Question about GE WBVH6240F Front Load Washer
GE DUET Washer
My washer will be fine till about 15 min before itis done with the load....then it beeps and the letter F comes on, why does this come on? Whats the solution?
  • 1 more comment
  • Oreokidbob Mar 12, 2008
    Have had mine for 3.5 years now, starting@ 1 month ago, would stop mid-cycle with f flashing, would reset and it would start again. Starting @ 2 weeks ago, does not spin/drain proper. Cycle ends with full load of water remaining, have to run drain/spin cycle. Today, as soon as I start machine, door will not lock, "dl" and "f" flash alternately. machine wont start.
  • Anonymous Jun 12, 2008
    Same door lock problem on front loading Whirlpool Duet. Won't always lock. Now won't lock at all.
  • Jodeew Sep 11, 2008
    I have the same exact problem, it starts beeping 10-15 minutes before its done..seems to be on the rinse cycle.
    The 'F' is flashing and if I start it over on the Drain/spin cycle the locks then unlocks and make this grinding sound.
    How do we fix this?
I also have the same problem. I went to find a new pump for the washer and when I looked at it I found that the pump has a Pea Trap in the front of it. To get to the pump you have to remove the lower front panel which is held in place by 3 screws located on the bottom of the panel. Once removed you will see the pump and notice that there is a small turning nob on the front of it. Just unscrew counter clockwise to remove the Pea trap.
Warning: if your washer has water in it then when you remove the trap it is going to come rushing out, if not then the clog is further back up in the drain hose. I would like to say that you can easily capture the water coming out but it is difficult to do given the design of the pump housing and position.
Clean the trap and hose, reassemble, and it should be good to go.
Always unplug the power when working with electronic equipment, especially when water is envolved.
Posted on Mar 11, 2009
Why does it beep through the entire. Wash cycle. No code showing.
Whirlpool Duet GHW9150P Front Load Washer Beeping ...
www.fixya.com > ... > Whirlpool Duet GHW9150P Front Load Washer
Question about Whirlpool duet Washing Machines ... my front loader is not workingwhirlpool washer flashes and beeps will not finish a cycle 1 Beep/E10--Error: Water... It beeps through the wash and rinse cycle every couple of minutes. ... Cycle signal which tells you that the cycle is complete beeps through the entire cycle.
[PDF]front-loading automatic washer use and care ... - Whirlpool
www.whirlpool.com/.../U...
Translate this page Whirlpool Home AppliancesWash. This is the main portion of the wash cycle. You will see the washer tumble the load. ... Spin cycle. If the laundry is still wet, take half of the load out of the washer and try again. .... Using recommended AFFRESH® washer cleaner, add.
[PDF]DISHWASHER USER INSTRUCTIONS - Whirlpool
https://www.whirlpool.co...
Translate this page Whirlpool Home AppliancesThe first cycle using the sensor will run longer to calibrate the optical sensor. Rinse Aid. Using rinse aid will optimize your drying and wash performance. This dishwasher is ...... laundry detergent, hand soap, or dish detergent for hand washing .... models) you will experience more starts and stops throughout the entire cycle.
Continuous Beeping - Whirlpool Duet Sport Washer - The ...
appliantology.org > ... > The Laundry Appliance Repair Forum
Jan 25, 2016 | Whirlpool Washing Machines
My washer will run for a short time and them stop and just beep repeatidly
Frigidaire washer beeps for no reason, driving us crazy ...
? 1:03
https://www.youtube.com/watch?v=gP51k2bhbbg
Nov 6, 2011 - Uploaded by NatalieJonathan
Our Frigidaire washer keeps giving us ridiculous beeping issues, and for no reason. ... Mine stack dryer above ...
My washer pauses during wash cycle and will not restart ...
www.shopyourway.com > Manage My Life > Questions
The washer will stop during wash cycle and just beep. Sometimes we can turn it off and it will run again. Getting worse ... My washer is a Whirlpool 3.5 cu. ft.
FIXED Whirlpool Duet Washer Stops and Beeps - ApplianceBlog
www.applianceblog.com/.../48786-Whirlpool-Duet-Washer-Stops-and-B...
Jan 16, 2015 - 6 posts - ‎2 authors
It's a front loading Whirlpool Duet Washer 4.0 cu ft, with Tumblefresh ... wet it stopswashing and starts beeping (three beeps, pause, three beeps, pause, etc). ... The clip that holds them into the CCU (I think that's the right term) has a ... with my fingers so I could get a couple loads of laundry done until I can .
Jan 05, 2016 | Washing Machines
How do I stop my washing machine door alarm beeping?
do this and fix it. God bless you
However read the instr. manual section troubleshooting /
if doesnot have download from www.fitness.manualsonline.com
The processes below will get most controls unlocked.
Duet Washer - Press and hold the END OF CYCLE SIGNAL button for 15 seconds.
Whirlpool Duet Dryer - Press and hold the END OF CYCLE SIGNAL button for 15 seconds.
Kenmore Elite Washer - Press and hold the DRAIN/SPIN button for 15 seconds.
Some Models- Press and hold the control lock button for 15 seconds.
If none of these work try unplugging for 5 minutes
Sep 28, 2012 | Hotpoint WMA74 Front Load Washer
WASHER MODEL WCVH6260 LOCK MODE
see this and fix it. God bless you
However go to instr .manual and read the section troubleshooting if you do not have it download from www.fitness.manualsonline.com
Sep 28, 2012 | GE WSXH208A Front Load Washer
My front load has a f 6 code flashing
F06 is an error code that meansthat the control is unable to properly detect motor speed and the machine will shut down. If a failure occurs during high-speed spin the door will be unlocked after 3 minutes.
Potential Causes
• Check wire harness connections between the Drive Motor/Tachometer and the Motor ControlUnit (MCU), and between the MCU and the Central Control Unit (CCU)
• Check the Drive Motor
• Check the MCU
• Check the Wire Harness
Replace failed component.
Read more: http://www.appliancepartspros.com/repairtips/repairtips_appliance+fault+codes.aspx#Whirlpool Duet Front Loading Automatic Washer Fault Codes#ixzz1goJUbb8i
Dec 05, 2011 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
Describe your Whirlpool Duet GHW9150P Front Load Washer Problem the control lock button is on
Hello & Welcome to FixYa
This is a common issue with Whirlpool Duet washer however; your whirlpool duet washer needs a reset to resolve the control lock problem. Press and hold the END OF CYCLE/CYCLE SIGNAL button for 15 seconds to reset the control. Please get back to me if you have any other questions.
Kevin
Aug 15, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Duet ht washer control locked. How do I unlock it? Really need your help
This is a common issue with Whirlpool Duet washers however, your whirlpool duet washer can be reset to resolve the control lock problem. Press and hold the END OF CYCLE/CYCLE SIGNAL button for 15 seconds to reset the control. Please get back to me if you have any other questions.
Kevin
Apr 25, 2011 | Whirlpool Duet GHW9150P Front Load Washer
I have a duet ht washer.the control lock is on ,how do i cancel this? I have forgotten .THankyou Janet
To unlock the control lock press and hold the cancel button down for 5 sec or till you here a beep.
Good luck
Sep 25, 2009 | Whirlpool Duet GHW9150P Front Load Washer
GE WBVH6240F Front Load Washer Logo
397 people viewed this question
Top GE Washing Machines Experts
Marvin
Marvin
geapptech
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
