Question about Kenmore 24032\24036 Top Load Washer
KENMORE SERIES 80 BALANCING PROBLEMS
I HAVE A KENMORE SERIES 80 WASHING MACHINE THAT WON'T SEEM TO BALANCE. IT IS LEVEL SIDE TO SIDE AND FRONT TO BACK, IT IS ON A SECOND STORY FLOOR (NEW HOUSE) BUT HAVE NOT HAD PROBLEMS BEFORE. WE HAVE PUT THE MACHINE ON ABOUT 6 INCHES OF PLYWOOD TO SEE IF IT WOULD PERFORM ANY BETTER BUT NO CHANGE. WHEN WE WERE MOVING THERE WAS A BLACK GASKET LOOKING PIECE THAT CAME OUT FROM UNDER THE WASHER - NOT A BELT OF ANY KIND - BUT MORE OF A FOAM RING ABOUT EIGHT INCHES IN DIAMETER, ANY IDEAS
  • 1 more comment
  • bbwizard95 Jan 28, 2008
    Series 80 wouldn't spin/agitate. I replaced the broken coupler and found the same foam ring loose. Now it agitates fine..and as it reaches the higher spin speed begins a high pitched howl, and sometimes a popping noise also. Balance is good (even for pitch & yaw) with no rocking.
  • diesel08 Mar 28, 2008
    machine is level side to side and front to back and no matter what size load it shakes violently in any spin cycle. i took the cabinet off the machine and didn't find anything broken or missing. the machine is only a couple years old and just recently started doing this. VERY AGGRAVATING!!!
  • Gary Davd
    Gary Davd May 11, 2010
    I dont know what the foam peice would have been from but you may have broken a support spring on the unit is the bottom rusty?? If you want to venture into the unit please let me know.
  • 114 Answers
The only thing I can suggest is to make sure the load is evenly distributed around the circumference of the tub. If you do only light to medium loads, this can occur from time to time. Lift lid as the unit goes into the spin cycle to check. If it is evenly distributed, you may have a support problem.
Posted on Jan 24, 2008
Kenmore Series 90-110.26932691 washer spin cycle is off centered what do I look for?
you have to check that the machine is level all round so front to back and side to side with a spirit level also change the spring
Sep 10, 2016 | Kenmore Washing Machines
Loud banging noise during spin cycle
If you balanced the machine, the only other problem could be the load itself. Either the load is too great or if washing a single item its falling to one side, tilting the drum and when spinning it will thump. Try even lodes.
Jan 31, 2018 | Washing Machines
Kenmore series 80 washer off balance
Go to www.applienceparts.com and ask them for assistance, it is a free service.
Mar 13, 2017 | Kenmore Washing Machines
During the spin cycle, the washing machine rattles loud almost as if its off track, it is the 80 series kenmore top load
souns like the gearbox (what the motor mounts to) it bad. I'm asummin the load in the washer is balanced (all the clothes are not on one side of the tub)
Jul 05, 2009 | Kenmore Washing Machines
WF865 noise when spinning
Washers have to be balanced. Some have balance adjusters either inside the dryer as explianed above or on the bottom to level the washer. try to balance it by turning the bolts slightly or the bottom portion of the washer to level it. Or else they want to shake apart. Also by distributing the clothes evenly so it won';t be all to one side can help. do not tighten the screws all the way. Just tighten them to the point of getting the right balance.
Jun 16, 2008 | Hotpoint Ultima WF865 Front Load Washer
Kenmore 700 series washing machine
check to see on the top of the basket if there is a balance ring it will look like a large doughnut if it has one and if it is loose or if the fluid in the ring has leaked out then this will cause the out of balance while in spin let me know if i can help 276 523 4434
Apr 25, 2008 | Washing Machines
Wiz, That black piece of foam is just a sound dampening strap, no big deal. This is a hard one, I see a lot of these vibrate when there is a false floor. Here are some things to check: makes sure the front legs are locked with the nut. Check to see that all the springs are attached and the plate is centered, I will attach a photo. Depending on whether the machine is walking or just the tub banging, it could be the drive block for the basket. You will have to remove the cabinet or tip it back to check the springs. Catriverdf505ed.jpg
Jan 28, 2008 | Washing Machines
Kenmore washer
how old is it reply will help
Dec 30, 2007 | Kenmore 24032\24036 Top Load Washer
Kenmore Waher spin cycle out of balance
Sounds like your front to back spring is pulling to tight, sometimes you need to replace it and sometimes you can take it off and stretch it. hope this helps
May 19, 2007 | Kenmore 24872 Top Load Washer
Kenmore 24032\24036 Top Load Washer Logo
109 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
