Question about InFocus ScreenPlay 4805 Multimedia Projector
X2 board I have several (12) X2 projectors that have bad controller boards. Where can I find replacements? It will cost about $350 + parts to have these repaired by InFocus.
    Problem Solver:
I have ballast problems with several X2 X3 projectors and even a C180 (Proxima) although with different ballast power layout. My X2 units mostly seem to have blown a pair of output FETs (2SK3568), but that is only part of the problem. One unit powers up, but just won't strike the lamp. Installing a good ballast power supply board fixes the problem, but I can't find any place to buy or repair these without sending the whole projector in for repair.
Perhaps it is time to trace out the schematic of these boards and have someone start repairing them at big profits.
Posted on Nov 05, 2008
  • 52 Answers
Ebay has several that need bulbs... just a thought here is one of the item numbers Item number: 270207032811
Posted on Jan 29, 2008
My RCA P52937SG projection tv. Picture distorted. I beleive it has to do with the green circuit / projector. Everything needs to be aligned to green. Green projector is on, but, in alignment screen I get...
The tv have a problems known as a convergence problems,it dead.Tv have colors lines R,G,B mis alignments,have colors shadow pictures or 3D pictures look alike?The tv convergence board is dead.The tv convergence board must have replace the 2 STK convergence ICS and some or all of it resistors too.To fixed the tv convergence board to solved the tv convergence picture problems.The shop,will cost u like $300-350 for parts and labors.
Mar 28, 2011 | RCA R52WH73 Projection Television
I have the akia projector tv and the numbers and letters are doubled. Also the color isn't right . Is it the auto focus ? . Please help I don't know how to fix this ...
The tv problem is call convergence problems,it dead.Tv have convergence colors lines R,G,B mis alignments,have colors shadows pictures or 3D pictures look alike?The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors too.These parts must replaced on the tv convergence board to solved the tv picture convergence problems.Try website like Tvrepairworld.com might still can buy a whole refurbish convergence board for the replacement.The Akai and Samsung DLP tvs used the same convergence board.Or the shop,will cost u like $300-350 for parts and labors.
Jan 06, 2011 | Akai PT5598HD 55" Rear Projection...
Colors are seperated throughout screen. started in corners over a period of several weeks, and now colors are seperated by about 2 inches
u have bad convergence ic , for this repair i would recomend to hire a tv repair tech , this job require alot of soldering and aligments , $250 - 350
Nov 03, 2010 | Mitsubishi WS-55809 55" Rear Projection...
Saab 900 fuel gauge erratic. I measure 5 volts on the sender bus going into the tank. This should be 12 surely. The pump has 12 and works fine. My 9 3has 12 volts to the sender .Is the 900 diferent or am I...
fuel gauge voltage is controlled by the dash board, there is a board on the back of the dash that connects the rev counter the voltage is controlled by this board. you would need to change this board. but to do so you would need to open up the dash board display to get to the board or just replace the dash.
Jul 22, 2017 | 1997 Saab 900
The blue projector is out of place i can't make it line up with yellow and red in the menu
U mean ur tv picture look like 3D pictures,colors R,G,B don't line up?This tv have a problems call Convergence,it dead.The tv Convergence board have the 2 convergence ICS and some or all it resistors are dead.These parts on the convergence board must be replaced to solved convergence problems.The shop will cost u $300-350 for parts and labors.
Jun 17, 2010 | Hitachi 53FDX01B 53" Rear Projection...
I have an LP530. Need main circuit board
Try LumenArc. They stock a range of ballasts. If yours is not listed, then email them.
May 09, 2009 | InFocus LP 530 Multimedia Projector
Infocus projector power supply parts
you won't find schematics for them. infocus had their boards made by someone else who now no longer makes boards. it's usually the caps drying out that causes power problems.
Nov 03, 2008 | NEC VT670 Multimedia Projector
Infocus projector power supply dead
the caps dry out. look for bulging caps. you won't find a schematic for the ps boards. infocus had someone else make them. the problem seems more like a overheating issue. as for the other one with the "just the fans", check the colorwheel.
Oct 03, 2008 | InFocus POWER SUPPLY CORD Multimedia...
Infocus x2
first try another computer cable. if same results, press the "auto image" button on the projector. if that doesn't work, press menu, select settings, then factory reset, and "yes". if you still have the same problem, the eca (main board) is bad.
Sep 01, 2008 | InFocus X1 Multimedia Projector
In need of new controller board???
The cost of a new controller is prohibitive. If you have to replace that, you may as well replace the projector. It is the second most expensive part in the projector, the optical engine being the most expensive. Last time I checked, a new Controller Board assy is in the neighborhood of $800 - $900.
Feb 01, 2008 | InFocus ScreenPlay 4805 Multimedia...
InFocus ScreenPlay 4805 Multimedia Projector Logo
314 people viewed this question
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
