Garmin Nuvi 760  Car GPS Receiver Logo
Posted on Dec 19, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I am having the same problem with a twist, sound works from the fm and headphone but only from the right side no left audio. I have the 760 and it only has one speaker and my guess it that it gets its feed from the left (which does not work anywhere; headphone or fm transmitter.
SHARCNET-USA
Level 3:
  • Garmin Master 2,130 Answers
  • Posted on Dec 20, 2009
SHARCNET-USA
Garmin Master
Level 3:
Answers
2130
Questions
Helped
782517
Points
4950
If you use the headphone jack a lot and your missing the audio from the speaker and one channel from the headphone jack, then it's possible that some of the headphone jack connections have broken off of the PC board. The audio goes to the speaker through the headphone jack.
Please see this link for more info and read the section about the headphone jack.
http://www.sharc.net/gps_audio_repair.htm
- Jim
I plugged in my headphones and it only plays sounds on one side.
there is a head phone jack in the front and the back. have you tried them both?
Using Denon AVR 2803 as an FM receiver
• Insure that the speaker system is working.
try it on other receiver.
• Check to see if there are headphones connected.
• Check if tuned is lit
4helpful
Only 1 side of my dr dre detox is working
THE INTERNAL WIRE CONNECTING BOTH HEADPHONES IS BROKEN. THIS PROBABLY HAPPENED WHEN TWISTING ONE OF THE HEADPHONES TO HEAR ONLY THROUGH ONE OF THEM. TRY FEEDING EEACH HEADPHONE INDEPENDENTLY WITH ITS OWN CABLE USING ONE OF THOSE PLUGS TO SHARE MUSIC FROM SAME SOURCE.
1helpful
2answers
Ive a problem with the volume of the headphones, the right one works fine but there is no sound from the left side....ive tested the headphones on other electronic equipment and the headphones work the...
Hi,,in most cases what causes one side of the headphone to work is because, the wire that is connected to speaker inside the headphone might have cut and it's not contacting properly.
What you will need to do is to open up the head phone (left),and check if the wire inside has not cut, If it has removed ,then you will need to put it back with soldering iron and a lead...
But if the wire inside has not removed and they are intact, then you will have to replace the left speaker .
Hope that helps...
Thanks for using fixya...
2helpful
I have my "PHILIPS SBC HC105" wireless headphone, it's left side is working properly but the right side of the headphone doesn't? i tried it in my many gadgets, PSP, Ipod, Mp3, T.V., Phone... and still...
Sorry, I haven't a solution, but i have the same problem and an another one i broke the wires in the right headphone. If you open this,you make a picture for me and you post it, please. Thanks
My earphones' audio isn't right. I have to twist the wires to get it fixed. Sometimes, it only has sounds on the left or on the right or nothing. What should I do?
You have fault in the wires that has been twisted and open/ shorted within losing the connectivity. The best thing is to get this replaced if you can do the work by yourself, you will have to buy the shielded twin core wires, one headphone stereo jack, open the earpiees carefully- it is tricky,so do it gently, solder the wires in accordance with the lead and shield on either sides and then connect to the stereo headphones. Hope this wil work out for you. Good day
Headphones only have left channel on Denon AVR-588 Receiver
Hi peroty,
Two suggestions for you.
1. If you look at the headphone jack connecton do you see one or two black O-rings or black lines on the jack. If you only see one they are Mono headphones and you would only get sound out of the left side. If there are two black lines they are stereo headphones and you should get sound on both the left & right sides.
2. If after checking the headphone jack connection and there are two black lines on it then I would suggest try a different pair of headphones to see if a different set of headphones works fine.
If a different pair of headphones works properly the original headphones may be bad. If neither set of headphones work properly it may be the reciever that may need to be repaired.
I hope it's not the receiver, but let me know if you have questions.
Matt @ OneCall
www.onecall.com
twitter.com/onecalldotcom
Top Garmin GPS Experts
vince
Jesse Walters
Jesse Walters
Are you a Garmin GPS Expert? Answer questions, earn points and help others
