Question about AT&T ATT-1855 Corded Phone
No message recorded. Static when in use.
Incoming call announcement is normal, the 'beep' is heard, but no message is recorded. When testing the intended message can be heard on the speaker, the machine does not hang up as quickly as it used to, and the new call is not counted.
There is also static on the line which can also be heard by the caller. There is a cordless phone attached to the same jack that functions ok.
Thanks in advance for any assistance.
Hello FixYa Community! I hope someone has an idea of why my 1855 phone's answering machine is nothing but static on both ends, caller and when I want to retrieve msg. Everything else works just fine??? I really don't want to replace it because it's a pretty good phone. Please help in one way or another!
Posted on Mar 12, 2010
  • 319 Answers
It sounds like you have damage to an internal component of your phone.
HERE is a link to the manual, if needed.
Posted on Jun 17, 2008
My KX-TG2322 takes neither incoming messages nor outgoing ones` it says 'Memory Full', although no message is there.
Erasing all messages
All recorded messages, except the greeting
message, can be erased at one time.
1-Press [ERASE] while the base unit is not
being used.
• "To erase all messages, press ERASE again" is
heard.
2-Within 10 seconds, press [ERASE] again.
• The unit beeps, then announces "No
messages".
• The base unit display shows "0".
Mar 08, 2015 | Panasonic KX-TG2322B - 2.4ghz Digital...
Record messages
Make sure it's in the "Answer" mode, not the "Announce" mode. The Announce mode merely plays an outgoing message but does not record an incoming message. The Answer mode does record incoming messages.
Since you declined to specify the model of your Uniden phone I can't tell you exactly how to switch modes. Select the model of your phone from the list beginning here to download a copy of the manual.
Mar 19, 2012 | Uniden 5.8GHz Expandable Cordless Phone...
Code to retrieve messages
Here are the instructions you need to follow:
If you want to be able to play your messages from a remote location, you need to enter a two-digit Personal Identification Number (PIN) code (01-99).
To select a PIN, perform the following steps:
1) With the phone in standby, press [menu/clock] twice.
The system announces "Security code," and the current PIN code is announced as it is displayed on the base.
Then the system announces the instructions for setting the PIN code.
2) Press [volume/select/ ] or [volume/select/ ] until the desired number appears.
3) Press [set] to select the PIN code. You hear a confirmation tone, then the announcement "Security code" followed by the new PIN code is announced. After a few seconds, the system announces "To set ring time, press menu again."
Note: The PIN code is set to "80" at the factory.
Remote Operation
When you are away from home, you can operate your answering machine with any touch-tone telephone. Use this function to check for recorded messages, to play or delete messages, even record a new greeting message.
1) Call your telephone number.
2) During the greeting message, press [0] and enter your PIN code
3) The answering machine announces the current time and the number of messages stored in memory. Then you hear "To play incoming message, press zero two. For help, press one zero."
4) You may continue to listen to the voice prompts, or you may select a command from the following chart:
Command Function Command Function
[0] then [1] Repeat a Message [0] then [6] Answering Machine On
[0] then [2] Play Incoming Messages [0] then [7] Memo Record/Stop*
[0] then [3] Skip a Message [0] then [8] Greeting Message Record/Stop*
[0] then [4] Delete a Message [0] then [9] Answering Machine Off
[0] then [5] Stop Operation [1] then [0] Voice Prompts
* For Memo Record and Greeting Message Record functions, the first time you enter the corresponding command, it
starts the Recording function. If you want to stop the recording, enter the command again.
Note: Once you enter the remote access menu, you must enter a command within 15 seconds, or the
answering machine automatically hangs up and returns to standby.
5) After all of the voice prompts have been played, you hear intermittent beeps indicating that the system is in the
command waiting mode. You may enter another command at this time from the chart.
6) When you are finished, hang up to exit the system. The answering machine automatically returns to standby.
Turn on the Answering Machine Remotely
If you have forgotten to turn on your answering machine, you can turn it on remotely from any touch-tone telephone.
2) Wait ten rings until the system answers. You hear intermittent beeps.
3) Press [0] and then enter your PIN code. The answering machine announces the number of messages stored in memory. You hear "To play incoming message, press zero two. For help, press one zero."
4) Press [0] then [6] to turn the answering machine On. You hear the outgoing message and a confirmation tone.
5) Hang up the phone; subsequent calls will be answered by the system.
Feb 28, 2010 | Uniden EXAI5680 Cordless Phone
I need to rerecord the greeting message for my phone system.
According to the instruction manual, which can be found at: http://telephones.att.com/docMgt/public/art/175/1872_manual.pdf,
TO RECORD AN ANNOUNCEMENT:
1. Press A.
2. Choose the announcement location by
pressing s until the appropriate
mailbox is displayed.
3. Press R. Begin speaking after the beep
4. When you are finished, press S.
You will hear your new announcement.
5. Repeat Steps 1-4 to record another
announcement
— OR —
Press S.
