Question about GE Spacemaker JVM1640SJ Microwave Oven
GE Profile Spacemaker keeps asking for time date reset and will not operate
I start the oven on any selection oven quits and asks to set time and date. I do so and then when i select any cooking option it starts stops abuptly and wants me to again reset the time date function. I unplugged the unit for a perion of time ,reset the time/date with same results.
  • chuckbb Jan 24, 2009
    Exactly the same issue happening to me. I wonder if chuckmeister had found the solution?
  • Anonymous Mar 15, 2014
    stops cooking after a couple seconds asks for time and date to be entered
    New Friend:
  • 23 Answers
The mag's little cooling fan probably broke loose and fell off the fan motor's shaft. The fan motor will still be running when you hit start but there is no fan on it. The fan keeps the mag cooler. The mag will heat up too much and then shortly the oven automatically shuts everything down when the mag gets too hot because the fan blade is just lying in there, Fan needs to be glued back on the shaft after the shaft is roughed up a little. Disconnect the plug-in wires (note where they go on), wiggle and remove the fan motor from the oven. I used contact cement to hold the fan to the shaft. the fan motor is located right behind the control panel. You have to first remove the grill, then the control panel's screws. It's not difficult to repair. No new parts needed.
Posted on Jun 12, 2013
  • 579 Answers
The power to the unit is drooping (when the heavy microwave load kicks in) causing the reset.
Try plugging it into a different outlet (whole different circuit if possible) and if that works then you have a wiring problem to the original outlet.
Posted on Jan 23, 2008
Thing worked fine and then recently started on this inccessant clock reset thing?
Well the only way to fix it, replace the keypad control board, but consider the cost in parts, it will rival some new microwave ovens.
Apr 09, 2012 | GE Spacemaker JVM1640SJ Microwave Oven
Tip
Profile series kicks out during operation
My GE Profile series Spacemaker Microwave, model JVM2070BH002 after we set the cooking time will kick out after about 3-5 seconds. This is sporatic. It will work for a week and the kick out for 3-4 times.
on Jan 01, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
How do I unlock the touchpad of my Profile 2.0 Spacemaker Microwave Oven # JVM2070
calvin,
If you have access to where your microwave is plugged in, unplug it for a few minutes and then plug it back in. This will reset your contol panel. Then follow your book directions to reset the time on the clock. Hope this helps!
Nov 06, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Ge eterna series - installed above oven. microwave stops working and display instructs to set time and date, then after setting time and date and starting oven again it stops after a few seconds and asks...
The magnetron draws a lot of power and the mains may be dipping beneath an acceptable level, causing the panel to reset.
Check the supply cable size and any connections.
Jan 23, 2011 | GE Microwave Ovens
GE Spacemaker shuts off after a few seconds and asks for the clock to be reset
Ge Spacemaker comes on ok but after a few seconds the noise level goes up significantly and it does not heat. It keeps running until the time runs out but it doesn't heat.
Feb 11, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
The unit is beeping and has a code showing F3
Is it difficult to change a touch pad on my ge profile eterna spacemaker microwave. F3 Error, Bought it new in 2006. Touchpad Part No# WB07X10959 Twinsinger asked.
Feb 03, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
I have a GE Spacemaker model #JVM1650CH01 that keeps on shutting off everything after a few seconds. I have to rest the clock and month -year - date to try again.
my spacemaker xl jvm 1650 microwave shuts down after just a few minutes of operation and after a few minutes needs to have a clock/time/day etc reset. is this reparable by a homeowner?
Oct 19, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
GE spacemaker Power goes off and clock needs resetting
Try going to the breaker box and shutting off the power to the microwave for 10 minutes. After 10 minutes, turn back on and set the clock. This fixed my clock and turntable both. Apparently turning off the power resets the software in the clock.
Jul 22, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Reset clock, ge spacemaker xl1800 times out after 2-3 seconds
There's a simple fix for this. Unplug the unit. Take off the top grill with 2 screws. Remove the 1 screw that holds the touch pad unit. Lift up on touchpad unit and lift out. Put a piece of aluminum foil inside a large zip lock bag and tape it to the back of the touchpad unit and reassemble. GE put the magnetron to close to the control board causing stray microwaves to interfere with the board. The foil shields it.
May 27, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Enter clock and time every usage
It sounds like it is momentarily losing supply voltage, in other words, like unplugging it and plugging it back in. Check your plug in at the outlet to make sure it is tight. If that doesn't help, then a service call may be in order as something may be loose inside the service area.
May 23, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
402 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
vince
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
