Question about Samsung HLN617W 61" Rear Projection HDTV
Samsung DLP HL-R6167W
ITV is three years old, using the HDMI input, sometimes my screen would turn green and if I played with the input connector on the TV it would be ok, now it appears it does not work at all. The TV says there is a HDMI input but no picture, says weak signal or lost signal. I took the DVD player into store and it works fine, I also replaced cable but still does not work. Is there something I can check or do I need to have a repair person check it out.?
Thank You
  • Anonymous May 27, 2008
    I just recently had this problem when I hooked up a new sony blu ray player. Called sony and they had me try the player on another tv with hdmi hook-up's on it and it worked perfect. Called samsung about the green screen problem when hooked up to the blu ray with hdmi cable. First thing I did was install a better hdmi cable. Second, I unplugged both the tv and my blu ray player and then reconnected them both and plugged everything back in. Turned everything on and now its been working fine for a few weeks.try it, it might just work for you
  • 3 Answers
Try unplugging everthing first...Make sure you are using a quality hdmi cable...Reconnect everything, plug in the power cords and see if this works for you. I had the same problem with my sony blu ray dvd player and after some research and a few calls to sony and samsung this process worked for me. I was using a radio shack hdmi cable that was for some reason disrupting the transmission between the two products. Also I found out from samsung the tv needs to be off for the tv to accept this new connection. It work for and its been a few weeks now.
Posted on May 27, 2008
    President:
  • 1,284 Answers
Most likely the digital board will have to be replaced. Not a cheap part, so you might concider using the component inputs for now if too expensive.
Posted on Jan 24, 2008
Green Lines on Samsung DLP
Either bad capcitors, or (if you're lucky) the color wheel needs lubed up. Probably bad caps.
Jun 12, 2012 | Samsung Televison & Video
Samsung DLP HL-R6167W - works fine for about 5 seconds then the screen freezes, sound goes out and then goes black then comes back on by itself and repeats the whole process. No blinking error lights.
There are three possible parts causing the problem. First, the Main or Digital bd is bad, Second, the DMD bd is bad. Third the Color Wheel is bad. You need a trained Samsung tech to have a look at it.
Jul 12, 2009 | Samsung HL-R6167W 61" HDTV
Green shade color on screen over tyhe program that is been broadcast
its a loose connections to you color amplifier RGB. cold solder in that board section.
May 30, 2009 | Samsung HL-R6167W 61" HDTV
Problem with HL-R6167W green vertical lines
You need to do an aggressive reset on the TV. This solved problem completely for me. You must unplug the TV when it is on. Repeat this several times until the TV is jolted back into the factory default settings. The issue is actually with the programming I believe. The clue was that the display worked 100% perfect in HDMI mode, and the problem only existed in the cable setting, no matter if wires were attached or not.
Again, do an aggressive reset to the TV by unplugging it several times while it is on. It may not register the reset at first because after all, the actual problem is a programming issue and it's having trouble recognizing commands in the first place.
Good luck!!
May 29, 2009 | Samsung HL-R6167W 61" HDTV
Samsung HLR5067W goes from a normal picture to snowy green color
Greetings!
I hate to be the bearer of bad news, but it is not something that has a quick fix. Without inspecting it myself it is impossible to say, but the last three of these that I have seen have been bad digital boards and can be a real bear to change, even when you have experience.
I would get slightly different video symptoms when I would switch between the coaxial input to the component input to the HDMI input. But in all cases my on screen display and menu were anomally free. Hope this was helpful, even though I don't think it is something you should attack yourself.
Rob
Jan 14, 2009 | Samsung DLP HL-P5663W 56" TV
Samsung HL-R6167W set turns itself off
sounds like the digital main board, seen this before
Jul 18, 2008 | Samsung HL-R6167W 61" HDTV
Samsung HL-R6167W DLP color problem/buzzing noise
My 3 yr old Samsung DLP has the same buzzing noise, had a tech out today and he said "color wheel". Thank goodness I purchased that expensive warranty, This is my 4th repair in 3 years.
Dec 24, 2007 | Samsung DLP HL-P5663W 56" TV
Samsung HLN617W 61" Rear Projection HDTV Logo
273 people viewed this question
Jerry Greenberg
Jerry Greenberg
