as the tape might be stuck around the play heads
Oct 23, 2017 | Televison & Video
Sharp video camera VL-AH50
Did you try cleaning the tape head?
Feb 22, 2008 | Sharp Viewcam VL-NZ50U Mini DV Digital...
How can I fix my 2002 Honda Civic cassette player from ejecting cassettes. I tried a cassette deck cleaner and that gets ejected the same.
The auto-eject feature is normally triggered by the tape reaching its end. This causes the tape to tighten and then activates a trip lever that starts the eject cycle. Most auto tape decks that are not auto-reverse eventually have this problem. It is not usually the deck's fault, but it is with the tapes themselves. After many plays the tapes get wound too tight on the reels and drag, causing the auto-ejection. This is especially true with the thinner, larger tapes found in the C-90 and C-120 varieties. Try taking the tapes to a regular tape player and then fast-forward them from one end to the other and them a full rewind as well to loosen the tape on the spindles and re-distribute the tension. Hopefully this will work.
Sep 25, 2015 | Audio Players & Recorders
How do you fix a VCR that will not receive a VCR tape?
If a particular cassette is rejected, the tape could be defective. You will have to open up the cassette to determine whether this is the case. If all cassettes are being popped out, the fault may be the internal mechanism and you will have to disassemble the VCR to find what's wrong and fix it.
Mar 20, 2015 | Televison & Video
Jvc minidv cassette not working display saying end tape does this mean tape has come loose.
End tape means that you have recorded the full 60 standard play or 90 minutes long play and you should rewind the tape or eject it.
Oct 15, 2013 | JVC GR-DVL100 Mini DV Digital Camcorder
Panasonic m7 vhs video camera while in play mode camera stopped and made whiring noise then shuts right down will not eject how do you get tape door open manually
Hi, open eject door,try to see very small lever at the left side cassette at lower end and try to pull it at your side with very thin and at least 4 inch long screw driver.Cassette compartment will open. But its not so easy to find.It need patience.
Aug 10, 2010 | Video Cameras
Hi8 won't eject cassette
There is a broken plastic part inside the cassette and needs to be replaced. Mostly due to cassette tape improper position and camera jam (tape jam).
Apr 03, 2010 | Sony Hi8 CCD-TRV138 Camcorder
My Camcoder says eject the cassette
Use a Sony head cleaning tape they work perfectly and you let them run there 10 second corse. Then your sharp will run perfectly...
Dec 20, 2007 | Sharp Viewcam VL-Z7U Mini DV Digital...
Cassette loading error 31:23
Take the battery out and turn selection switch to camera and then turn it off. Put the battery back in and its working again.
if that doesn't work try
Try smacking the side of the camera relatively hard with the palm of your hand. Eject the tape and reinsert. You may need to do this a couple of times.
Nov 18, 2007 | Sony Handycam DCR-HC96 Mini DV Digital...
Removing dv cassettes manually
open the unit and look for a small motor that ejects the tape through a series of mechanical gears, slides and hinges. Now turn this motor by hand.
Jun 06, 2007 | JVC GR-D270 Mini DV Digital Camcorder
Philips VR550 VHS VCR Logo
425 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
