Question about GALAXY Microsystems 55622
Frozen slabs of ice instead of ice cubes
All of a sudden, my ice maker does not make ice cubes. It dumps the water in the bin and freezes to a big slab of ice. Not sure what is going on? Any suggestions?
  • theblues Jan 28, 2008
    The water was pouring out when it was supposed to cycle the water for ice cubes. Found out the thermostat was gone. Had to replace it and now evrything works fine. Thanks for your help.
  • 770 Answers
The icemaker could be leaking by can you see where the water is coming down into the bin from??
Posted on Jan 24, 2008
  • Gary Davd
    Gary Davd Jan 28, 2008
    plz rate this for me thx
My ice maker inst working Whirlpoo; model gz25fsrxyy2
By "ice maker isn't working" do you mean it isn't filling with water, it isn't freezing the water in the ice maker, it isn't dumping the ice cubes into the bin, or it isn't dispensing ice cubes?
Was it previously working and it is not working now?
Typically one can hear the valve when it opens to fill the ice maker with water. Can you hear it attempting to do so? If so, and there isn't any water in the ice tray, check that there is water supplied to the valve at the wall and the valve is open. Is there a water filter? Has it been replaced per the manufacturer's recommendation? (Typically, the water filter should be replaced every six months.)
Is the "full" bar pushed up? It shouldn't be. The bar above the ice cubes should not be in the horizontal position. That position tells the ice maker the bin is full so it should wait until the bar goes down, indicating some ice has been used.
Can you hear the bayonet turning? Is the ice maker attempting to dump out cubes whether or not they exist? The next issue after you confirm there is water going into the ice maker that is being frozen and the ice maker knows to dump the ice, is the bayonet. There is a motor that turns the bayonet and a mechanical connection. Either could be at fault.
Jan 22, 2018 | Refrigerators
Dumping ice
If heater element is open the newly made cubes will stick to the tray and not be pushed out by the fingers doing the ejecting.
Apr 08, 2014 | Whirlpool 2198597 Ice Maker
My Liebherr ign 2566 freezer is having problems with the icemaker. It is producing ice cubes but also water is pouring direct into the tray therefore producing a big slab of frozen water.
Hello there,
You need to check the water inlet valve, it is having a problem, it is not shutting close after filling the ice maker with water. It is already defective hereby causing water to pour out into the tray therefore producing the big slab of frozen water.
You will have to test and replace the water inlet valve. That way, it will stop pouring water into the already made ice that is in the tray.
Hope this helped. All the best Elect_Comp
Sep 23, 2011 | Liebherr Refrigerators
No ice Ice maker does not fill up with water
Pour about 2/3 cup of water into the ice maker . If it freezes and dumps , then check the fill tube going to the ice maker , to see if it is frozen up inside . If it is , replace the water valve behind the refrig , where the wall water line connects to on the refrig . If the ice maker dumps the cubes , but does not refill with water , then the water valve is bad . If the ice maker does not dump the cubes , then replace the ice maker .
Nov 11, 2009 | Refrigerators
Icemaker makes shells. Outside is frozen but
Hollow cubes are caused by not having enough water in the ice mold. Fill it up manually by pouring water in it and see how the cubes turn out.
look for an adjustment behind the plastic endcover with a +/- on it. - is less water. + is more water.
Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
There is a screen filter before the water inlet valve in the water line. It can get partially stopped up with sediment blocking water flow.
Oct 28, 2009 | Freezers
Ice maker will not make ice
Make sure the ice maker is turned on ( green light ?) . Pour about 2/3 cup of water into ice maker . If it freezes and dumps the cubes , but doesn't fill with water , replace the dual water inlet valve ( one coil for water dispensor , the other is for the ice maker ) . If it does not dump the frozen cubes , then replace the ice maker .
Sep 17, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
No Ice Cubes
Maybe water inlet tube is stopped up with ice so water is bypassing ice maker and dripping into bin.
Or is the water inlet valve on the back not shutting off.
Either way check water inlet valve. http://www.acmehowto.com/howto/appliance/refrigerator/check/inletvalve.php
Jan 23, 2008 | GALAXY Microsystems 55622
Ice accumulating in freezer
There should be a tube that brings water to your icemaker from the back of the fridge into the icemaker. This tube is frozen with water, or the inlet where this tube feed the icemaker tray is frozen. The result is that water cannot go to the ice maker, and instead, goes over the top of the inlet area.
Verify that this is indeed what is going on.
The fix is to remove the blockage/buildup of ice at the inlet. You may have to detach the icemaker to get to it. Be carefull with electricity! Also be carefull as plastic can break under stress!
The tube may be frozen to the inlet, channel locks can be used to gently twist the tube to break it free.
Good Luck!
Jan 01, 2008 | Samsung RS2630SH Side by Side Refrigerator
GALAXY Microsystems 55622 Logo
321 people viewed this question
Top GALAXY Microsystems Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a GALAXY Microsystems Refrigerator Expert? Answer questions, earn points and help others
