Question about Gevalia 25280 / 50304 / 60130 / 50431 Coffee Maker
My coffeepot the Gevalia model above will not brew this mornign
It's plugged in, water is in reservoir, indicator light is on, but the thing won't brew. HELP. There was no warning of any problem. I need my morning coffee.
  • carvey Jan 23, 2008
    tHANKS FOR THE INFO
    Master:
  • 518 Answers
There's a little Thermocouple that can burn out on coffee makers, it's usually mounted by the warming plate. It's about an inch long and looks like a tiny bullet. It's a safety device and should be replaced, not jumped out. Radio shack may have them.
Geno
Posted on Jan 23, 2008
6ya staff
SOURCE:
How to prime
http://www.keurig.com/~/media/DD2E19AE632A45BDAA55D72706420B74.ashx
^^^^ that's the owners manual.
according to it,
LCD Control Center
indicates "PRIME"
and the blue light in
the Water Reservoir
is flashing
Solution:
Completely remove the Water Reservoir and
thoroughly clean (refer to page 14). Ensure
the Water Reservoir is fully filled with water. Return it
to the Brewer and ensure it is seated properly
(refer to page 6).
If you have completed the above procedure two
times and this situation persists, contact Customer
Service at 1.866.901.BREW (2739
Aug 05, 2014 | KUERIG Keurig Platinum B70 Brewing System
Why is my Kuerig B60 coffee maker not filling the correct amount of water. ie. a cup instead of a mug or 2 instead of 3rd level?
Your b60 may need to be descaled. There might be scale built up on the water level probes in you machine. I have listed the directions below:
Brewer De-Scaling Instructions
Brewer Model: Elite B40 ' Classic B44
Special Edition B60 ' Platinum B70
To begin, you will need the following:
• 48 ounces of undiluted white vinegar
• Large ceramic mug (do not use a paper cup)
• Access to an empty sink
PREPARE
Step 1:
Empty the water in the Water Reservoir.
Step 2:
Disable "Auto Off features."
FILL AND CLEAN
Step 1:
Pour approximately 48 ounces of the vinegar
into the Water Reservoir.
Step 2:
Place a large mug on the Drip Tray Plate and run a brew cycle.
DO NOT USE A K-CUP
, just press the BREW Button. Pour the contents of
the large mug into the sink.
Step 3:
Repeat the brew process without a K-Cup until"ADD WATER"
is indicated.
Step 4:
Now let the Brewer stand for at least 4 hours while still on.
Step 5:
Discard any residual vinegar and rinse the
Water Reservoir thoroughly.
RINSE
Step 1:
Ensure the Water Reservoir is filled with fresh water.
Step 2:
water brew cycle. Pour the contents of the
Step 3:
Repeat brew process until "ADD WATER is indicated.
Step 4:
You may need to perform additional water brew
cycles if you notice any residual taste.
NOTE:
If "DE-SCALE" is still displayed after
completing the procedure, repeat the
descaling procedure above.
Apr 14, 2013 | Coffee Makers & Espresso Machines
Keurig b60 won't dispense water
PREPARE
Step 1:
Step 2:
FILL AND CLEAN
Step 1:
Step 2:
DO NOT USE A K-CUP
Step 3:
is indicated.
Step 4:
Step 5:
RINSE
Step 1:
Step 2:
Step 3:
Step 4:
NOTE:
Dec 14, 2012 | Keurig B60 Coffee Maker
Gevalia 12 cup coffee maker slow brewing
The pipes are blocked with build up scale or water dirt. You can try to descale the machine by adding in the water half cup of lemon juice and brew it without coffee leave if for 20 min and the clean it by brew it with fresh water these will make a diference then try this again in a week.
May 16, 2012 | Gevalia CM-500 12 Cup Coffee Maker
I have a Gevalia Kaffe 12 Cup Automatic Coffee Maker (Stainless Steel) Model CM-500B (Black). Date Code: S1710. (Global Marketing Corp. warrants the coffee maker, thru Gevalia) It worked perfectly for...
Hello, point
I was trying to help you out here. Maybe this will help some? I was going backto some customers that asked questions in the recent past and even fartherback. It appeared that no one answeredsome of them, So, I thought I would take some of my personal time to see if Ican help. Even though this Informational site may not have your exact model orbrand, this site will help you a lot. Here is a site link about everything you want to know about CoffeeMakers and possibly yours, from
repair to trouble shooting it. b>http://home.howstuffworks.com/coffee-maker4.htm
Please if this helped you at all, if you can find the time and in your heart torate my help and some kind words written would be appreciated for my free help, I would appreciate it.
Here is also my direct link to my own pages of other areas of my expertise forother problems you might have in Automotive, Appliance, and Electronics. DropIn anytime for my help.
