Question about Sony Ericsson W700i Cellular Phone
Camera gets open automatically
Camera is getting open automatically though shutter is closed,because of that battery life is getting down
    Brigadier General:
  • 7,752 Answers
You should have the phone firmware reflash on the phone.....take it to a mobile service center and have them do that for you.
Posted on Jan 25, 2008
Camera not working
Hi Jane,
When we press the shutter release the mirror flips up after the shutter opens and closes the mirror flips down. When it flips down we then see out the viewfinder.
At first blush is sounds as though the mirror flipped up but not back down. Remove the lens look inside the camera press the shutter release what happens?
Cordially,
Jul 25, 2013 | Canon EOS Rebel 2000 35mm SLR Camera
Nikon coolpix S3000 won't take a picture when the
Assuming you have new batteries and the camera lens cover is opening when turned on. Try switching to any mode other than automatic, turn off the flash, and press the shutter button. Many cameras have a safety feature that prevents the flash capacitor from charging if the case is opened. This is to lessen the chance of electric shock. They usually use one or two of the screws along the perimeter of the camera to complete a circuit that lets the processor know that the case is closed. Verify that all the screws are in place along the perimeter of your camera, and that there are no gaps along the perimeter seams. If you're missing a screw, try using one of the others to replace it.
If they're all there, next thing to check is the batteries. The brand that you're using may have reached its shelf life, or just may not have sufficient power to charge the flash capacitor. Try a better brand, or better yet rechargeable NiMH batteries.
If the above didn't help, then the flash tube or its circuit is probably at fault. In this case, would then recommend professional repair. This repair is somewhat difficult, requires some soldering, has some danger of electrical shock, and goes beyond what I'd like to describe here
Jun 13, 2011 | Nikon Coolpix S3000 Digital Camera
I am not getting an image either through the viewfinder or on the LCD monitor. The display is clear and bright and the batteries appear to be fine.
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Jun 26, 2010 | Canon PowerShot S2 IS Digital Camera
Shutter appears to be stuck closed.
Theirs oil on the shutter blades causing it to stay closed, Thats why you can't see though the lens or the viewfinder also, This comes from the grease from the zoom assy, It's a major job to fix it, Has to be fixed by a repair shop
Jun 04, 2010 | Canon PowerShot S3 IS Digital Camera
Nikon F100 does not advance film to start of roll,
Jim, it really sounds like one of threethings. Either will require a repair shop.
1. the film sensor is not recognizing film in the film chamber, or film across the back, therefore not telling the advance motor to advance film...
2. The film advance motor itself needs replaced.
3. The rear door latch switch needs replaced.
Since everything else seems to do OK, I doubt the main computer board is bad.
Feb 03, 2010 | Nikon F100 35mm SLR Camera
No view though the lens
Dec 26, 2009 | Canon PowerShot S2 IS Digital Camera
While taking a photo snap, don't see the picture on the screen. Screen is black. Can see the old picture on preview mode without any problem
Sounds like you might have accidentally pressed the DISP or DISPLAY button on the back of your camera. This manually turns the screen on and off to save batterie (you would then use the optical viewfinder in its place). Press this button once to see if it corrects the problem.
If the above didn't help, a stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
Nov 07, 2009 | Canon PowerShot SD1000 Digital Camera
Lens does not always open, batteries run down quickly
the 520's are notorious for lens opening issues... I've had a few and any dirt or moisture in the lens shutters, and they'll get screwy.
Clean dirt with a little compressed air...not high pressure...
Batteries... set the resolution a bit lower, avoid alot of flash and zoom and you'll get better battery life... it's part the 520...carry spare alkalines.. always..
K
Jul 01, 2009 | Canon PowerShot A520 Digital Camera
Shutter will not fully open or close
It sounds like the shutter mechanism is dirty, or you have a bad spring. Try taking it to a camera shop and have them clean it. It is not very expensive, and well worth it if it fixes the problem. Best regards, nightdiver Let me know if it solves the problem.
May 25, 2006 | Konica Minolta DiMAGE F100 Digital Camera
Sony Ericsson W700i Cellular Phone Logo
50 people viewed this question
Top Sony Ericsson Cell Phones Experts
270rexton
270rexton
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
