Question about Jetway V266B Motherboard
Upgrade of ram
Hi could anyone tell me if my jetway V266B REV 3.0 A10 mother board will support 1g or 2g of ddr ram and if so what spec of ddr ram. also would 1g be sufficiant or 2g ie in relation to this mother boards perfomance thankyou
  • butle Jan 24, 2008
    thankyou for your help sorry i posted twice but im new to this and thought i posting elsewhere the second time. once again thankyou for your help iwill go with 1g
    President:
  • 2,351 Answers
Your board Support 168-pin SDRAM DIMM and 184-pin DDR DIMM (Can't Use DIMM & DDR SDRAM memory Together).
I would run the 184-pin DDR. Supports PC1600/PC2100 DDR DRAM up to 2BG Max. Since you have four memory slots 2x512mb of DDR PC2100 = 1GB would be plenty. You will notice programs load faster & games run smoother. Personally, 2Gb. may help but you will not see the difference. To see a difference it is not all about memory. Mb bus speed, CPU, chipset & speed of video memory all play a part with regards to Pc overall speed. You can download your manual here.: http://www.jetway.com.tw/oldweb/evisn/download/manual/index1.htm
You can download the specs of your board here.:
http://www.jetway.com.tw/oldweb/evisn/product/amd/v266b/v266b.htm
And below is a link for some good ram.:
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=302039&CatId=548
This should all help you decide, best wishes!
Please vote.....
Posted on Jan 23, 2008
Jetway v266b rev 3.0-what ram memory to use??
You might wanna try DDR RAM, the highest size you will be able to get is is 1GB per module, so buy a few if a DDR module fits, and you may also want to look at the capacitors, make sure they're not bulging, I've seen a lot of these boards in computers, and when I've had to repair them, 99% of the time it was bad caps, so if they are bulging, I reccommend nichicon K series caps (NOT KZG, they're known defective)
Feb 22, 2013 | Computers & Internet
I need a manual for the Jetway V266b rev.3 motherboard. Can you help in any way.
Here is the link:
http://www.machspeed.com/manuals/VIPER/V266B.pdf
Adobe reader will have to be installed on your PC.
Hope this helps
Chris
Sep 28, 2010 | Jetway V266B Motherboard
2G RAM's for Elitegroup (ECS) L7VMM2 Rev 1.0A Motherboard
You're board can handel; DDR SDRAM up to 200 or 266MHz DDR SDRAM memory module. Accommodates two "unbuffered", 2.5V 184-pin slots. Each slot supports up to 1 GB with a total maximum capacity of 2 GB. Return the Kingston memory you have installed if it is less than a year old. They should allow you to trade up to the MB's supported memory.
Two reach the MB's max memmory of 2GB. Buy two Kingston DIMMS of, "unbuffered", 2.5V 184-pin
DIMMs. Here is one site that sells Kingston memory;
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=235786&CatId=548
The next link is Kingstons site; http://www.ec.kingston.com/ecom/configurator_new/PartsInfo.asp?root=us&LinkBack=http://www.kingston.com&ktcpartno=KVR266X64C2/1G
Here is another site; http://www.buy.com/prod/kingston-1gb-ddr-memory-pc2100-266mhz-184-pin-dimm-kingston-1gb-ddr/q/loc/101/10348796.html
If you decide to search for you're self, use this as the basis for the correct model: Module - KVR266X64C2
Link to ECS web site; http://www.ecsusa.com/ECSWebSite/Product/Product_Detail.aspx?DetailID=62&CategoryID=1&MenuID=50&LanID=9
Mike
Jun 02, 2010 | EliteGroup L7VMM2 (L7VMM2 NO CARD READER)...
Dell Dimension 4600 desktop memory upgrade
well first the mother board needs to be capable of handleing that much memory you can check that by going to the dell website and checking the specs on that model pc or mother board if the bios isn't recognizing it the chances are it won't but take out the 512 stick and just try one of the 1Gig if it does recognize that then try the second stick if it doesn't recognize them both then chances are it can't handle that much memory.
Oct 07, 2009 | Dell Dimension 4600 PC Desktop
Will this motherboard use 1gb ram memory 184 pin
Since it uses ddr 2 RAM you should use pairs. Your max supported on this board is 2 GB so if you want to max out you could install 2 x 1 GB. Hope this helps.
Jan 19, 2009 | Jetway V266B Motherboard
Jetway v266b jumper settings just bought a working mobo but nothing comes on screen tested memory psu and graphics card on working pc
Hi craig74
it shouldnt be hard to find the pdf manual for the mother board on google just search for v266b motherbaord mannual :)
Jul 13, 2008 | Computers & Internet
Is pc400 compatible
The board supports PC1600/PC2100 DDR Ram up to 2GB Max
May 15, 2008 | Jetway V266B Motherboard
Cache
Cache memory is available inside the processor. So in order to increase the Cache you need to change your Processor.
Feb 20, 2008 | Jetway V266B Motherboard
Want to up grade to 2g ddr mem
hi
is this your board?
http://www.geniyisis.com/index.html?/Jetway/v266b.htm
well, if this is your board, you can upgrade your ram to 2gb howerver since it is a dual ram...(SDRAM and DDR) you cant use all the slots at 1 time since they are of different frequencies.
you can use DDr266 (pc2100) as your RAM since this board is a socket A as it is said here in the boards specs.
hope this helps
Jan 23, 2008 | Jetway V266B Motherboard
JetwayV266b (REV: 3.00) - Max processor speed??
Design ATX form factor 4 layers PCB size: 30.5x24.4cm Chipset VIA KT266A/VT8233A Chipset CPU Socket Support AMD Athlon 700MHz∼1.4GHz processor Support AMD Athlon XP 1500+ 2600+ processor Support AMD Duron 600MHz 1.3GHz processor Support 200MHz/266MHz (Double Data Rate) Front Side Bus frequency processors Reserves support for future AMD processors 2600+ is the highest it will go. http://www.machspeed.com/manuals/VIPER/V266B.pdf page 3
Sep 17, 2007 | Jetway V266B Motherboard
Jetway V266B Motherboard Logo
186 people viewed this question
Top Jetway Computers & Internet Experts
john smith
Iqbal Husain
Iqbal Husain
Starnley Johnwells
Starnley Johnwells
Are you a Jetway Computer and Internet Expert? Answer questions, earn points and help others