TO REVIEW YOUR ANNOUNCEMENT:
1. Press A.
2. Press s to choose the announcement
you want to review (A, B, C, AO,
MBOX 3, MBOX 4).
3. Press P to hear the selected
announcement.
Or, if you're away from the office,
CHANGING ANNOUNCEMENTS:
You can re-record any of the announcements
currently in use by any
line or mailbox.
1. Contact the answering system.
2. After two beeps press a number key
(1-4) to select a line or mailbox, then
press 4*. The system beeps and begins
recording.
3. Speak into the telephone in a normal tone
of voice.
4. Press # when you are finished. The
system beeps once and plays the new
announcement.
To review your announcement, press a
number key (1-4) to select a line or mailbox.
Press 41 after the two beeps to play
your announcement.
NOTE: If announcement is being used by
both lines, re-recording the announcement
will change the announcement heard on
both lines.
Hope this helps!
tkhusa420
Sep 25, 2009 | Lucent 1872 Corded Phone
How do you record outgoing message?
1 Prepare your announcement. Each
announcement can be up to 4 minutes long.
2 Press A.
3 Press and release S until you see
the letter of the announcement you want
to record (A, B, or O).
4 Press R. Begin speaking after you
hear the beep. Speak in a normal tone
of voice, about 9 inches from the
microphone.
5 Press S. The system plays your new
announcement. To hear the announcement
again, press P.
6 Repeat Steps 3 to 5 to record another
announcement, or press S.
To assign an announcement to play:
SELECT ANNOUNCEMENT CALLERS HEAR
1 Press and release F until the screen
displays ANNC.
2 Press and release S until the screen
displays the announcement you want
callers to hear (A, B, or O). If you
select AO, you must record an announcement,
as instructed in “Record an
Announcement.”
3 Press S to return to the message display
Jul 02, 2009 | Lands Phones
How to change announcement ?
Before using this answering system, you
should record the announcement (up to
one minute long) that callers will hear
when the system answers a call. If you
choose not to record an announcement,
the system answers with a prerecorded
announcement: “Hello. Please leave a
message after the tone.”
1 Press and hold "ANNC/SKIP" . The system
beeps. Speak toward the microphone
normally, from about nine inches away.
While you are recording, the Message
Window displays —.
2 To stop recording, release "ANNC/SKIP".
The system automatically plays back
your announcement.
and release "ANNC/SKIP".
Nov 10, 2008 | AT&T 1717 Digital Answering Machine
1738 att answ machine-need to change message
Record Your Announcement
three minutes long) that callers will hear
the system answers with a pre-recorded
announcement: “HELLO. PLEASE LEAVE A
MESSAGE AFTER THE TONE.”
1 Press and hold a. When the
system beeps, speak toward the
microphone normally, from about nine
inches away. While you are recording,
the Message Window blinks .
To stop recording, release a.
your announcement.
and release a.
To erase your announcement and
return to the pre-recorded announcement,
press Dwhile your announcement is
playing.
Callers can skip the announcement by
pressing #.
Aug 10, 2008 | AT&T 1738 Digital Answering Machine
Won't record messages anymore
You must record your announcements (A, b,C and RO) one at a time.
1 Select the announcement you wish to record.
2 Press and hold "ANNC/SKIP". When the system beeps, speak toward the microphone normally, from about nine inches away.
3 To stop recording, release "ANNC/SKIP". The system automatically plays back your announcement.
To review your announcement, press and release "ANNC/SKIP".
To erase your announcement and return to the pre-recorded announcement press "DELETE" while your announcement is playing.
Apr 18, 2008 | AT&T 1726 Digital Answering Machine
How do I change the recorded message?`
2 To stop recording, release a.
your announcement.
and release a.
playing.
pressing #.
HAPPY TRAILS!!
Apr 17, 2008 | AT&T 1738 Digital Answering Machine
Help! Re-recording message
Following are instructions for the GE25881 phone which is similar to your 25880. Hopefully this will work for you. -Vish Answering System Set Up This section shows you how to set up your answering system to receive incoming calls. Before you begin the setup, you must turn on the answering system. ? Press the conference/ans on/off button to turn the answering system on and off. NOTE: The display shows ANSWERER OFF when the answering system is off. The default status is on. Voice Instructions If you need additional assistance, press and hold the memo button on the base and follow the voice instructions. 12 Answering System Operation Recording the Outgoing Announcement For best results when recording, you should be about nine inches from the microphone, and eliminate as much background noise as possible. 1. Make sure the answering system is ON. 2 . Press and hold the announce button on the base while you record the announcement. 3. Begin speaking after you hear the beep. 4. Release the button after you finish your announcement. If you choose not to record an outgoing announcement, the default announcement plays. To return to the default announcement after you have recorded your personal announcement, press the delete button on the base while playing the announcement, or press the announce button and release it when you hear the beep.
Jul 23, 2007 | GE 25880 Twin Phone
AT&T ATT-1855 Corded Phone Logo
208 people viewed this question
Top AT&T Lands Phones Experts
Paul C.
Are you an AT&T Lands Phone Expert? Answer questions, earn points and help others
