Question about Intel D845GVSR Motherboard
Restarting..... the motherboard is getting too hot and while playing some of the video the computer gets restarted.......
    Problem Solver:
  • 17 Answers
Try adding fan in your pc;
check your video card if its working properly and has its driver (not the driver define by your OS but the driver from the cd of your video card)
if the video is onboard try adding RAM
Posted on Jan 23, 2008
Dear Sir, I used to play igi2 game regularly but recently it does not open and shows fatal error. How can I restart this game and play regularly?
Hello Sir!
Think in these possibilities
1) Video Driver Update
2) Cooling System of your computer **
3) GPU gets very hot on new games! stay cool!
Hope these hints, helps!
Jun 25, 2016 | Infogrames Project IGI I'm Going In 2:...
Restart problem
The problem will be with your video driver. Try re-installing your driver
Mar 06, 2014 | Intel Computers & Internet
Auto restart
Your machine is rebooting itself while you watch a movie on it? Could be a couple of things. First, is this a laptop or desktop? When is the last time you updated your video drivers? If this is a laptop, does it get very hot just before rebooting?
Theories work like so:
1. older video drivers can be causing a cpu panic condition due to a bug. This is more common with PC games vs. watching movies, but still possible. Updating your video drivers may help fix the problem if that's the cause.
2. heat: if the computer overheats, it will reboot to protect itself. As for why it's getting hot--could be that your video hardware or cpu is getting too hot playing the movie. Could be that your cooling fans are bad. This is why I asked about the machine getting hot.
Another possibility is the need to update either your BIOS or hardware drivers.
Please post more info if you require additional help.
Oct 18, 2013 | Intel Computers & Internet
System restart even playing game gta3
If your CPU or GPU aren't capable of running the game your computer might be overheating. Restarting itself is a safety measure built into the system. Trying checking your computer CPU temperature and make sure its not getting to hot. I use CoreTemp to check things like this. It will show all the info you need for your CPU. Google the CPU model for temperature specs from Intel or AMD depending on your computer. If it seems to be getting hot make sure your fans inside the computer are operating and also blow the dust inside the machine out regularly. Only other thing i can think of is you might be hitting a bad spot in your memory (RAM) but usually that results in a blue error screen then restarting.
Mar 05, 2012 | Microsoft Windows 7 Ultimate 32 bit Full...
Blue screen error and intermittent restart issue
before you update bios, sounds like there is a problem with something getting hot inside your computer. check, proccessor fan. make sure it is working properly and the heatsink is attached correctly. other to check is video card, if it has fan on it, make sure it works. sometimes if you add an extra fan to blow out hot air from case it helps. the computer will go to shutdown if it senses high heat on any of the components on motherboard.
when you resolve this then goto your motherboards manufacturers website and download latest bios upgrade, usually is a self executable file. run it after save to your computer and it will upgrade your bios.
Apr 14, 2009 | Computers & Internet
If you are using the on board graphics this will cause problems due to your 1 gb of ram being shared with the graphics and other things , for most of todays games that will cause many problems, I would suggest getting a video Card or playing older games that the on board graphics can support. The restart usually is a sign the the graphics capability is to low for the game, altho you can tweak your computer to some extent you will always still have problems. Now adding extra ram can always help but still i would recommend getting a video card first that your computer supports.
Hope this helps, let me know if i can further help,,,,larry
Dec 12, 2008 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
My pc keeps restarting everytime i play online game or lan game
Most often restarts during games or other heavy duty tasks are from the following reasons
1.) Lack of power. If your Power supply unit is less than 450W then this is highly likely.
2.) Overheating. If your PC's bios has temperature reading sensors then after it is warmed up open the BIOS by press <Delete> after the logo disappears and go to the entry that informs you of temperature... If your seeing a Temp ove 45-50 degrees Celcius your runnin too hot. Get a better heatsink or other cooling apparatus (ie... liquid cooling or peltier) depending on your budget and your technical skill.
3.) Video card over heating/power issues run the PC with the cover off. Watch your Video card. is the Fan on it spinning? Does you Video card have a seperate power adapter? If so is it Fully seated.
4.) Mismatched memory. the memory adapter you installed does it have the same specifications as other memory that is also in your system. Sometimes if their slightly off and the computer sets the timing for the faster memory instead of the slower memory then the system chugs along at a speed that the slow module cant handle and it fails momentarily.
5.) Driver conflict error. Sometimes an older driver just gets in the way of other devices that want the same resources. (Particularly if you are using the drivers that came with the Video card) Go to Nvidia's website download and install the latest drivers for your card and Operating system combination.
Hopefully these tips will help you get you Fragging in no time.
Good gaming
and godbless
Nov 17, 2008 | Foxconn 865G7MF-SH Motherboard
Problem with intel d101ggc motherboard
Hi Rohit, you're CPU should not be running that hot & that is why you're system is restarting. Very soon the CPU will burn up.
Replace the CPU's HeatSink & fan assembly as soon as possible. The link I have posted is a list of the CPU's you're board can support.
Even at 70'c, that's too hot also. You're game is not putting that kind of load on you're CPU.
May 09, 2008 | Intel D101GGC Motherboard
I'd be leaning towards a hardware problem most likely your video card. Could you post some more specs on your computer eg video card(type, size, slot type) how much ram you have now, what operating system your running, what resolution your trying to run these games at and what options eg anti-aliasing etc. and what size monitor. The extra information will make it easier for me to provide a more accurate solution to your problem.
Nov 01, 2007 | Intel D102GGC2 Motherboard
Getting a blue screen
first off, try just one mem stick in slot 1, if the m/c comes up with bad bios checksum then you have a faulty bios, updating this to v0403 should sort out your problems. oh but make sure when you update you dont have any mem in slot 1 because it wont work. if you still having problems then take it back to where you bought it from and get a different board.
Oct 27, 2007 | ASUS M2N-MX Motherboard
Intel D845GVSR Motherboard Logo
35 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
