Question about Panasonic DMR-E50 DVD Recorder
My display on the dmr-e50 shows ready but will not turn on.
The unit was working fine but the next time I tried to turn it on, the display shows ready and does nothing. It will not open or change the display. What can this be??
    Genius:
  • 1,003 Answers
UNPLUG UNIT FROM THE WALL SOCKET & REPLUG AFTER 12 SECONDS.
Posted on Jan 23, 2008
Hi, I have DMR-E60 I have original Remote control but when I press any button, on a display shows remote dvd 2 ,please tell me what can I do. Thanks
The remote and the DVR are not paired correctly. This is a feature which allows the use of 2 units from the same manufacturer without each remote controlling both units. There will either be a small switch in the remote's battery compartment, a sequence of button pushing on the remote or an option to pair the remote in the DVR's menus to change from remote 2 back to remote 1.
Oct 08, 2011 | Panasonic DMR-E50 DVD Recorder
Tip
DMR-E50 Fixed!
My E50 stopped working yesterday. All that was working was the cooling fan. I knew it had to be related to the power supply, so I got a screwdriver.
I found that the power supply board inside had two "bulging capacitors". For those that don't know, these are capacitors that look sort of like Jiffy Pop popcorn. The top is puffing up like it's going to explode. A good capacitor should be flat on top.
I carefully removed the existing (bad) capacitors, and I replaced them with similar rated capacitors that I yanked from an old computer motherboard. You can also buy them online for about twenty-five cents a piece. After soldering them on the board, I put everything back together.
I carefully plugged the unit back in, not 100% sure that something would explode.
WOW! It came on... not only that, but it played a disc. After that, I recorded a show. My recorder is back!
I just wanted to share this in case any of you with the DMR-E50 were heading to the trash can. I should also add that any of you not experiencing power problems, but maybe having inconsistent behavior, might want to check the capacitors. I know from experience that PC's with bulging capacitors have a variety of symptoms including just shutting off out of the blue.
I hope this helps somebody out there. Just remember to unplug everything and be careful. That's my disclaimer so I don't feel guilty. :)
on Jan 18, 2008 | Panasonic DMR-E50 DVD Recorder
Machine stuck on remote dvd 2 setting
Try holding 1 and enter at the same time for more than 3secs
Nov 16, 2009 | Panasonic DMR-E50 DVD Recorder
Actually I have a 4 yr old dmr eh50 panasonic dvd recorder
Make sure remote is set to unit code ex: press enter and 1 at same time see if this matches try enter and 2 or enter and 3 see if this matches and works
Oct 03, 2009 | Panasonic DMR-E50 DVD Recorder
Panasonic DMR-E50 no power
Check the two pin power plug on the back panel.
These units have a common problem on the power board where a regulator overheats and finally blows. Sometimes even before it blows it will take out an internal fuse. If the power board is faulty the repair is easy for an engineer and not too expensive.
Mar 19, 2008 | Panasonic DMR-E50 DVD Recorder
NO FUNCTIONS
Replace the Digital board
Feb 26, 2008 | Panasonic DMR-E50 DVD Recorder
DMR-E50 DVD recorder versus DMR-ES15 are these equivalent recorders
The DMR-ES15 is a later model (around 2006/07) than the DMR-E50 (2003/04), but essentially both should do the same job so technically - a good equivalent in terms of recording and same brand so yes. The connections on the rear (of the replacement recorder) should suit and work with your other devices just as the old one did.
According to some other online reviews, the DMR-E50 has had a few issues with recording, and finalizing certain discs.
I'd say go for it - accept the replacement - as long as it comes with some kind of guarantee, works fully and has all the accessories (including remote, instructions etc.) you should be good. Contact the store and seal the deal.
I hope you can get this in time for Christmas.
Dec 21, 2017 | Panasonic DMR-E50 DVD Recorder
Panasonic dmr-e50 remote control
The aswer is in the manual that can be had on line, page 45. You have 3 different remote types, 1,2,3, All you have to do is hold down the ENTER button and the number 1 or 2 or 3 on the remote for a few seconds and it will change the setting.
Jan 13, 2008 | Panasonic DMR-E50 DVD Recorder
No finalising of discs.
USE MEMOREX DVD-R IT IS A HIGHLY COMPATABLE DISC AND HAS WORKED GREAT FOR ME
Nov 02, 2007 | Panasonic DMR-E50 DVD Recorder
DVD DMR-E50 Doesn't Work
As it's been 5 months I suspect problem's been solved - how? I have similar problem, E50 recorded DVD-r's lock up after playing about an hour. RAMs and commercial DVDs play fine.
Aug 12, 2007 | Panasonic DMR-E50 DVD Recorder
Panasonic DMR-E50 DVD Recorder Logo
90 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
