Question about Goodman GDS80904BNA Open Flame Heater
Goodman GMP125-5 Air Handler
My blower is not starting, I measure 207VAC across the starter cap, when it is trying to start. The motor (cage) spins freely until it is energized... Any suggestion?
The furnace is kicking on, the flames start, and then after about 2 minutes it shuts off because the blower iss not starting
It has a 12uf 370VAC Ge Capacitor CAP125370
  • Kuyer Jan 24, 2008
    Thanks, for the REALLY quick response, I looked at the time of the e-mail and was shocked at how fast you reponded.. Unfortunately I didn't read this until the next day.
    I was pretty confident that it was the motor, because the motor was humming, so I knew there was voltage to it.. I had the cap tested and it was 11.7uf, so I ordered the motor and installed it plus I put a new cap in too, because it was only $12.
    But I would recommend you to everyone, as you reponded so quickly! Next time I may wait for the response, but I never did it before, and given the time of year, I had to act fast..
    Thanks so much!!!
    Debbie (I used my husbands name before!)
    Genius:
  • 1,003 Answers
REPLACE BLOWER MOTOR
if its spinning free until motor is energized motor may have bad armature or brushes.
If you energize blower and manually give fan motor a spin will it start if so replace cap.
Posted on Jan 23, 2008
I need to replace my blower motor on my air handler
Turn off power to machine and have a 5/16" or 1/4" nut driver handy take off front door of machine. Take a rubber coated Screw driver and place across the terminals of the Capacitor to discharge any stored electricity. Cut wires for blower Black, Red, white, two browns one with white lines on it probably. Look inside machine and locate where bracket holds squirrel cage to air handler and there you will find either 5/16" or 3/8" screw remove pull bracket out. Then you will need a 1/2" socket and a crescent wrench. Remove screws for motor bracket that is attached to squirrel cage. Also you need to loosen the set screw that attaches blower wheel to motor. Apply wd-40 if needed to remove blower wheel from motor. Then install new motor on the flat part of the shaft comes through wheel attach set screw to motor shaft at that position. Install new cap that goes with motor. place entire housing of motor back into air handler and then follow wires that where previously cut back to either relays, sequencers, or fan timer board located in top section of air handler. Tighten everything up and turn power on and make sure air is coming out of vents. Then your good to go.
Apr 29, 2011 | Heating & Cooling
I have a Goodman Furnace that doesn't turn on. If I spin the blower it will run, blower just buzzes and still buzzes while running. It shuts itself off after twenty minutes. I can resets it and spin the...
First I would suggest that you replace the start capacitor on your blower motor but if it is running for awhile that makes me wonder if the thermal overload is shutting your motor off. You can replace the start capacitor and then if it starts as it's supposed to and then shuts off you'll know the motor needs replaced also. I hope this helps you . THanks
Nov 30, 2010 | Goodman CLQ24AR42 Air Conditioner
Goodman ac heat air handler starts noisily for about 30 seconds then stops. Condenser fan is okay. Inside fan works but seems weak. I can't find the model number, so I just picked the first one.
inside the air handle there is a motor and a cage(squirrel). I am assuming this is the problem. The side that has the pilot light, take this cove off first, then the back cover. There is a switch so when you take the back cover off it opens the circuit. You will see a main board and to the left and behind is the motor and squirrel cage. I would kill power and then remove the bolts making sure I make the wires and where they go. Then just take the motor and cage out. You will need a allen wrench to remove cage, then replace motor. Hope this helps Tim
Aug 01, 2010 | Goodman CKL60AR60 Air Conditioner
Blower motor replacement on an Armstrong 51HWC242A-88?
the blower motor is located in the air handler. It has a squirrel cage around it you will need a puller to pull the cage off you must first unthighten the set screw on the motor shaft. Then replace the motor with a motor that has the same specs as the one you took out.
Jun 12, 2010 | Heating & Cooling
RUUD UBHA-14 J11SFJA air handler. The fan (blower) doesn?t runs
Absolutely, however, you want to properly diagnose the reason why the fan is not running. It could be a less expensive part than the fan motor itself.
First, check to see if you have the proper voltage going to the motor. I believe your motor requires 240volts ac. If you do not have 240 volts, you have a control problem.......either the thermostat is failing to close R & G or your blower relay may have failed to close the contacts necessary for your fan to operate.
If you have the voltage, then you want try spinning the blower wheel with your hand. Does it spin freely? Is the motor warm/hot? If so, turn everything off for an hour or so. As soon as your energize it, try spinning the motor with your hand again.....if it spins freely with no resistance and then starts running by itself, the problem is the run capacitor (approx $20.00 depending on where you purchase it from). If there is resistance when you try to spin it, the problem is most likely with the bearings and you will need to replace the motor.......if you have to replace the motor, go ahead and replace the capacitor also, making sure it is properly "matched" with your new motor.
I hope you find this to be very helpful to you, moving forward. :-)
Mar 28, 2010 | Ruud Handler Air Conditioner
Air handler running but nothing coming out of
Shut unit off, remove door that would have the blower
located in it. Make sure that the blower motor has not seized up. Try to spin it with your hand.
If the unit starts up ,fires up and shuts down all the time, more than likely the blower motor is the problem
Feb 13, 2010 | Goodman CLQ36AR49 Air Conditioner
My squirel cage blower motor fails to start
Hi there the main problem is the run capacitor on the side of the blower cage has gone bad.
But you have replaced that..
The Next Problem is that one of the magnets inside the motor had demagnetized and is not allowing the cage to freely start But makes since that you can hand start the motion of the motor
Need A New motor Sadly to say
But sometimes you can have them rebuilt for less than a new motor
Any other questions just ask
Bryan
Jul 08, 2009 | Goodman CKL42AR42 Air Conditioner
Replaced blower motor on coleman ac
You MUST always replace a capacitor when you replace a capacitor start/run device.
Replace the cap.
May 24, 2009 | Coleman Heating & Cooling
Fan blower overheating
Sounds like your motor is bad check when it was installed all the units have a 5 yr warranty on parts but a HVAC contractor has to change it for the warranty
Dec 09, 2008 | Ruud Handler Air Conditioner
Heating & Cooling Logo
415 people viewed this question
Top Goodman Heating & Cooling Experts
Paul Carew
Dennis Boxerman
vance jones
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
