Question about Intel D915GAG Motherboard
Windows xp i purchased 2 x 1 gb ddr 400, when i install it and reboot my pc, it loads windows xp but it doesn't go to the desktop, the screen stays black and i cant turn the pc off from the power button, it just stays on, please help
  • 2 more comments
  • sjr37 Jan 23, 2008
    yes, ok 2 pc of 1 gb ddr 400, why does windows xp fail to start properly and what stops me turning the pc off from the power button?
  • sjr37 Jan 26, 2008
    tried putting the memory in the blue slots, even updated the bios, still getting the same problems
  • little_mac8 Aug 19, 2008
    I have the same problem but i bought 2 x 512MB and have tried installing them separately & also with the other 2 x 256MB stick that were already in there and get a blank screen.
  • Louel Bernal May 11, 2010
    you mean 2 pc of 1gb ddr 400?
    Problem Solver:
  • 17 Answers
Use only 1-1GB stick. xp reacts really funny to 2-1GB sticks, I had this problem before and it works fine with 1 stick. If you do try to add the second stick, it;ll scerw-up on you. let me know if this helped. tallcoolone100@yahoo.com
Posted on Jun 22, 2009
    Problem Solver:
  • 17 Answers
I guess you should try first putting one ddr at a time.. i mean, you first try one ddr then run your computer and if gets inside your desktop... shut it down then try putting another one.. that makes 2 ddr running in your pc.. if it still doesn't get into your desktop... check your bios settings or try reinstalling your OS... it happened to me twice.. the same problem as yours but of different motherboard and i just tried reinstalling my OS and then it runs.. btw make sure that those to RAMS are connected properly and no other rams except the two ddr.
Posted on Jan 25, 2008
  • 871 Answers
Hi
is this your motherboard? http://shop.pcmag.com/shop/product_specs/Intel+D915GAG+BLKD915GAGL10+Motherboard/22673983.aspx
if so, it is ok for you to upgrade your memory up to 2gb. btw, just be sure to properly install the rams to the slots.
since youve purchased 2 x 1Gb ddr400 , put on color blue slots.
hope this helps
Posted on Jan 23, 2008
I have A30 8199 with initial 2 ram card of 256 for total of 512 meg. I purchased 2 new cards of 512 each for total or 1Gig. I am on Win XP home and have all updates to XP with Bios of 5/10/05. When I...
Looking over at crucial.com it says that your A30 can use PC2700 and PC3200 DDR. Maybe go other there and see if your new ram matches what they sell. I know it's not much but maybe a start.
Apr 26, 2011 | Lenovo IBM ThinkCentre A30 8199 (8199XX2)...
I upgraded my RAM to 1 Gig but it's still showing only 256 meg. Why?
Hi this model sopport 2Gig Memory Ram.
RAM Technology DDR SDRAM Installed RAM 512 MB Max Supported RAM 2 GB Number of Memory Slots 2 x DIMMs Supported RAM Speeds 400 MHz • 333 MHz Installed Cache Memory 256 KB
Please check in to your Bios system maybe share memory Video or capacity is setting
Nov 03, 2010 | Dell Dimension B110 PC Desktop
Pc keeps rebooting
Try re-installing the operating system. It is possible it possible OS is not installed properly. (ehteshamhusain@gmail.com)
Jul 19, 2009 | Computers & Internet
I have upgraded my k7s8xe with athlon xp 3200 cpu. I have adjusted the jumpers to fsb 200 & installed 1gb ddr 400 ram. system keeps rebooting os vista enterprise. any suggestions. also can i install 2...
First of all, if your FSB is set to 200mhz, the system will not support DDR400. "CPU at FSB 200MHz mode, it will NOT support DDR400". The FSB will have to be either 333 or 400mhz in order to utilize DDR400. Only 1GB of DDR400 is supported. As to your rebooting issue, could be because of these incompatibilities and/or you did not properly seat the heatsink/fan on the new CPU, which also means you might not have properly applied thermal compound or might have no applied it at all. All the compatibility information for this motherboard can be found at: http://www.asrock.com/mb/overview.asp?Model=K7S8XE
Upgrade of RAM
184 pin DDR DIMM is the correct information :) The bus speed of the ram would range from PC 2100 - PC 3200. I assume the Max amount of ram will probably be 2gb though unless your motherboard specifies a higher amount.
Mar 22, 2009 | Computers & Internet
Need to know mem spd...333...400 etc to add cards
Memory Installed 512 MB (2 x 256) Maximum allowed 4 GB* (4 x 1GB) requires the replacement of the installed 256 MB DIMMs
*Actual available memory may be less Speed supported PC3200 MB/sec Type 184 pin, DDR SDRAM DIMM slots Four Open DIMM slots Two
Thats the sticks you need
Good luck
Nic
Feb 26, 2009 | HP Compaq Presario SR1630NX PC Desktop
Windows XP Pro hangs on reboot after installation
Try removing your AGP card and enabling the onboard graphics again. It is possible your Radeon is a 3.3v, but this board only supports 1.5v cards. Take a look at the manual at ftp://download.intel.com/support/motherboards/desktop/D845GERG2/BV2RG2_English.pdf
Dec 29, 2008 | Intel 845GE Motherboard
Presario R4000 does not detect 2GB of memory
Hi PhotoTom,
I check you laptop specification and it really do support uptp 2 GB. So here I'm not sure your 1GB are both of them DDR 333Mhz ?? .If so what I really want you to test here is
1. 1 GB in one slot and turn it on (as you say you can boot wih it) after that move that 1 GB to the other slot and see.
2. try the same with the other 1GB and see that both work fine on both slot or not.
Incase both work fine on both slot then maybe problem with hardware what I want you to do after that is try to check your BIOS version and check on the website that they do have new BIOS version or not ?? Coz this can help incase problem are from BIOS.
Goodluck,takecare.
May 21, 2008 | HP Compaq Presario R4000 Notebook
Please help me in my RAM
If your PC boots up successfully and load windows then its mean that RAM is working fine... There is some problem with OS settings.. So at XP booting press F8 for start-up menu and select Last known good configuration... Hope it will work...
Please Rate .... Thanks.
May 14, 2008 | Intel Motherboard
Medion pc keeps rebooting just as starting to load win xp home
Sir your useing windows xp os ok your Probalm finaly turns off & reboot some .dll fils are missing so your install new software for your pc ok by .
Mar 15, 2008 | Medion MD-1704 PC Desktop
Intel D915GAG Motherboard Logo
113 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
