Question about HP Pavillion a818n Desktop PC (Refurb) Pentium 515(2.93Ghz) 512MB 160GB (PS453AAR)
Computer won't boot with chime-ing
I could not find a valid product on the list offered, so I picked what I thought was closest to my computer. My computer, a different model is not refurbished.
When I turn my computer on, an HP Pavillion a1150y, I get this chimeing sound from the rear inside of the computer and windows does not load. I get a message that the monitor is going to sleep. I had a similar problem while the computer was still under warrenty. It turned out that the power cord connection was loose (I try to keep the computer covered when not in use, and the cover pulling down on the power cord loosened the connection). When the power cord was reconnected, the chimeing stopped and the problem was fixed.
Well this time when the chimeing started, we turned off the computer (had to do it by the switch on the power strip, because windows had not logged on, so I couldn't log off. We checked all the connections on the back of the computer, turned the power back on and the computer booted, windows loaded and I connectd to the internet. Shortly thereafter my computer screen filled with columns of bars (the bars had blocks of various flashing colors) and my mouse froze. I tried control+alt+delete, but the computer did not respond to that and again had to end by turning off the power strip. Does anyone know what causes the chimeing sound other than a loose power connection and where do I go from here. I would like to fix the computer myself, if I can (must be easy, I have low expertise) or, if I have to take it somewhere for repair, I would like to have an idea of what might be wrong, so I have an idea of how much it will cost to fix. Any advice on how to find good repair will be appreciated. Thank you.
  • 1 more comment
  • EdwinaH Jan 23, 2008
    Thank you for your fast response. The computer is not beeping. The sound it is making is a rapid chime, kind of like a fire alarm, only not quite so loud.
    Ok. Thanks for the suggestion. I will give it a try and see what happens. I will get back to you and let you know what happened. Thanks again.
  • EdwinaH Feb 01, 2008
    It took me awhile to get what I needed, and to get the courage to open the CPU, but we finally did and yes the fans were dusty and blowing out the dust solved the problem. No more alarm. Thank you so much for your helpful advice. It was right on!
    Master:
  • 788 Answers
If it beeps in a pattern (example 2 long 3 short) then I would need to know the pattern. With that pattern I could try to determine when the faulty component is.
Posted on Jan 23, 2008
  • Dean Joly
    Dean Joly Jan 23, 2008
    That could indicate overheating, I would suspect that a fan is stuck or stopped spinning. Open up the machine and dust out the fans with some compressed air. If they are stiff to turn with your finger then they need to be replaced. Don't forget the one in the power supply.
Currently, this hardware device is not connected to the computer. (Code 45)
  1. Turn the computer off.
  2. Turn the computer back on.
  3. Immediately at the Dell logo screen, starting tapping the F12 key once a second until the One Time Boot menu appears (if the computer boots to Windows turn the computer off and try again).
  4. At the One Time Boot menu, press the arrow key to highlight Diagnostics and press enter
  5. Write down any Error Codes and Validation codes listed.
Jun 22, 2014 | Dell Inspiron Computers & Internet
Gray screen on macbook pro
does it chime?
could be ok if it chimes.
could be bad ram, bad hdd, spill damage, liquid damage, might need new logic board. Places on ebay offer repairs for flat rate for about 250 bucks.
Feb 12, 2014 | Apple MacBook Pro Notebook
2003 Cadillac CTS won't start after disconnecting battery
Don't do that again! You will need to re-boot the on board computer system by entering a code. Call your nearest Cadillac dealer.
If you need further help, reach me via phone at https://www.6ya.com/expert/lloyd_4256582adacd68ee
Nov 28, 2011 | 2003 Cadillac CTS
Won't boot from dvd or hard drive, changed hard drives and still won't boot
Depends on what you mean by won't boot from DVD or Hard Drive,
it sounds like your boot order is what you're looking for help for.
To do this you need to get into your computers BIOS (or "Setup")
You can do this by rebooting the computer and the very very very first screen you see tells you how,
usually by pressing DEL or F2 or F10.
Without knowing the specific computer you're looking for help on I can only point you in the right direction however keep in mind the BIOS is for advanced users only and you can damage your computer by randomly changing settings.
What you're looking for though is usually called the Boot Order or Boot Sequence
You'll need to set whatever device you want to boot from higher on the list (usually with the up arrow or PgUp)
If you don't see your device on the boot list then it may not be detected due to failure.
May 31, 2011 | Computers & Internet
My computer was fixed by a person who installed xp pro on it but he didn't have a validation key. Well i found my original install cd with the xp home edition and i want to do a clean install to install...
really simple just turn put the cd in turn off the pc and reboot, your cd drive should pick it up on boot up from there its simply following directions
Jun 24, 2009 | Computers & Internet
Pop up window upon booting computer
Hi Barbara,
I recommend you to visit the below web link and follow the instructions provided in the document to resolve the issue.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01631295&cc=us&lc=en&dlc=en
This should resolve your issue. If not reply for further assistance.
Apr 29, 2009 | HP PSC 1410v All-in-One Printer
My desktop says that my computer did not pass genuine windows val
For Windows XP Home
Restart your computer and before the appearance of the boot screen hit F8 to get the booting option list. From the list select Safe Mode in order to start your computer in Safe Mode.
Once the computer has booted in Safe Mode go to Start > Run and type c:Documents and SettingsAll UsersApplication DataWindows Genuine Advantage (where C: is usually the system drive).
Right click the DATA folder and choose Properties. Now go to the security tab and in the Group or user names section click on Users. In the permission for user section make sure you check all the check boxes under the Allow column: Read & Execute, List Folder Contents and Read. Click OK and then restart the computer. Now you should be able to validate your Windows copy.
For Windows XP Professional
In Windows XP professional there is no need to boot in safe mode. Just go to Start > Run and type c:Documents and SettingsAll UsersApplication DataWindows Genuine Advantage. There you will find the Data folder. Right click on it and follow this path: Properties > Security tab > Users > Permission for users section and verify the Allow column for all the check boxes to be selected. If not selected, do it yourself.
Now restart the validation process.
for more help go here:
http://www.mydigitallife.info/2006/03/07/bypass-and-disable-genuine-windows-validation-check/
Mar 20, 2009 | Dell Dimension 4300 PC Desktop
I think i killed my wife's mini
Best Buy geek squad might fix Macs. Try booting up the computer with out the hd plugged in. And then plugging it into the computer after it has booted up. I've found that unplugging the power from the computer for an hour or so and plugging it back in can sometimes magically fix some booting problems.
Oct 16, 2008 | Apple Mac mini 2Ghz/2GB/120GB...
Computers & Internet Logo
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