Thanks, Mike
http://beta.fixya.com/users/mc1bean
Sep 19, 2011 | Gevalia CM-500 12 Cup Coffee Maker
I have had my Kuerig coffee maker for over a year now which I believe means it's no longer under warranty. However, I paid quite a lot for it so I'd really like to see if I can have it repaired...
unfortunatly keurig treats any home model as throwaway once warrenty is up. They even do the same with mostcommercial models. By the sounds of your problems its time for a new one. sorry. try for a b145 or b150 they are a little more robust.
Sep 05, 2011 | Keurig Platinum B70 Coffee Maker
I lost my manual. How do I de-scale? Does this not allow you to brew a cup until it has been de-scaled?
From http://www.keurig.com/customer-service/brewer-registration-and-support/~/media/Files/Keurig%20Brewer%20Manuals/De-scaling_instructions.ashx
PREPARE Step 1: Empty the water in the Water Reservoir. Step 2: Disable "Auto Off" features.
FILL AND CLEAN Step 1: Pour approximately 48 ounces of the vinegar into the Water Reservoir. Step 2: Place a large mug on the Drip Tray Plate and run a brew cycle. DO NOT USE A K-CUP, just press the BREW Button. Pour the contents of the large mug into the sink. Step 3: Repeat the brew process without a K-Cup until "ADD WATER" is indicated. Step 4: Now let the Brewer stand for at least 4 hours while still on. Step 5: Discard any residual vinegar and rinse the Water Reservoir thoroughly.
RINSE Step 1: Ensure the Water Reservoir is filled with fresh water. Step 2: Place a large mug on the Drip Tray Plate and water brew cycle. Pour the contents of the large mug into the sink. Step 3: Repeat brew process until "ADD WATER" is indicated. Step 4: You may need to perform additional water brew cycles if you notice any residual taste. NOTE: If "DE-SCALE" is still displayed after completing the procedure, repeat the de-scaling procedure above.
Mar 17, 2011 | Keurig Special Edition B60 Coffee Maker
Heater element not warming water at all light on front of machine just keeps flashing model number on box hd7850/60
Hi, Please go through some of the information in the user manual which you would be able to access by clicking on the below web link:- http://download.p4c.philips.com/files/h/hd7850_60/hd7850_60_dfu_eng.pdf Usually the light on the front of the machine keeps blinking because There is not enough water in the water reservoir or the reservoir is not properly been placed.So take out the water reservoir of the machine. Check if there is enough water in the water reservoir (i.e above the 1 cup MIN level if you want to brew 1 cup and above the 2 cups minimum level if you want to brew 2 cups) and replace the water reservoir. Thank you for your time and best wishes for your effort.
Jan 03, 2011 | Coffee Makers & Espresso Machines
Why does Gevalia coffee maker leak from bottom?
Because the Gevalia coffee makers are often offered as a free or reduced price premium for purchasing Gevalia coffees they are not well made and can sometimes have a difficult to repair molding error in the reservoir. I have had very good luck with the Hamilton Beach Brew Station. It is affordable, well made, easy to keep clean and nearly foolproof.
Aug 20, 2010 | Wega Mininova EPU Espresso Machine
Kenmore Elite coffee maker Model # 100.9101670A Is this model on a recall? How can I get a manual for it? And what is the filter reset button?
I have a manual with mine and as far as "recall" goes on this model, I've not found anything recalling this particular model...<br /> <br /> The most important thing in the manual, that I have found, is how to clean and change the filter. If all else fails unplug the pot for 10-15 seconds; replug it...this resets it...(if it ever acts up, do this; it helps)<br /> <br /> The filter reset button: Your coffeepot should flash a small message stating: "change filter and clean" To do this you first, turn off the pot, remove filter~(the filter is in a long thin black plastic thing and the filter cover simply snaps and pulls apart to expose the charcoil filter; Remove the Filter, then fill the coffee pot with 7 cups of vinegar plus 7 cups cold water; Place a paper type regular coffee filter in the brew basket, or a thin paper towel works well too~(This traps and holds particles that get trapped inside the pot)<br /> <br /> Before brewing; PLEASE NOTE, brew the first pot of vinegar/water mixture only HALF WAY then TURN OFF and let it sit for a good 15 minutes to soften any deposits...<br /> Turn the pot BACK ON and brew the remaining solution. When brew stops turn OFF coffee pot, empty the solution, and discard the paper filter...<br /> <br /> Refill reservoir with cold water and turn ON; you may want to dump this and refill with more cold water to ensure the vinegar taste/smell is gone...<br /> <br /> Now, wash the brew basket and the glass pot...Open the black skiny Water Filter and replace with a new charcoil filter...Put Filter back in pot...fill brew basket with coffee and brew some mighty fine tasting coffee!!! Hope this helps....Good Luck
Jun 29, 2010 | Coffee Makers & Espresso Machines
Gevalia 25280 / 50304 / 60130 / 50431 Coffee Maker Logo
548 people viewed this question
Top Gevalia Coffee Makers & Espresso Machines Experts
Pierre Laplante
Marvin
Marvin
Vitally Alcher
Are you a Gevalia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
