Question about Xerox XC356 Copier
Xerox Copier XC356 gives only all black copies.
Our Xerox XC356 gives only all black copies. It was purchased in 1997 and the problem came on suddenly. Can we fix this or have it fixed or should I just purchase a new one? Thanks so much for your help.
  • fIX All Apr 17, 2008
    Changed the drum ,changed the toner ,vacumed out all exess toner and I still have the same problem.
  • Mejew Feb 17, 2009
    dark copies how do i clean inside of glass
    Genius:
  • 1,003 Answers
WITH THIS PRINTER ITS CHEAPER TO REPLACE THAN REPAIR SOUNDS LIKE THE LED OR ILLUMINATIN LAMP IS BLOWN
Posted on Jan 23, 2008
WHERE IS THE THERMAL FUSE IN A XEROX COPIER?
It is usually an internal fuse in the FUSER Assembly that limits or reports the fuser temperature to the control board..
May 24, 2014 | Xerox XC356 Copier
I cannot get the drum cartridge out of the XC356 copier by Xerox. I have lifted the green tab, however it is still locked or hard to come out and I am afraid I will break same. Do I need to do something...
You can always find a soution to your Xerox problem at www.xerox.com/support Here is a link to this solution:
http://www.support.xerox.com/SRVS/CGI-BIN/WEBCGI.EXE?St=22,E=0000000002703238142,K=7389,Sxi=4,Solution=obj(18692)
  1. Turn the copier off.
  2. Remove the Toner Cartridge:NOTE: If you are not sure how to remove the Toner Cartridge, refer to Related Links at the bottom of this page.
  3. Remove the Input Tray on the right side of the copier, if applicable.
  4. Slide the Platen to the right by pushing in on the grey square Release Button on the back of the copier, then sliding the Platen.
  5. Fold up the Exit Tray on the left side of the copier, if applicable.
  6. Stand the copier upright on its left side.
  7. Remove the Bottom Access Door (see Related Links).
  8. CAUTION: Be careful not to touch the red surface of the Drum.
  9. Locate the green Drum Cartridge Release Lever at the bottom of the Drum Cartridge.
  10. Lift up on the Drum Cartridge Release Lever.
  11. Pull up on the bottom of the Drum Cartridge. The Drum Cartridge will pivot upwards.
  12. Pull back on the Drum Cartridge to remove it from the copier.
Jan 26, 2011 | Xerox XC356 Copier
My xc356 copier prints dark lines on the copy, toner has been replaced
If it is just with copies, then you have either dirty optics or dirty glass which you must clean. However, most likely the problem is with the imaging drum. If you are able to remove the drum, I suggest cleaning it with soft cloth or rag, then reinsert and see if the problem persists. If the issue does not go away, then I would suggest having a technician coming out and seeing if you need the drum replaced.
-David.
Nov 02, 2010 | Xerox XC356 Copier
Print black pages and jam pages
please check exposure lamp. Is it go on when press copy button?
Sep 15, 2010 | Xerox XC356 Copier
XEROX COPIER XC865 HAS AN H4 ERROR CODE HOW TO RESET AND WHAT DOES IT MEAN
H4Fuser temperature too low. Must be reset in diagnostics
Dec 18, 2009 | Xerox XC356 Copier
GETTING STREAKS ON COPY.
Hello sir; It's time to replace drum cartridge. after you replace still have problem then let me know.
Oct 04, 2009 | Xerox XC356 Copier
New toner but still have dark streaks
IF YOU ARE ONLY GETTING THE LINES WHEN YOU PUT THE DOCUMENTS INTO THE TOP FEEDER AND NOT FROM PRINTNG TO COPIER OR IF YOU PUT A COPY ON THE GLASS UNDER THE DOC FEEDER AND NO LINES APEAR CHECK THE SMALL GLASS WINDOW UNDER THE DOC FEEDER THERE MAY BE SOME TIPEX OR INK RUBBED OFF AND LEFT ON THE GLASS THERE.. THISD MIGHT BE CAUSING THE STREAKS YOU CAN CHECK THIS BY PUTTING THE PAGE IN THE DOC FEEDER AND DOING A COPY AND THEN PUT IT ON THE GLASS PLATE UNDER THE LID AND DO A COPY OR IF HOOKED UP TO COMPUTER DO A PRINT JOB.. IN NO STEAK APPEARS YOU CAN BE SURE ITS ON THE THIN SCANNER GLASS.. GOOD LUCK ...a
Jun 24, 2009 | Xerox XC356 Copier
Dark streaks on copies from Xerox XC356 copier. Streaks were light at first; changed to a new toner cartridge and streaks are same size/same place on the page -- but now darker. There are three streaks,...
Replace the Drum Unit, Do you know how to rebuilt this unit, if not you can get an after market product, The Drum unit release is in the Middle of the Copiers you will see a door , open the door, then ONLY , and i do mean ONLY, touch the "Green" release lever for the drum take it out and replace it or rebuilt it f you now how, if this does solve it, which i am certain it will but, if it doesn't something is wrong with the fusing unit and needs to be dismantled, wish i could give you our contact info however, been informed not too so sorry. rules of fixya.com
Mar 04, 2009 | Xerox XC356 Copier
Xerox xc356 copier
TRY TO CLEAN THE RUBBER ON FEEDING PAPER WITH A DRY CLEAN CLOTH AND DROP A SOME ALCOHOL IN CLOTH AND CHECK THE PAPER PATH IF HAVE SOME A LITTLE PAPER ON PATH PAPER... ABOUT CATRIDGE...TRY TO REPLACE A NEW CATRIDGE.. DO THIS NECESSARY UR COPIER IS ON. panlaqui08@yahoo.com.ph
Jul 05, 2007 | Xerox XC356 Copier
Brand New in sealed box , but not powering up
well, when the copier is new, it is best you take it back to the dealer and get other . You should have a warranty on this product.
May 21, 2007 | Xerox XC356 Copier
Xerox XC356 Copier Logo
151 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Philip Hughes
docukaaf
Level 1 Expert
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
