Question about Creda C362E Electric Kitchen Range
Creda cooker not working properly
When i turn on any of the rings on my creda electric cooker the oven is coming on all the dials are turned to the off position but the oven is heating up aswell?
  • 2 more comments
  • donpat Sep 06, 2008
    My hob,grill and fan is working but my oven will not heat up.
    Thanks.
  • soarerman Nov 02, 2008
    my oven element is on when the oven is switched on but the oven thermostat is in the off position. is this the thermostat?
  • Anonymous Nov 23, 2008
    Creda EDC51 - oven is not heating.
  • nsmorley Dec 19, 2008
    3 top hob rings work ok, but top oven and fan main oven not coming on at all.
    LCD display just flashes auto all the time and none of the control (timer etc) buttons do anything.
    pls help!
My creda cookers hob and top oven is working,but my fan oven is not heating up,the fan works though.
Posted on Sep 06, 2008
6ya staff
SOURCE:
Every time I switch the rings on my creda starlight cooker they start smoking and trip the electric ?
they are shorting out through the ceramic insulation
get and install new rings
Dec 31, 2016 | Creda Ovens
Creda Solarplus (48906) top oven and grill not working
Electric stoves do not have pilot lights or igniters it could be the power control board has failed .
Mar 12, 2016 | Creda Ovens
How to fix creda cooker all of the hobs when put on are unable to control heat
[PDF]Product Directory Summer 2013 - Creda Heating
www.credaheating.co.uk/assets/kb/brochure/.../Creda_Nobo_Brochure.p...
Creda Heating range, installation and operating instructions, brochure ... installations. We are able to offer an expert application design service for all our.
The Different Functions And Uses Of The Oven - Creda ...
www.manualslib.com > ... > Instructions for installation and use manual
Creda J052E Instructions For Installation And Use Manual: The Different Functions And Uses Of The Oven ... For all other types of. cooking, never ... cooking functions are set up by operating the two knobs: ... The oven light turns on and the top and bottomheating ... permit reaching the maximum (250°C) temperature inside.
[PDF]Instructions for Installation and Use - you
Jan 24, 2016 | Creda Kitchen Ranges
How do I turn the timer off on my old Creda Hallmark oven?
I recommend replacing the entire unit. 20 years is well past the operational life cycle of the oven. You deserve a new unit for sticking with it for so long. Besides, the new ones are more energy efficient.
Jul 28, 2014 | Creda Kitchen Ranges
Creda cf50g cooker oven not getting hot
sounds like the ffd is at fault, this is a safety device that alows the main flow of gas through. when the cooker is cleaned the sensor can be moved by accident from its position over the flame, another reason could be a build up of grease etc, stopping the flame reaching the sensor. if none of these then the ffd unit needs to be replaced. they are about £20.00 for the part
Apr 06, 2010 | Ovens
Hi.i have a hotpoint creda c362e cooker the rings work grill works but main oven and top oven elements dont come on even when lights come on when switched on fan works but no heat could you help me on this...
Hi.
Frpm the sympton's you list, I would say that the main oven element has failed, espsecially if the fan is working o/k.
The element is located at the rear of the oven compartment behind a removeable cover.
In addition to the grill elements in the top oven compartment, there is an additional base element which you can't see.
If you turn the top oven on, the base of the compartment should get hot, if it does not, then the base element has probably failed.
Hope this helps.
Jan 09, 2010 | Creda Ovens
CREDA OVEN FAN NOT WORKING OVEN BARELY HEATING
As a first port of call, you can remove the fan by removing the inner back panel (4 screws) and taking the fan blade off (anti clockwise screw) The drop the fan out through the back of the cooker. If you apply WD40 to the two bearings you may get the fan going again. Otherwise you'll have to replace it.
Sep 29, 2009 | Creda C361E Electric Kitchen Range
How do I get a manual on a Creda Concept Solarglo Cooker
When i turn on the kitchens rings,they turn on for 10 seconds and after turn off for half minute and this process continue to repeate again and again. The indicates of screen change allte time, and i dont know whats happen with the kooker.Please inform me what to do. Thtank you!
Apr 21, 2009 | Creda C362E Electric Kitchen Range
Creda C362E Electric Kitchen Range Logo
2,425 people viewed this question
Top Creda Kitchen Ranges Experts
Marvin
Marvin
Paul Carew
Are you a Creda Kitchen Range Expert? Answer questions, earn points and help others
